    TEA TIME ( dedicated to tadema)
    19 Posts 10 Posters 1.5k Views 10 Watching
    • Bryan KB Offline
      πŸ‘
          That's a wonderful model
          • gillesG Offline
            gilles
            Thanks.
            • tademaT Offline
              tadema
              πŸ˜„ Thank you Gilles, great modeling and rendering πŸ‘
              John
              • gillesG Offline
                gilles
                Be my guest.
                  Rob D
                  That's a great diffused specular material. How did you manage it?
                  • gillesG Offline
                    gilles
                    I think noise is the culprit. πŸ’š
                    • massimoM Offline
                      massimo Moderator
                      Nice model. πŸ‘
                      The material looks not correct however. You can't mix specular & reflection in that way in KT because it will violate the energy conservation law (not proper balance between absorbed and reflected energy). You need a proper layered material instead.
                      • gillesG Offline
                        gilles
                        May I ask you an example off good settings for a similar result?
                        I would appreciate .
                        • massimoM Offline
                          massimo Moderator
                          Well I don't know exactly the result you are after, but here is a very quick attempt of a grey aluminium. Not sure is the best way to do that, anyway it uses a NK al so maybe you need to have installed the NK metals material pack. Try it and if it doesn't work I'll try to post the NK file or make another mat.
                          You can change the percentage of grey reflection by changing the values of the weights: the first is the al and the second is the grey reflection. The sum must be <= 1.
                          Alu_grey.mat.zip
                          • N Offline
                            notareal
                            There are some material packs you might look
                            http://www.kerkythea.net/cms/resources/materials/Metals_Ashikhmin_MLT.mat.zip <- need to use MLT with this
                            http://www.kerkythea.net/cms/resources/materials/Metals%20and%20Car%20Paints.mat.zip
                            • gillesG Offline
                              gilles
                              will take a look thanks.
                                Rob D
                                That's why this is such a good material. Gilles has managed to fake it with the settings he's used. It's notoriously difficult to get a brushed metal material in Kerkythea without violating laws πŸ˜„ All the aluminium materials I've found so far for KKT have bumped up render times massively so haven't been worth using, for me anyway.
                                Gilles - how long did that render take with your settings?
                                • gillesG Offline
                                  gilles
                                  More or less 1h1/2 PhotonMap-High + AA 0.3.
                                  • gillesG Offline
                                    gilles
                                    [attachment=1:2ijicdxd]<!-- ia1 -->alu_grey.jpg<!-- ia1 -->[/attachment:2ijicdxd]
                                    [attachment=0:2ijicdxd]<!-- ia0 -->Alu_grey.mat.zip<!-- ia0 -->[/attachment:2ijicdxd]
                                    Lots of things to try, thanks.
                                    • RichardR Offline
                                      Richard
                                      Not sure if KT reacts the same way as most other render engines but normally adding roughness to a metal produces a plastic, I'd suggest you need bump map it induce the roughness!
                                      BUILTBRAND.COM.AU
                                      • tridemT Offline
                                        tridem
                                        @richard said:
                                        ..I'd suggest you need bump map it induce the roughness!
                                        I guess that way is far more difficult to be managed in KT, using layers as Massimo said is the best way.
                                        I think Gilles has found a good workaround anyway, providing that the sum of the channels colours doesn't exceed 100% white in order to respect the mentioned law.
