    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.1k Views 155 Watching
    • fredo6F
      Pilou,
      You should move to the latest version of JPP, where the interactive selection process is more natural (and where bugs have been fixed too).
      • gillesG
        gilles
        @magazines said:
        Hello!
        I think I have tried what you are demonstrating. Here I pull up with normal JPP as your gif shows on the top face. I do see that a number of the faces are triangles and others are quads. Do you think this is the problem?
        Here's another pic.
        It looks to me that the issue is more about the extrusion causing intersecting planes.
        When I did it before I used the followme JPP option pulling the flat face on the bottom, but it surely resulted in intersecting planes too.
        I wonder what other approach I might take.
        Thanks for taking a look!
        This one?
          @Gilles : Oui mais maintenant il faut faire une "épaisseur générale" (pour je ne sais qu'elles raisons) avec le JPP ! 😉
          Et c'est là que cela peut coincer suivant les natures des surfaces et leurs intersections!
            @Fredo Thx for the tip! ☀
            • gillesG
              gilles
              Hum...
              Je pense que le résultat recherché est plutôt ça.
                Personnellement j'avais compris que le JPP de manière générale avait des petits soucis avec les surfaces alambiquées pour en mettre une épaisseur! 😄
                  magazines
                  O and two extrusions
                  @gilles said:
                  Hum...
                  [attachment=1:vs5eal7t]<!-- ia1 -->G2.gif<!-- ia1 -->[/attachment:vs5eal7t]
                  Hello. Sorry, my last post didn't seem to accept the image.
                  Gilles, that is excellent! Yes, the thicker version is what I am trying to do. And I see there where you are making two follow me shapes intersect each other. I had hoped to extrude the thinner versions that I already had to the big fat ones rather than remake all of them from rails though. My problem seems to come more from a single one extrusion that intersects itself.
                  But Fredo, the newer version certainly makes a big improvement. I've attached a comparison on the "O" here. IT seems to work far better, leaving much fewer dense areas to fix. I will see how it works on the more complicated letters as I move forward. My only issue here is that I will need to fill in the edges where faces intersect other faces made by extruding the single letter form. Is there a way using the present form of the plugin to make planar intersections automatically produce edges?
                  Oh, and I think that you are right on, Piliou! I have a bit of wonky model making to fix!
                  • fredo6F
                    NEW RELEASE: JointPushPull Interactive v4.4a - 18 Dec 18
                    JointPushPull Interactive 4.4a provides small adjustments[/b].
                    JointPushPull 4.4a requires LibFredo6 8.7a or above
                    See plugin home page of JointPushPull for Download of JointPushPull.
                    Main Post of the JointPushPull thread on this forum
                      Does the last version has "Vector" selected faces to a Plane ? (who is existing in the classical JPP)
                      • fredo6F
                        Not sure I understand. JPP 4.4a is just a maintenance release. Functionality is the same.
                          OK! So why this cool function (Vector to plane) is not more on the JPP 4 ?
                          • fredo6F
                            ....what is Vector to Plane ?
                              Ceci! Qui est bien pratique! Il semble qu'il ne soit plus dans la V 4! 😉
                              • fredo6F
                                It is still there. You may have to expand the button palette if it is in compressed mode
                                  Damned! 😲 (the 3 little horizontal green arrows expand on the left! 😄
                                  Ok I have it but... 😄
                                  If it's works in 2015
                                  It's buging in 2017! Drawing is good but at the end...so no drawing result! 😮
                                  Bizarre, vous avez dit bizarre ? 😄
                                  Ruby Error - Vector Push Pull - 20-Dec-18 12_17_33.txt
                                  Bug_vector_v6.skp
                                  • fredo6F
                                    NEW RELEASE: JointPushPull Interactive v4.4b - 21 Dec 18
                                    JointPushPull Interactive 4.4b fixes a potential bug with JPP Vector, Vector To Plane function, when some faces are perpendicular to the direction of push-pull[/b].
                                    JointPushPull 4.4b requires LibFredo6 8.7d or above
                                    • fredo6F
                                      This bug is now fixed in v4.4b.
                                      In your model, one of the faces is perpendicular to the direction of pushpull and thus would disappear. That's the issue.
                                      Thanks for signaling.
                                        Bravo! 👍
                                          SunnyGee2017
                                          First of all, thanks for the amazing plugins that you provide to the community!
                                          For some reason, I am experiencing errors with the Round Push-Pull tool. This happens in SU 2017 and SU 2018 alike. Every time I am trying to apply the function, the following error message appears. I have the latest versions of the LibFredo6 (8.7) and Fredo6 JointPushPull (4.4b) installed on a Windows10 machine with the latest drivers for my NVIDIA 960 GPU's. Any idea?
                                          Date: 13-Jan-19 09:26:04
                                          An error occurred in Round Push Pull
                                          Error in Analysis of model
                                          Cannot create unit vector from zero length vector
                                          body_lib6g6.rbe: 1863 -- intersect_plane_plane
                                          body_lib6g6.rbe: 1863 -- vector_exact_average
                                          jointpushpullalgo.rbe: 1445 -- block (2 levels) in round_compute_direction
                                          jointpushpullalgo.rbe: 1433 -- each
                                          jointpushpullalgo.rbe: 1433 -- block in round_compute_direction
                                          jointpushpullalgo.rbe: 1415 -- each
                                          jointpushpullalgo.rbe: 1415 -- round_compute_direction
                                          jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                                          jointpushpullalgo.rbe: 1353 -- each
                                          jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                                          jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                                          jointpushpullalgo.rbe: 1111 -- each
                                          jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                                          jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                                          jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                                          jointpushpulltool.rbe: 826 -- dragging_start
                                          jointpushpulltool.rbe: 1516 -- onLButtonDown
                                            Share the SKP file where you get this message.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
