    De-Tripling (De-Triangularization)
    8 Posts 5 Posters 748 Views 5 Watching
    • K
      Kanastrous
      Sometimes one winds up with a model (frequently imported)which contains a large number of unnecessary triangular polys (for example a flat plane which needs be defined only by its edges but nonetheless is subdivided into many polygons across its face).
      Does anyone know of an automated tool that can analyze a model, and "de-triple" (combine together into one flat poly) polygons that are unnecessarily subdivided?
      thanks,
      karl
        ThomThom's CleanUp would be one option.
        • xiombargX
          xiombarg
          If erasing the triangulation lines also results in erasing geometry (which will mean that cleanup won't get rid of those lines) then do this:
          1- Use the Axes tool and set it to the plane's surface.
          2- Select the entire planar surface along with all triangulation lines.
          3- Use thomthom's Vertex Tools ($20) gizmo to scale the surface on the "z" plane to zero. (The "z" plane is the perpendicular plane to the surface).
          4- Erase lines with eraser.
          • xiombargX
            xiombarg
            I should also mention that you can use the above directions to flatten any uneven surface or make any selected geometry flatten to a single perfectly flat plane.
            • Bob JamesB
              Bob James
              Artisan has an option to decrease the the amount of triangles.
              • K
                Kanastrous
                Tried installing Cleanup but weirdly enough while it shows up in the Plugins Manager, it's nowhere to be found on any menu.
                Xiombarg - thanks for the tip. Also, great choice of screen name.
                Bob James - I use Artisan but unfortunately its polygon reduction facility leaves lots of triples and distorts geometry too much, at the level of cleanup I need to perform.
                • TIGT
                  Have you Activate the CleanUp Extension ?
                  Did you also install TT_Lib it needs ??
                  • K
                    Kanastrous
                    ...and there it is. Always nice when someone points you in the right direction. Thanks!
