    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @pilou said:
      Does the last version has "Vector" selected faces to a Plane ? (who is existing in the classical JPP)
      Not sure I understand. JPP 4.4a is just a maintenance release. Functionality is the same.
        OK! So why this cool function (Vector to plane) is not more on the JPP 4 ?
        • fredo6F
          ....what is Vector to Plane ?
            Ceci! Qui est bien pratique! Il semble qu'il ne soit plus dans la V 4! ๐Ÿ˜‰
            • fredo6F
              It is still there. You may have to expand the button palette if it is in compressed mode
                Damned! ๐Ÿ˜ฒ (the 3 little horizontal green arrows expand on the left! ๐Ÿ˜„
                Ok I have it but... ๐Ÿ˜„
                If it's works in 2015
                It's buging in 2017! Drawing is good but at the end...so no drawing result! ๐Ÿ˜ฎ
                Bizarre, vous avez dit bizarre ? ๐Ÿ˜„
                Ruby Error - Vector Push Pull - 20-Dec-18 12_17_33.txt
                Bug_vector_v6.skp
                • fredo6F
                  NEW RELEASE: JointPushPull Interactive v4.4b - 21 Dec 18
                  JointPushPull Interactive 4.4b fixes a potential bug with JPP Vector, Vector To Plane function, when some faces are perpendicular to the direction of push-pull[/b].
                  JointPushPull 4.4b requires LibFredo6 8.7d or above
                  See plugin home page of JointPushPull for Download of JointPushPull.
                  Main Post of the JointPushPull thread on this forum
                  • fredo6F
                    This bug is now fixed in v4.4b.
                    In your model, one of the faces is perpendicular to the direction of pushpull and thus would disappear. That's the issue.
                    Thanks for signaling.
                      Bravo! ๐Ÿ‘
                        SunnyGee2017
                        First of all, thanks for the amazing plugins that you provide to the community!
                        For some reason, I am experiencing errors with the Round Push-Pull tool. This happens in SU 2017 and SU 2018 alike. Every time I am trying to apply the function, the following error message appears. I have the latest versions of the LibFredo6 (8.7) and Fredo6 JointPushPull (4.4b) installed on a Windows10 machine with the latest drivers for my NVIDIA 960 GPU's. Any idea?
                        Date: 13-Jan-19 09:26:04
                        An error occurred in Round Push Pull
                        Error in Analysis of model
                        Cannot create unit vector from zero length vector
                        body_lib6g6.rbe: 1863 -- intersect_plane_plane
                        body_lib6g6.rbe: 1863 -- vector_exact_average
                        jointpushpullalgo.rbe: 1445 -- block (2 levels) in round_compute_direction
                        jointpushpullalgo.rbe: 1433 -- each
                        jointpushpullalgo.rbe: 1433 -- block in round_compute_direction
                        jointpushpullalgo.rbe: 1415 -- each
                        jointpushpullalgo.rbe: 1415 -- round_compute_direction
                        jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                        jointpushpullalgo.rbe: 1353 -- each
                        jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                        jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                        jointpushpullalgo.rbe: 1111 -- each
                        jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                        jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                        jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                        jointpushpulltool.rbe: 826 -- dragging_start
                        jointpushpulltool.rbe: 1516 -- onLButtonDown
                          Share the SKP file where you get this message.
                            SunnyGee2017
                            Any model. A simple cube is already enough.
                              There's got to be something more to it than that. Round Push/Pull works fine on a cube here. What's different about your model?
                              • fredo6F
                                It works fine on a simple cube.
                                So there must be something special in your model, most likely polluting edges.
                                Anyway, I fixed the problem and it will go in a next version of LibFredo6.
                                But it's better to know why you have the problem.
                                • T
                                  theVonZipper
                                  I'm sure Joint Push Pull v4.4b has generated multiple groups at once for me. I just can't recall what choice of options do this. Anyone know? Think I chose the face by face option ... but can't seem to replicate the multiple group results.
                                  OK. Just realized that multiple groups are generated when the faces I'm push/pulling are not connected.
                                  • designerbursaD
                                    designerbursa
                                    It would be great if you add the thickness to the surface and add the option to delete the surface after grouping
                                    • fredo6F
                                      The native PushPull does not have this option.
                                      Although this could be possible, I think there are enough options in JPP. It is easy to remove the face after push-pull.
                                        rv1974
                                        1.copy surface to buffer
                                        2.execute JPP
                                        3. paste in place
                                        4. delete
                                        • fredo6F
                                          I don't understand. The grouping in Group PushPull 2D Faces is individual by face, which is not supported by JPP.
                                          So this is two different features.
                                          • designerbursaD
                                            designerbursa
                                            It would have been nice if there was an option of giving the thickness similar to the Autocad Exturude command! .. Yes, it is a waste of time but we can easily remove the remaining surfaces. ๐Ÿ˜„ Achievements in your studies Fredo6
                                            "Group PushPull 2DFaces" will not need this plugin! .. thanks Fredo6
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
