    [Preview] Wrap-R Video #2
    extensions
    72 Posts 26 Posters 22.9k Views 26 Watching
    • alsomarA Offline
      alsomar Extension Creator
      Any new about this? I'm sure it will be a game changer!
      Greetings!
      Alejandro Soriano Visuals · All my links
        jfa
        Hello Rich O Brien... any news? I'm impatient ... Wrap-R is the first in my shopping list
          This month we open up the beta to test as many OS as we can.
          But here's a video I did for the current testers showing some of the new functionality...
            Do you mean will it export the UV layout?
            You can export the UVs to SVG so you can scale them to any resolution without pixelation.
              rv1974
              Will Wrapper feature some kind of 'render UV template' with alpha (3DS Max terminology)?
              https://vimeo.com/151742771
              My idea is to use Object Painter tool later (upon proper set UV map)
              • alsomarA Offline
                Great! 😄
                • GubermenschG Offline
                  Gubermensch
                  Very excited for this.
                  I suspect the Beta will be closed. I'd be happy to participate if you're looking for more users.
                  http://www.jacobgubler.com/
                    jonorman
                    Second that, beta testing would be nice 😄
                    • SJS66S Offline
                      SJS66
                      Wow. Looks good. If you need a complete noob for testing, I'm in. Might be helpful.....can't blame a bloke for trying though 😛
                        SebastianSztyber
                        Could you upload part 2-3? 😃
                          pinoy
                          Hi Rich, Will we see Mac OS as well? Just downloaded but for Windows only.
                          Any news on this?
                          Cheers
                            SourceSkyBoxer
                            Hello I can not understand why does wrapr not work for me 😞 If I marked seam lines as green lines than export to obj file. than wrapr doesn't work why?? I can not understand 😞 PLEASE EXPLAIN ME CLEAN! HOW DO I USE STUPID GREEN LINES.....????????????????????????
                              Gábor
                              Thank you for testing Wrap-R beta. Do I understand well that after you mark the seams in SketchUp, you export your model to .obj from SketchUp? The .obj exporter will not export the marked seams so of course you will not see them in Wrap-R. The preferred way to do it:
                              • Mark your seams in SketchUp with the Wrap-R plugin.
                              • Select in SketchUp the geometry you want to unwrap.
                              • Right click the selected geometry and from the context menu select "WrapR / Send to WrapR"
                              Other option:
                              If you want to use Wrap-R as a stand-alone application. You need to save your model in .skp format and open the .skp file in Wrap-R.
                              I hope this helps.
                                Gábor
                                Any news on this?
                                Cheers
                                Hi Pinoy,
                                Currently we are concentrating on the development of the Win version. If the Win version will be popular on the market we plan to make a MAC version as well.
                                • 4 / 4
