    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.6k Views 155 Watching
      Personnellement j'avais compris que le JPP de manière générale avait des petits soucis avec les surfaces alambiquées pour en mettre une épaisseur! 😄
      • M
        magazines
        O and two extrusions
        @gilles said:
        Hum...
        Je pense que le résultat recherché est plutôt ça.
        [attachment=1:vs5eal7t]<!-- ia1 -->G2.gif<!-- ia1 -->[/attachment:vs5eal7t]
        Hello. Sorry, my last post didn't seem to accept the image.
        Gilles, that is excellent! Yes, the thicker version is what I am trying to do. And I see there where you are making two follow me shapes intersect each other. I had hoped to extrude the thinner versions that I already had to the big fat ones rather than remake all of them from rails though. My problem seems to come more from a single one extrusion that intersects itself.
        But Fredo, the newer version certainly makes a big improvement. I've attached a comparison on the "O" here. IT seems to work far better, leaving much fewer dense areas to fix. I will see how it works on the more complicated letters as I move forward. My only issue here is that I will need to fill in the edges where faces intersect other faces made by extruding the single letter form. Is there a way using the present form of the plugin to make planar intersections automatically produce edges?
        Oh, and I think that you are right on, Piliou! I have a bit of wonky model making to fix!
        Thanks!
        • fredo6F
          fredo6
          NEW RELEASE: JointPushPull Interactive v4.4a - 18 Dec 18
          JointPushPull Interactive 4.4a provides small adjustments[/b].
          JointPushPull 4.4a requires LibFredo6 8.7a or above
          See plugin home page of JointPushPull for Download of JointPushPull.
          Main Post of the JointPushPull thread on this forum
          Fredo
            Does the last version has "Vector" selected faces to a Plane ? (who is existing in the classical JPP)
            • fredo6F
              fredo6
              Not sure I understand. JPP 4.4a is just a maintenance release. Functionality is the same.
                OK! So why this cool function (Vector to plane) is not more on the JPP 4 ?
                • fredo6F
                  fredo6
                  ....what is Vector to Plane ?
                    Ceci! Qui est bien pratique! Il semble qu'il ne soit plus dans la V 4! 😉
                    • fredo6F
                      fredo6
                      It is still there. You may have to expand the button palette if it is in compressed mode
                      Fredo
                        Damned! 😲 (the 3 little horizontal green arrows expand on the left! 😄
                        Ok I have it but... 😄
                        If it's works in 2015
                        It's buging in 2017! Drawing is good but at the end...so no drawing result! 😮
                        Bizarre, vous avez dit bizarre ? 😄
                        Ruby Error - Vector Push Pull - 20-Dec-18 12_17_33.txt
                        Bug_vector_v6.skp
                        • fredo6F
                          fredo6
                          NEW RELEASE: JointPushPull Interactive v4.4b - 21 Dec 18
                          JointPushPull Interactive 4.4b fixes a potential bug with JPP Vector, Vector To Plane function, when some faces are perpendicular to the direction of push-pull[/b].
                          JointPushPull 4.4b requires LibFredo6 8.7d or above
                          Fredo
                          • fredo6F
                            fredo6
                            This bug is now fixed in v4.4b.
                            In your model, one of the faces is perpendicular to the direction of pushpull and thus would disappear. That's the issue.
                            Thanks for signaling.
                            Fredo
                              Bravo! 👍
                              • S
                                SunnyGee2017
                                First of all, thanks for the amazing plugins that you provide to the community!
                                For some reason, I am experiencing errors with the Round Push-Pull tool. This happens in SU 2017 and SU 2018 alike. Every time I am trying to apply the function, the following error message appears. I have the latest versions of the LibFredo6 (8.7) and Fredo6 JointPushPull (4.4b) installed on a Windows10 machine with the latest drivers for my NVIDIA 960 GPU's. Any idea?
                                Date: 13-Jan-19 09:26:04
                                An error occurred in Round Push Pull
                                Error in Analysis of model
                                Cannot create unit vector from zero length vector
                                body_lib6g6.rbe: 1863 -- intersect_plane_plane
                                body_lib6g6.rbe: 1863 -- vector_exact_average
                                jointpushpullalgo.rbe: 1445 -- block (2 levels) in round_compute_direction
                                jointpushpullalgo.rbe: 1433 -- each
                                jointpushpullalgo.rbe: 1433 -- block in round_compute_direction
                                jointpushpullalgo.rbe: 1415 -- each
                                jointpushpullalgo.rbe: 1415 -- round_compute_direction
                                jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                                jointpushpullalgo.rbe: 1353 -- each
                                jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                                jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                                jointpushpullalgo.rbe: 1111 -- each
                                jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                                jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                                jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                                jointpushpulltool.rbe: 826 -- dragging_start
                                jointpushpulltool.rbe: 1516 -- onLButtonDown
                                  Share the SKP file where you get this message.
                                  • S
                                    SunnyGee2017
                                    Any model. A simple cube is already enough.
                                      There's got to be something more to it than that. Round Push/Pull works fine on a cube here. What's different about your model?
                                      • fredo6F
                                        fredo6
                                        It works fine on a simple cube.
                                        So there must be something special in your model, most likely polluting edges.
                                        Anyway, I fixed the problem and it will go in a next version of LibFredo6.
                                        But it's better to know why you have the problem.
                                        Fredo
                                        • T
                                          theVonZipper
                                          I'm sure Joint Push Pull v4.4b has generated multiple groups at once for me. I just can't recall what choice of options do this. Anyone know? Think I chose the face by face option ... but can't seem to replicate the multiple group results.
                                          OK. Just realized that multiple groups are generated when the faces I'm push/pulling are not connected.
                                          • designerbursaD
                                            designerbursa
                                            It would be great if you add the thickness to the surface and add the option to delete the surface after grouping
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
