    Request: Modeling a particular form trumpet-ish
    16 Posts 6 Posters 1.0k Views 6 Watching
    • S ShepherdS
      S Shepherd
      Untitled.jpgYou might try making the "horn" straight with follow me tool then bending with fredoscale's radial bending.
      S
      • benjanowitzB
        benjanowitz
        Thanks guys!!
        I'm gonna try right now and let you know!
          Perpendicular face tool can be useful for draw some elaborate sections on the path! πŸ˜‰
          By Chris Fullmer
          • benjanowitzB
            benjanowitz
            Guys, is there anyone who can loft it for me? As soon as I press 'enter' to consolidate, SU crashes...
            pipe.skp
            • massimoM
              massimo Moderator
              No crash for me. Anyway you have circles with 100 segments. That slows down the operation. Also it's better if the circles are perpendicular to the path. I've reduced the circles to 48 segments and rotated one circle. Do you need something like this?
              pipe.skp
                As Massimo said, you're using way more segment than you really need. And, as I told you twice before, if you insist on using all those segments in your circles and curves, you need to work at a much larger scale. Maybe the third time will get through to you. I had no problem with it when I scaled it up to a reasonable size.
                pipe.skp
                • benjanowitzB
                  benjanowitz
                  Could you, please, achieve something like this one? (it's a model)
                  • benjanowitzB
                    benjanowitz
                    [attachment=0:3aabmiar]<!-- ia0 -->pipe.png<!-- ia0 -->[/attachment:3aabmiar]
                    Hey Dave, yes you said me before about the segments, but I need them in order to have, as much as possible, clean PDF files to edit in AI. The 'horn' was 4 meters tall, I thought was a resonable lenght.
                    • massimoM
                      massimo Moderator
                      As I wrote before use the "loft by spline" tool and play with tension.
                      • massimoM
                        massimo Moderator
                        Of course you can also do something like that with the native follow me tool.
                        • benjanowitzB
                          benjanowitz
                          Grazie Massimo! πŸ˜„
                          I'm gonna try right now.
                          And thanks to everybody.
                          • massimoM
                            massimo Moderator
                            Prego. πŸ˜‰
