    Projecting through a solid
    26 Posts 8 Posters 1.3k Views 8 Watching
    • AnsenSealeA Offline
      AnsenSeale
      I have about 60 of these to project in this model, so I was trying to save myself some steps.
      --Ansen Seale
      ansenseale.com
        Creating the reversed images could probably be batched with some image editors.
        Although having reversed faces is generally inadvisable, another option would be to reverse the face on the opposite side from the first texture image and apply the same material to that reversed face. I did that in this SKP file.
        Another option would be to leave the face correctly oriented, apply the material and then right click, choose Texture>Position, right click again and choose Flip>Left/Right.
        mirrored texture.skp
        • BoxB Offline
          Dave seems to be on the money here, but an image of what you want to do would help.
            too bad I'm not in the money. 😆 😆
            • ntxdaveN Offline
              ntxdave
              You can even take advantage of a transparent image to make something like a sign that has irregular edges using DaveR's technique. The attached model is an example.
              WashEntranceSign.skp
              Press F1...thank me later
              • Wo3DanW Offline
                Wo3Dan
                @ansenseale said:
                Is there a way to project an image through a solid shape so that it shows up on both sides?
                Before applying the texture to a face (still default on both sides!) just reduce the opacity from 100% to say 99%. Then sample it and paint default faces.
                Once done, raise opacity of the texture to 100% again if needed.
                Front shows normal oriented texture, back shows mirrored texture.
                  That works if you are applying the material to both sides of the same face but not if applying the material to the opposite end of a 3D shape, right Gerrit?
                  • KrisidiousK Offline
                    Krisidious
                    Depends on if you can have back faces on a solid. then it should be revered on back right? I'd have to test.
                    By: Kristoff Rand
                      C'mon. Catch up. 😆 We've already done that. If you look at the SKP file I shared back a few posts, you'll see it works. You don't need to test it.
                        Krisidious
                        Don't ask me how I did it... Cuz I can't recreate it now.
                        backside.skp
                        By: Kristoff Rand
                          Krisidious
                          Cuz I didn't do it...
                          By: Kristoff Rand
                          • Wo3DanW Offline
                            Wo3Dan
                            @dave r said:
                            ........That works if you are applying the material to both sides of the same face but not if applying the material to the opposite end of a 3D shape, right Gerrit?
                            How can I get out of this, 😲 and deny that you are right.
                            Well, let's just face it, you are right Dave. I should have paid more attention when reading. 😳
                              AnsenSeale
                              Thanks, guys.
                              I'm just sending a screenshot because my model is already 15MB with all the photos. I definitely want to project through the solid, if possible, not just affect both sides of a face. My images are abstract enough that flipping is not really the issue. It's just pure laziness on my part. That's the issue.
                              --Ansen Seale
                              ansenseale.com
                                Krisidious
                                with those types of images, those that are hard to discern left from right, you could easily just paint the surface with the one material... I doubt many would know it was not the same on the other side.
                                By: Kristoff Rand
                                  AnsenSeale
                                  My point exactly. I just don't want to import all the image over again, doubling my file size and rendering time.
                                  --Ansen Seale
                                  ansenseale.com
                                    Once the image is imported as a texture, there's no need to import it again. There's no reason to wind up with two of each image.
                                      Krisidious
                                      Yeah... As Dave said, there will only be one of each image, even if you mirrored it, it would be the same image mirrored. and there is a plugin to import all images from a directory.
                                      By: Kristoff Rand
                                        AnsenSeale
                                        How would you duplicate a texture without importing it again?
                                        Thanks.
                                        --Ansen Seale
                                        ansenseale.com
                                        • BoxB Offline
                                          Thanks.
                                          Use the eye dropper tool to select the one you want and paint it on the other face.
                                            AnsenSeale
                                            Thank you, Box!
                                            My interface looks like this on the Mac. The "Materials" label brings up the Colors window with my photos showing up under "Colors in Model". I like the PC version better.
                                            --Ansen Seale
                                            ansenseale.com
