    Projecting through a solid
    26 Posts 8 Posters 1.3k Views 8 Watching
    • AnsenSealeA Offline
      AnsenSeale
      Is there a way to project an image through a solid shape so that it shows up on both sides?
      --Ansen Seale
      ansenseale.com
        Would it not be enough to apply the image to the opposite face? If that would work, you could make a mirrored version of it and apply that on the opposite side.
          AnsenSeale
          I have about 60 of these to project in this model, so I was trying to save myself some steps.
          --Ansen Seale
          ansenseale.com
            Creating the reversed images could probably be batched with some image editors.
            Although having reversed faces is generally inadvisable, another option would be to reverse the face on the opposite side from the first texture image and apply the same material to that reversed face. I did that in this SKP file.
            Another option would be to leave the face correctly oriented, apply the material and then right click, choose Texture>Position, right click again and choose Flip>Left/Right.
            mirrored texture.skp
            • BoxB Offline
              Dave seems to be on the money here, but an image of what you want to do would help.
                too bad I'm not in the money. 😆 😆
                • ntxdaveN Offline
                  ntxdave
                  You can even take advantage of a transparent image to make something like a sign that has irregular edges using DaveR's technique. The attached model is an example.
                  WashEntranceSign.skp
                  Press F1...thank me later
                  • Wo3DanW Offline
                    Wo3Dan
                    Before applying the texture to a face (still default on both sides!) just reduce the opacity from 100% to say 99%. Then sample it and paint default faces.
                    Once done, raise opacity of the texture to 100% again if needed.
                    Front shows normal oriented texture, back shows mirrored texture.
                      That works if you are applying the material to both sides of the same face but not if applying the material to the opposite end of a 3D shape, right Gerrit?
                      • KrisidiousK Offline
                        Krisidious
                        Depends on if you can have back faces on a solid. then it should be revered on back right? I'd have to test.
                        By: Kristoff Rand
                          C'mon. Catch up. 😆 We've already done that. If you look at the SKP file I shared back a few posts, you'll see it works. You don't need to test it.
                            Krisidious
                            Don't ask me how I did it... Cuz I can't recreate it now.
                            backside.skp
                            By: Kristoff Rand
                              Krisidious
                              Cuz I didn't do it...
                              By: Kristoff Rand
                              • Wo3DanW Offline
                                Wo3Dan
                                @dave r said:
                                ........That works if you are applying the material to both sides of the same face but not if applying the material to the opposite end of a 3D shape, right Gerrit?
                                How can I get out of this, 😲 and deny that you are right.
                                Well, let's just face it, you are right Dave. I should have paid more attention when reading. 😳
                                  AnsenSeale
                                  Thanks, guys.
                                  I'm just sending a screenshot because my model is already 15MB with all the photos. I definitely want to project through the solid, if possible, not just affect both sides of a face. My images are abstract enough that flipping is not really the issue. It's just pure laziness on my part. That's the issue.
                                  --Ansen Seale
                                  ansenseale.com
                                    Krisidious
                                    with those types of images, those that are hard to discern left from right, you could easily just paint the surface with the one material... I doubt many would know it was not the same on the other side.
                                    By: Kristoff Rand
                                      AnsenSeale
                                      My point exactly. I just don't want to import all the image over again, doubling my file size and rendering time.
                                      --Ansen Seale
                                      ansenseale.com
                                        Once the image is imported as a texture, there's no need to import it again. There's no reason to wind up with two of each image.
                                          Krisidious
                                          Yeah... As Dave said, there will only be one of each image, even if you mirrored it, it would be the same image mirrored. and there is a plugin to import all images from a directory.
                                          By: Kristoff Rand
                                            AnsenSeale
                                            How would you duplicate a texture without importing it again?
                                            Thanks.
                                            --Ansen Seale
                                            ansenseale.com
                                            • 1 / 2
