    SketchUp 2017 Wishlist
    105 Posts 45 Posters 73.3k Views 45 Watching
    • utilerU
      utiler
      Ok, gets get started on the next version:
      • LineTools
        Custom linetypes [dashed, centre, dotted, etc]
      As with CAD programs in general, I really think that SketchUp users would benefit from being about to create and use custom linetypes.
      • Layers
        SU10 - Ability to nest Layers
      IMO, this is one of the main focuses of future releases should productivity be a priority.
      I posted a while ago about how Layers and the Outliner could be brought closer together. http://forums.sketchucation.com/viewtopic.php?f=15%26amp;t=40338
      I know there are users that might use Outliner and love it however it's only really useful in 'working' not setting out your presentation with scenes, export to Layout, etc..
      Firstly, I use SU and LO for Architectural presentation so manipulation of geometry is paramount. For a long time now, I’ve tried many different ways of setting up my layer structure to try and facilitate the different ways of modeling / output for each project. It was only recently that I realized that this is the answer!!!!
      Let’s consider this:
      Leave Outliner as it is for those whose use it. Hiding a group in Outliner and then saving the currently scene means it is hidden, period. Try going to any other scene and it is not visible. This has no use for saving to and exporting scenes to layer.
      Re-work the Layer Manager UI to be similar to Outliner in that groups and components that are assigned a layer have the ability to be ‘nested’ to a parent layer.
      See adjacent example:
      This allows the user to at least have some control over his / her layer/geometry structure visually as well as being a lot quicker to alter visually. Not to mention if I'm in a group, create another group and want to assign it to a new layer that I should be able to click in the Layer drop down and do so. This automatically creates a new layered named as required and 'nested' within the parent layer group. You would even have the ability to move layers from group to group as required to be included in grouped visibility control.
      Maybe as with Outliner double click on a nested layer and you’re taken straight to the group/component on that layer and start working.
      I’m sure you’ll agree; this would change the way we work in SU significantly.
      Now let’s put it into workflow:
      Say I have modeled a project on a site and want to export a ground floor plan. I cut sections where required and create a new scene called same and save. Now I want to create a first floor layout. If I don't want my site to show beneath in the first floor layout I can turn off the parent 'SITE' layer....BAM! No scrolling through the layer dialogue clicking here and clicking there to isolate geometry. The fact that the nested layer function avoids a global alphabetical search of the layers list it is much easier to see how your model is layered as well as a much quicker way to manipulate visibility.
      I would love to hear from any of the Googlers’ about their thoughts on this.
      BTW, obviously I have used the Outliner Manager to communicate this idea so no toggles for visibility, current active, color [never used it], etc are shown. These would be as they are I assume.
      • Linetypes
      Really need to be able to create custom linetypes [dashed, centre, etc...]
      Relying on exporting to LO and exploding is just laborious.
      There'll be more but these are what comes to my mind...
      Just Curious...
      • JQLJ
        JQL
        SCENES
        • Manage scenes as Utiler would manage layers.
        UV MAPPING
        • Better UV mapping features
        • Specially UV unwrapping
        www.casca.pt
        Visit us on facebook!
          A publicly listed roadmap of development would be nice.
          • jujuJ
            juju
            +1
            • pbacotP
              Just an idea. Not a biggie. What if you could find (and / or) open any layout file which references a SU file --from within the SU file.
              • JQLJ
                JQL
                Useful!
                www.casca.pt
                • pbacotP
                  Also I would like to see trays for Mac just as in Windows. It MUST be possible to clean up the UI! Same for LayOut. Every session requires clearing up all the windows.
                  • JQLJ
                    JQL
                    @numerobis said:
                    • import improvements
                    • better texturing tools
                    • multicore support (yes, this is the way processors evolve now - since a few years)
                    • high poly support
                    • faster ruby script execution! (it's just a joke, that you have to watch a counter when you round some edges, where another app can do this instantly...)
                    • faster explode or copy/paste
                    • disable/configure snapping
                    • an advanced camera without these unbelievable stupid huge frustums and guide lines (clipping problem?) or simply a camera with numerical input for the target hight (or simply the same value as the eye level if a flexible value is too much 😆 )
                    • a usable, more direct or intuitive version of dynamic components with usable stretch and move options like in dynamic blocks in acad for instance
                    • a camera that can use/display shift parameters of the camera in render plugins
                    These should be feasible right?
