    SketchUp 2017 Wishlist
    105 Posts 45 Posters 72.3k Views 45 Watching
      A publicly listed roadmap of development would be nice.
      • jujuJ Offline
        juju
        +1
        • pbacotP Offline
          Just an idea. Not a biggie. What if you could find (and / or) open any layout file which references a SU file --from within the SU file.
          • JQLJ Offline
            JQL
            Useful!
            www.casca.pt
            Visit us on facebook!
            • pbacotP Offline
              Also I would like to see trays for Mac just as in Windows. It MUST be possible to clean up the UI! Same for LayOut. Every session requires clearing up all the windows.
              • JQLJ Offline
                JQL
                @numerobis said:
                • import improvements
                • better texturing tools
                • multicore support (yes, this is the way processors evolve now - since a few years)
                • high poly support
                • faster ruby script execution! (it's just a joke, that you have to watch a counter when you round some edges, where another app can do this instantly...)
                • faster explode or copy/paste
                • disable/configure snapping
                • an advanced camera without these unbelievable stupid huge frustums and guide lines (clipping problem?) or simply a camera with numerical input for the target hight (or simply the same value as the eye level if a flexible value is too much πŸ˜† )
                • a usable, more direct or intuitive version of dynamic components with usable stretch and move options like in dynamic blocks in acad for instance
                • a camera that can use/display shift parameters of the camera in render plugins
                These should be feasible right?
                @numerobis said:
                • Quads
                • sub-D modeling
                • better proxy display modes for referenced objects of external renderers - not only a box πŸ˜’
                • non destructive and parametrical modeling using a modifier stack or node graphs. Maybe we'll see a ruby... this seaems to be to only way this program will evolve in the future (as always).
                www.casca.pt
                • oceanembersO Offline
                  oceanembers
                  Modulus operator in Dynamic Components. Please. It would make some of my formulae infinitely less complicated.
                    Lushi
                    I wish there was a tool that will facilitate the creation of floors from sketches of lines, like revit
                    • utilerU Offline
                      utiler
                      What's a modular operator?
                      Just Curious...
                      • ashscottA Offline
                        ashscott
                        One of these: https://en.wikipedia.org/wiki/Modulo_operation
                        (I still have no idea)
                        Doesn't Simfonia Animation Tools have a modulator function so you can create wave signals (possibly completely unrelated).
                        Wishlist for SU 2017:
                        • FEA (just kidding, but not really)
                        • To incorporate this into the software: http://sketchucation.com/plugin/803-coastalconcepts_editflag
                        • Some way to not have segments in arcs
                        • STL export
                        • +1 for publicly listed roadmap of development
                        • Regarding the nesting of layers - isn't this effectively BillyBob's [url=http://sketchucation.com/forums/viewtopic.php?t=53906:36c9x8qg]Layers Panel Plugin?[/url:36c9x8qg]
                        Just some stuff I do with Sketchup.
                        • JQLJ Offline
                          JQL
                          @ashscott said:
                          @utiler said:
                          [*]Regarding the nesting of layers - isn't this effectively BillyBob's Layers Panel Plugin?[/list]
                          The problem is that jiminy had to come up with so many workaround methods to create Layers Panel, that even he got confused and eventually stop supporting it, in order to have time to create skatter.
                          I believe he'd gladly welcome a native solution to this...
                          www.casca.pt
                          • JQLJ Offline
                            JQL
                            I'd say JBB-Layers Panel is as usefull to me as it is to you!
                            www.casca.pt
                            • ashscottA Offline
                              ashscott
                              I'm impressed that he even got it to work as someone who was teaching himself Ruby as he went.
                              I cannot say how useful it has been using Layers Panel in conjunction with scenes to create complex construction documents in Layout.
                              I arrange every view I need as a scene in sketchup with the appropriate layers on/off (some models have 30+ layers so doing this without Layers Panel is extremely error-prone), send to layout, place the scenes, dimension and add notes, export, build.
                              Its standard functionality in photoshop etc yet does NOT add any unnecessary complexity to a new user
                              EDIT: Grammar
                              • HornOxxH Offline
                                HornOxx
                                IΒ΄ve just copy pasted my little wish from the SketchUp 2016 Wishlist πŸ˜‰
                                I want an improved 2D pixels export - regardless of the width/height-size of my currently used SkUp viewport. (As if I would adjust the output resolution within any render plugin)
                                I want that other SkUp users with their own viewport sice can export exactly the same file resolution as I do. Interacting by repeating the same output results with other users would be so much easier ...
                                Even if there is a plugin for that, SkUp should at last be able to do this "out of the box"
                                never trust a skinny cook
                                • jiminy-billy-bobJ Offline
                                  jiminy-billy-bob
                                  I'd very much indeed.
                                  I'll soon make it completely open-source, so that anyone can update it, even try to make money out of it, whatever.
                                    sketchuh
                                    Guys, Trimble Won't improve anything you wished here, since we are only 0.0001% of the market...haha.
                                    But Plugin authors are the best here! Thank you all for the great plugins!
                                    • HornOxxH Offline
                                      HornOxx
                                      well written πŸ’š
                                      I agree!
                                      • ashscottA Offline
                                        ashscott
                                        Speaking of which, I'd pay someone to clean up Layers Panel and make it as robust as possible - I just can't pay enough to make it worthwhile - on the other hand, if there were a number of us willing to pay...
                                          jiminy-billy-bob
                                          You could start a kickstarter or similar πŸ˜„
                                          • ashscottA Offline
                                            ashscott
                                            Who would be able to do the coding really well?
                                            • 1 / 6
