    A more traditional look!
    17 Posts 12 Posters 4.0k Views 12 Watching
    • Z Offline
      Zylescozar19
      πŸ‘
      • Bob JamesB Offline
        Bob James
        @rv1974
        What's "Richdirt"?
          @Bob
          enRichPro - enRich your renderings in a second
          RichDirt free trial - for 3ds Max 2011 - 2025 with V-Ray and Scanline.
          (www.enrichpro.com)
            Bob James
            Thanks, Rich. Neat tool, but I only use Thea for rendering.
              Ben Ritter
              Karl,
              I always hate commenting on something I'm not even close to being able to do myself, but what I've seen in your render, and others, is the use of a real sky mixed in with the other non-photo real elements. Any way to make the sky detail consistent with the rest of the render? Thoughts?
              Anyway, I think it looks great otherwise.
                tdevost
                @rich o brien said:
                @Bob
                (www.enrichpro.com)
                There doesn't appear to be an SU version...?
                  karllarsen
                  Its been a while
                  Less is more.
                  • FrederikF Offline
                    Frederik
                    Looks much better... πŸ‘
                    What render app. have you been using...?
                    Side note...
                    Where are you from...?
                    Karl Larsen sounds very Danish, but the building doesn't look Scandinavian at all...
                    Cheers
                    Kim Frederik
                    • FrederikF Offline
                      Frederik
                      With proper texturing, you can achieve similar results using Thea Render... πŸ˜„
                      This is also achievable using procedurals...
                      Cheers
                      Kim Frederik
                      • Bryan KB Offline
                        Much better! I noticed you changed the lighting direction, among other things.
                        That seems to have made a big difference.
