    SketchUp 2015 is 64bit
    302 Posts 74 Posters 115.4k Views 74 Watching
    • BoxB
      In a word, Yes.
      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59648#p543000
      • tt_suT
        tt_su
        @krisidious said:
        Well, hello Steve... Nice to meet you.
        First time I saw the template figure I thought it was Mike... ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜†
        • tt_suT
          tt_su
          @pixero said:
          Will thumbnail previews on wondows 64bit work now without any third part software?
          Yes - the thumbnail handler will now be 64bit if you install the 64bit version. Though I'm not sure if you will see thumbnails in 32bit applications when you use the file dialogs.
          • hellnbakH
            hellnbak
            Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
            And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
            They seem to be getting serious about making changes that really matter.
            Kudos, Trimble ๐Ÿ‘
              Mike's taller
              • BoxB
                I like the Rotated rectangle tool, but it is very easy to get Z-Fighting with it.
                  Don't draw one rectangle on top of another. ๐Ÿ˜„
                  • BoxB
                    Dave you're always a font of good advice, one might even say you are full of it.
                    • hellnbakH
                      hellnbak
                      ๐Ÿคฃ
                      • tt_suT
                        tt_su
                        Kudos, Trimble ๐Ÿ‘
                        We're just getting warmed up! ๐Ÿ˜Ž It takes time to turn a big boat around. ๐Ÿ˜‰
                        • srxS
                          srx
                          http://www.michaelspornanimation.com/splog/wp-content/uploads/2013/02/toot17.jpg
                          www.saurus.rs
                          • M
                            meanmrmustard85
                            Hi - Any advice on whether V-Ray 2.0 is compatible with 2015? Want to make sure before I upgrade and wipe out our rendering capability!
                            • N
                              numerobis
                              so, finally... 64bit. Thanks!
                              And if the slow exploding/importing is really improved, this is even better!
                              And the PhotoMatch upgrade looks very useful
                              http://help.sketchup.com/en/article/3000075
                              http://help.sketchup.com/en/article/1004436
                              Is this working with manually imported photos or only with images imported via special Trimble software?
                              Concerning the new license system... so it is possible to install v8 and 2015 side by side and i'm not loosing my v8 license, right?
                              (the new arc and rectangle tools are nice to have but not really worth mentioning i think, the same applies to the fast styles - i suppose it will not be faster than simple lines...)
                                It's exactly the same as it's always been. You can have multiple versions installed and one license doesn't affect the other. They are entirely separate installations. And in case you haven't seen this before: Do not simply copy plugins from your old SU8 installation to SU2015. It's been repeat ad nauseum for most of the last year so you should have seen it by now.
                                  Might be worth getting in touch with the V-ray people and get the information from the source.
                                    The only downside I can see at the moment is that we now have 64 bit but I cannot think of a thing to do with it. No rendering for some time I reckon but at least I can get the modelling done in preparation. I just hope it is not too long for renders to begin.
                                    • N
                                      numerobis
                                      Thanks! ๐Ÿ˜„
                                      • BoxB
                                        And as has been pointed out, you can run both side by side. Which means even if Vray doesn't yet work with 2015 you can still model in it and render in 2014.
                                        • olisheaO
                                          olishea
                                          Congratulations SU team. This is a huge advancement for SketchUp. I was getting so frustrated with the software but now it's onwards and upwards I guess. ๐Ÿ˜„
                                          oli
                                          • bmikeB
                                            bmike
                                            Guess you have to go get it 'manually'?
                                            mike beganyi design + consulting llc
                                            • 15
                                            • 16
                                            • 3 / 16
