    Request: Modeling a particular form trumpet-ish
    16 Posts 6 Posters 1.1k Views 6 Watching
    • benjanowitzB
      benjanowitz
      Hey guys, I was wondering if you could help me out, again.
      I need to have this shape:
      in 3d version. It's like a big empty tube. I know that it will be involved the Follow Me tool, but how?
      Thanks,
      Ben.
      • K
        kaas
        I need to have this shape:in 3d version. It's like a big empty tube. I know that it will be involved the Follow Me tool, but how?
        Thanks,
        Ben.
        I would model it using Curviloft http://sketchucation.com/forums/viewtopic.php?t=28586. Just need to trace the path (middle of the shape) and a few circles with different radius at the right places. Don't have the time to model an example but maybe using the above you can try/find out yourself.
        • benjanowitzB
          benjanowitz
          Thanks Kaas.
          I've tried with curveloft (loft along a path) but the resault it's pretty far from what I want...probably my fault.
          P.S. As I click enter to consolidate the loft, sketchup crashes!
          • massimoM
            massimo Moderator
            You need to draw properly the starting "wireframe".
            In the picture below you can see a simple basic start using the "loft by path" tool. Of course you can select the circles two by two and use the "loft by spline" tool trying different spline methods (and tension) to refine more the shape.
            • S ShepherdS
              S Shepherd
              Untitled.jpgYou might try making the "horn" straight with follow me tool then bending with fredoscale's radial bending.
              S
              • benjanowitzB
                benjanowitz
                Thanks guys!!
                I'm gonna try right now and let you know!
                Thanks!
                  Perpendicular face tool can be useful for draw some elaborate sections on the path! πŸ˜‰
                  By Chris Fullmer
                  • benjanowitzB
                    benjanowitz
                    Guys, is there anyone who can loft it for me? As soon as I press 'enter' to consolidate, SU crashes...
                    Thanks!
                    pipe.skp
                    • massimoM
                      massimo Moderator
                      No crash for me. Anyway you have circles with 100 segments. That slows down the operation. Also it's better if the circles are perpendicular to the path. I've reduced the circles to 48 segments and rotated one circle. Do you need something like this?
                      pipe.skp
                        As Massimo said, you're using way more segment than you really need. And, as I told you twice before, if you insist on using all those segments in your circles and curves, you need to work at a much larger scale. Maybe the third time will get through to you. I had no problem with it when I scaled it up to a reasonable size.
                        pipe.skp
                        • benjanowitzB
                          benjanowitz
                          Could you, please, achieve something like this one? (it's a model)
                          • benjanowitzB
                            benjanowitz
                            [attachment=0:3aabmiar]<!-- ia0 -->pipe.png<!-- ia0 -->[/attachment:3aabmiar]
                            Hey Dave, yes you said me before about the segments, but I need them in order to have, as much as possible, clean PDF files to edit in AI. The 'horn' was 4 meters tall, I thought was a resonable lenght.
                            • massimoM
                              massimo Moderator
                              As I wrote before use the "loft by spline" tool and play with tension.
                              • massimoM
                                massimo Moderator
                                Of course you can also do something like that with the native follow me tool.
                                • benjanowitzB
                                  benjanowitz
                                  Grazie Massimo! πŸ˜„
                                  I'm gonna try right now.
                                  And thanks to everybody.
                                  • massimoM
                                    massimo Moderator
                                    Prego. πŸ˜‰
