    A more traditional look!
    17 Posts 12 Posters 4.1k Views 12 Watching
    • K
      karllarsen
      This is my very first try at a full blown architectural render. I've intentionally tried to portray a more traditional illustration / architectural rendering look, and avoid too much virtual reality, which always looks unnatural to my eye - no offense to those that like it. Modeled entirely in SketchUp, with Xfrog and some low-poly shrubs I made pretty quick - not a single 2D element in the model - but if I did it over I would use 2D trees for behind the structure to reduce some polygons - Xfrog trees are just way over-kill for this type of work so I purchased Xfrog 3.5 and started making more manicured looking medium-polygon trees.
      Positive feed back welcome!
      Less is more.
      • Bryan KB
        Looks good!
        Well done!
        • K
          karllarsen
          Thanks Bryan.
          Less is more.
          • DanielD
            Daniel
            looks nice. I'd crop the bottom some more to reduce the asphalt (asphalt just aint attractive!). Also, looks like it might be washed out a bit - the roof tiles looks pink and the sports car light red.
            My avatar is an anachronism.
            • R
              Roger
              You might want to try adding a cloud shadow on the hills behind the houses. I think that would really make the building pop.
              http://www.azcreative.com
              • ely862meE
                ely862me
                Nice render, a bit too clean for my taste though . I tried to change it a bit (in better I hope) by adjusting the color balance and adding a dirt map over the entire building and alleys . I hope you don't mind too much !
                Elisei (sketchupper)
                Come and See EliseiDesign
                • R
                  rv1974
                  the main issue it's too CG..
                  you need better textures (arroway for example); additionally you should take a look at what Richdirt plugin does.
                  • Z
                    Zylescozar19
                    πŸ‘
                    • Bob JamesB
                      Bob James
                      @rv1974
                      What's "Richdirt"?
                        @Bob
                        http://www.enrichpro.com/en/richdirt/freeversion.html
                        • Bob JamesB
                          Bob James
                          Thanks, Rich. Neat tool, but I only use Thea for rendering.
                          • B
                            Ben Ritter
                            Karl,
                            I always hate commenting on something I'm not even close to being able to do myself, but what I've seen in your render, and others, is the use of a real sky mixed in with the other non-photo real elements. Any way to make the sky detail consistent with the rest of the render? Thoughts?
                            Anyway, I think it looks great otherwise.
                            • T
                              tdevost
                              @rich o brien said:
                              @Bob
                              There doesn't appear to be an SU version...?
                              • K
                                karllarsen
                                Its been a while
                                Less is more.
                                • FrederikF
                                  Frederik
                                  Looks much better... πŸ‘
                                  What render app. have you been using...?
                                  Side note...
                                  Where are you from...?
                                  Karl Larsen sounds very Danish, but the building doesn't look Scandinavian at all...
                                  Cheers
                                  Kim Frederik
                                  • FrederikF
                                    Frederik
                                    With proper texturing, you can achieve similar results using Thea Render... πŸ˜„
                                    This is also achievable using procedurals...
                                    Cheers
                                    Kim Frederik
                                    • Bryan KB
                                      Much better! I noticed you changed the lighting direction, among other things.
                                      That seems to have made a big difference.
