    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 310.1k Views 110 Watching
      monmonred
      @jiminy-billy-bob said:
      1. Nope, that's not possible. Unfortunately.
      2. Already working on it.
        3&4. Added to my todo list. ๐Ÿ˜„
      cool! we all will be waiting!
      i'm always checking for your updates. this plugin is so helpful! thanks!
      +Greatness may be measured on how much we have lost for the betterment of mankind+
        IE means the same thing here: Internet Explorer
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          It will be avaiblable on mac when it's ready. I don't know when.
            tomot
            @jgb said:
            Since IE and WIN OS share many DLL's that contain these calls, an update to an IE DLL will update an OS DLL, but not necessarily vice versa. The app developer WILL have the latest IE on his system, and may use an "updated" OS call, but if you have an older IE, that call may fail. ๐Ÿ˜ฎ
            Your point is well taken! ๐Ÿ‘
            Which is why I have always maintained the decision to use Web dialogs in the first place, was a bad idea.
            Lets face it, a robust SU Ruby API should have been developed with its own graphical interface, not unlike the capability of Python. Its unfortunate Ruby was chosen over Python but that's a story for another day. Instead the SU API developers decided to hitch their horse to the I.E. cart which is about as popular as BING. and also alienates the OSX user.
            Lets face it, its almost 2014, and we still have not been able integrate simple graphical information along with user input in a simple format, without a programmer learning 3 other languages to make this work, and also having to be I.E. compliant ..... its downright laughable!
            [my plugins](http://thingsvirtual.blogspot.ca/)
            tomot
            • tt_suT Offline
              tt_su
              • Adds an options to hide the warning for outdated IE versions (This is intended for people with the warning appearing even though their IE is up to date)
              How are you detecting the IE version and which versions are detected incorrectly?
                jiminy-billy-bob
                I display a warning with <!--[if IE 7]> <![endif]-->, etc.
                But it seems to catch sometimes compatibility mode even when it's supposed to be disabled. Don't know why...
                • tt_suT Offline
                  tt_su
                  Some times? Not consistently?
                  Do you use the META tag to force embedded IE to use the actual IE IE render engine? Embedded IE is more conservative and it uses an older render mode even if you have a standard doctype. See the Lost Manual for more details: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki/Doctype---Quirks-vs-Standard-vs-Superstandard
                  I also think that in one of the recent SU versions there was a registry setting set that would bump up this doc type one version (and that would affect older SU versions on the same machine.) So that might be the reason to why you get seemingly random reports of this. It might be they have versions that trigger the IE7 mode.
                  By the way, should you not be detecting older versions as well, not just IE7?
                  <!--[if lte IE 7]> <![endif]-->
                    jiminy-billy-bob
                    That's interesting.
                    But how can we force the last version ? Let's say I put <meta http-equiv="X-UA-Compatible" content="IE=10"/>, how will IE8 behave with this ?
                    Of course I do ๐Ÿ˜‰ , I just display different things depending on the version, so I have two of these.
                    • tt_suT Offline
                      tt_su
                      That's interesting.
                      It will use the newest it can - IE8.
                      I'd recommend you set it to: <meta http-equiv="X-UA-Compatible" content="IE=edge"/> - it will then always pick the latest mode available. Like a normal browser would do. (See example in the SKUI project: https://github.com/thomthom/SKUI/blob/master/src/SKUI/html/window.html#L4)
                        jiminy-billy-bob
                        Ok thanks ! ๐Ÿ˜„
                        • H Offline
                          huckrorick
                          any progress on not updating scenes and changing layers activated in a scene?
                            monmonred
                            just thank you. jiminy-billy-bob! are you working on the option to hide/show multiple layers at a time? can this also have a hotkey?
                            brilliant work!
                            • Bob JamesB Offline
                              Bob James
                              New version 0.7 beta !
                              Changelog :
                              • Added a dark bar at the top to minimize/maximize the dialog
                              • Added CTRL+G : Group selected layers
                              • Added CTRL+SHIFT+G : Ungroup layers
                              • Added CTRL+A : Select all
                              • Added CTRL+E : Merge selected layers
                              • Added different color for groups
                              • Layer0 is now selectable
                              • Fix bug with sorted groups
                              • Potential fix for IE version bug
                              Super improvements - have made a donation
                                jiminy-billy-bob
                                Did you miss version 0.6 ? ๐Ÿ˜‰
                                New version 0.6 beta !
                                • Fix scene auto-update (This is now an option)
                                If was trying to find a good way to do this. Hotkeys are a good idea, thanks.
                                Thanks a lot Bob !
                                  Hi Thomas,
                                  I get this consistently in SU8...
                                  ...not on SU2013
                                    jiminy-billy-bob
                                    I had this as well when trying to update it from the pluginstore inside SU8.
                                    (I use SU8 to check everything is right after an update)
                                    I deleted Layers Panel in the plugin folder and installed it again from the PS. Works fine... I thought it was a permission issue, but maybe the fact that you have it proves it's something else ?
                                    I already had this kind of problem in the past, with files not being properly replaced during an update with the PS.
                                      If you have changed a script file etc then it might be advisable to popup a warning to tell the user to restart SketchUp to effect the changes - depends on how the menus/toolbars etc are written.
                                      BUT if you have a file that is still loading that shouldn't be - e.g. you have replaced it with a new file [with a different name] BUT that older now-not-needed legacy-file is left behind and is loaded/going-to-load-next-time, then your code really needs to do its own tidying up and delete these legacy-files as it itself loads; AND if so; then warn the user to restart SketchUp to effect all of the changes...
                                        jiminy-billy-bob
                                        Nope, no new file, just updated ones. And restarting SU does not solve this...
                                          YEs, I restarted 6 times and still error occured.
                                          I needed to remove and install fresh.
                                          But there is something funky going on with Layers Panel for me for a while. It needs gets listed as needing an update in My Plugins and I could never figure out why.
                                          Great plugin BTW. I ain't knocking it just doing some investigation while I have some time
                                            If you manually remove all of the plugin's subfolder-of-support files and the lone loader .rb... then re-auto-install it is there still the error ?
                                            If so something is wrong in the files/archives - the error message tells you that some js code is adrift ??
                                            Your newly install script needs to tidy up after itself IF there are file changes...
                                            ๐Ÿ’ญ
                                            As a 'trusted author'... Are you really sure that you are properly making the two files needed for inclusion in the PluginStore database - the RBZ for the page and then the 'second-format' needed for the in-SketchUp dialog etc ??
                                            What ZIP program are you using to make the ZIP you are renaming as RBZ ?
                                            Are you using definitely v8 to process the RBZ into the 'second-format' and NOT v2013 ? OR if it has to be made in v2013 are you remembering to do a Save_as to v8, to keep it compatible with earlier versions...
                                            I suspect this might be the core issue - i.e. archives from an author who fails to provide the dialog-version in the required v8 compatible format ! The server-side database built-in version-checker for the 'second-format' ought to trap this, so it is disallowed... but it might be failing ??
                                            Gรกbor ๐Ÿ˜’
                                            Comments need asap - an author should NOT be able to upload incorrectly versioned 'second-format' archives to the PluginStore - they must all be v8.
                                            Please all reread the Author's Guide sticky in the special forum if you are in any doubt as to what you must do...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 33
                                            • 34
                                            • 13 / 34