                    @numerobis said:
                    • Quads
                    • sub-D modeling
                    • better proxy display modes for referenced objects of external renderers - not only a box 😒
                    • non destructive and parametrical modeling using a modifier stack or node graphs. Maybe we'll see a ruby... this seaems to be to only way this program will evolve in the future (as always).
                    www.casca.pt
                    • oceanembersO
                      oceanembers
                      Modulus operator in Dynamic Components. Please. It would make some of my formulae infinitely less complicated.
                      • L
                        Lushi
                        I wish there was a tool that will facilitate the creation of floors from sketches of lines, like revit
                        • utilerU
                          utiler
                          What's a modular operator?
                          Just Curious...
                          • ashscottA
                            ashscott
                            One of these: https://en.wikipedia.org/wiki/Modulo_operation
                            (I still have no idea)
                            Doesn't Simfonia Animation Tools have a modulator function so you can create wave signals (possibly completely unrelated).
                            Wishlist for SU 2017:
                            • FEA (just kidding, but not really)
                            • To incorporate this into the software: http://sketchucation.com/plugin/803-coastalconcepts_editflag
                            • Some way to not have segments in arcs
                            • STL export
                            • +1 for publicly listed roadmap of development
                            • Regarding the nesting of layers - isn't this effectively BillyBob's [url=http://sketchucation.com/forums/viewtopic.php?t=53906:36c9x8qg]Layers Panel Plugin?[/url:36c9x8qg]
                            Just some stuff I do with Sketchup.
                            • JQLJ
                              JQL
                              @ashscott said:
                              @utiler said:
                              [*]Regarding the nesting of layers - isn't this effectively BillyBob's Layers Panel Plugin?[/list]
                              The problem is that jiminy had to come up with so many workaround methods to create Layers Panel, that even he got confused and eventually stop supporting it, in order to have time to create skatter.
                              I believe he'd gladly welcome a native solution to this...
                              www.casca.pt
                              • JQLJ
                                JQL
                                I'd say JBB-Layers Panel is as usefull to me as it is to you!
                                www.casca.pt
                                • ashscottA
                                  ashscott
                                  I'm impressed that he even got it to work as someone who was teaching himself Ruby as he went.
                                  I cannot say how useful it has been using Layers Panel in conjunction with scenes to create complex construction documents in Layout.
                                  I arrange every view I need as a scene in sketchup with the appropriate layers on/off (some models have 30+ layers so doing this without Layers Panel is extremely error-prone), send to layout, place the scenes, dimension and add notes, export, build.
                                  Its standard functionality in photoshop etc yet does NOT add any unnecessary complexity to a new user
                                  EDIT: Grammar
                                  • HornOxxH
                                    HornOxx
                                    I´ve just copy pasted my little wish from the SketchUp 2016 Wishlist 😉
                                    I want an improved 2D pixels export - regardless of the width/height-size of my currently used SkUp viewport. (As if I would adjust the output resolution within any render plugin)
                                    I want that other SkUp users with their own viewport sice can export exactly the same file resolution as I do. Interacting by repeating the same output results with other users would be so much easier ...
                                    Even if there is a plugin for that, SkUp should at last be able to do this "out of the box"
                                    never trust a skinny cook
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      I'd very much indeed.
                                      I'll soon make it completely open-source, so that anyone can update it, even try to make money out of it, whatever.
                                      • S
                                        sketchuh
                                        Guys, Trimble Won't improve anything you wished here, since we are only 0.0001% of the market...haha.
                                        But Plugin authors are the best here! Thank you all for the great plugins!
                                        • HornOxxH
                                          HornOxx
                                          well written 💚
                                          I agree!
                                          • ashscottA
                                            ashscott
                                            Speaking of which, I'd pay someone to clean up Layers Panel and make it as robust as possible - I just can't pay enough to make it worthwhile - on the other hand, if there were a number of us willing to pay...
                                            • 6
                                            • 1 / 6
