    Measurment text in black area
    24 Posts 5 Posters 5.9k Views 5 Watching
      @dave r said:
      I wonder why I don't have any issue on my machine with this.
      Could still be Print Driver........I am using Adobe Acrobat ProXI.
      Charlie
      So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
      • TIGT
        I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
        • C
          Charlie__V
          Charlie
          My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
          I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
          I do not have any other print driver installed to test further.
          Charlie
          PS:
          XPS Writer does not black out the text.
          MS_XPS_Writer_HLR
          • C
            Charlie__V
            Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
            As I suspected.......the HLR print (output) option is vector based output.
            So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
            SU dimension text fails to convert/display as vector?
            User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
            I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
            Best,
            C
            Trimble_SU_Print_To_HLR
            • 2 / 2
