    TEA TIME ( dedicated to tadema)
    19 Posts 10 Posters 1.5k Views 10 Watching
    • gillesG
      gilles
      Your coffee sir.
      • Bryan KB
        πŸ‘
            That's a wonderful model
            • gillesG
              gilles
              Thanks.
              • tademaT
                tadema
                πŸ˜„ Thank you Gilles, great modeling and rendering πŸ‘
                John
                • gillesG
                  gilles
                  Be my guest.
                  • R
                    Rob D
                    That's a great diffused specular material. How did you manage it?
                    • gillesG
                      gilles
                      I think noise is the culprit. πŸ’š
                      • massimoM
                        massimo Moderator
                        Nice model. πŸ‘
                        The material looks not correct however. You can't mix specular & reflection in that way in KT because it will violate the energy conservation law (not proper balance between absorbed and reflected energy). You need a proper layered material instead.
                        • gillesG
                          gilles
                          May I ask you an example off good settings for a similar result?
                          I would appreciate .
                          • massimoM
                            massimo Moderator
                            Well I don't know exactly the result you are after, but here is a very quick attempt of a grey aluminium. Not sure is the best way to do that, anyway it uses a NK al so maybe you need to have installed the NK metals material pack. Try it and if it doesn't work I'll try to post the NK file or make another mat.
                            You can change the percentage of grey reflection by changing the values of the weights: the first is the al and the second is the grey reflection. The sum must be <= 1.
                            Alu_grey.mat.zip
                            • N
                              notareal
                              There are some material packs you might look
                              http://www.kerkythea.net/cms/resources/materials/Metals_Ashikhmin_MLT.mat.zip <- need to use MLT with this
                              http://www.kerkythea.net/cms/resources/materials/Metals%20and%20Car%20Paints.mat.zip
                              • gillesG
                                gilles
                                will take a look thanks.
                                • R
                                  Rob D
                                  That's why this is such a good material. Gilles has managed to fake it with the settings he's used. It's notoriously difficult to get a brushed metal material in Kerkythea without violating laws πŸ˜„ All the aluminium materials I've found so far for KKT have bumped up render times massively so haven't been worth using, for me anyway.
                                  Gilles - how long did that render take with your settings?
                                  • gillesG
                                    gilles
                                    More or less 1h1/2 PhotonMap-High + AA 0.3.
                                    • gillesG
                                      gilles
                                      [attachment=1:2ijicdxd]<!-- ia1 -->alu_grey.jpg<!-- ia1 -->[/attachment:2ijicdxd]
                                      [attachment=0:2ijicdxd]<!-- ia0 -->Alu_grey.mat.zip<!-- ia0 -->[/attachment:2ijicdxd]
                                      Lots of things to try, thanks.
                                      • RichardR
                                        Richard
                                        Not sure if KT reacts the same way as most other render engines but normally adding roughness to a metal produces a plastic, I'd suggest you need bump map it induce the roughness!
                                        BUILTBRAND.COM.AU
                                        • tridemT
                                          tridem
                                          @richard said:
                                          ..I'd suggest you need bump map it induce the roughness!
                                          I guess that way is far more difficult to be managed in KT, using layers as Massimo said is the best way.
                                          I think Gilles has found a good workaround anyway, providing that the sum of the channels colours doesn't exceed 100% white in order to respect the mentioned law.
