    Can't even make half a dang dome
    15 Posts 8 Posters 785 Views 8 Watching
    • hellnbakH Offline
      hellnbak
      Something as basic as it gets, just trying to make half a dome. Should have taken maybe a minute. Yeah, right.
      Everything is symmetrical, colored edges by axis and there's nothing weird about it.
      Until I click follow-me --
      When I make it a full circle, everything's fine
      Yeah, I know, I could just delete half of it and move on, but I would like to know why it's doing what it's doing.
      The SKP is attached.
      Untitled.skp
        When using FollowMe around a partially circular path you need to ensure that the profile face is perpendicular to the first edge [segment] in the path.
        If you start at a 'node' it won't be.
        If you start at the midpoint of a segment it will be.
        So draw your full circle path and then add a line to half it...
        BUT not from node to node but rather drawn from the mid-point of the segments.
        Erase the unwanted parts and perhaps rotate the remaining semi-circle so it is orthogonal again
        Then arrange for the profile to be perpendicular to the end [half] segment.
        The FollowMe surface generated should now be correct.
        Alternatively [as you discovered] make a whole sphere and with hidden geometry on erase half of it to leave a hemisphere.
        OR make the profile from a half-circle and then make a quarter face.
        FollowMe that around a circle - you'll get a proper 'dome' that way.
        OR use EEbyLathe [or a similar tool] to make a true swept extrusion through any angle [it'd be 90 degrees for a half-sphere] - from any profile around a picked axis... The 'end-facets' are auto-corrected to suit...
        • cottyC Offline
          cotty
          Ok, too slow for TIG and Dave, but here is an image ...
          my SketchUp gallery
          • hellnbakH Offline
            hellnbak
            Crap, I knew all this. It was explained to me years ago, right here on the forums when I was just starting out. Have used it many many times.
            My apologies. I think my brain is getting too old and tired for this stuff. πŸ˜’
            I'll just go back to bed.
              I didn't bother with an illustration - a thousand words paint a picture πŸ˜‰
              • hellnbakH Offline
                hellnbak
                Just another old fart's brain fart. Anybody know of a cure for cerebral flatulence?
                  πŸ˜†
                  Marriage?
                  • hellnbakH Offline
                    hellnbak
                    Marriage?
                    if that's the cure I'll just put up with the flatulence
                    • Mike LuceyM Offline
                      Mike Lucey
                      πŸ˜† I know the feeling. As for a cure ..... there is none ...... its a case of just plodding along.
                      • cottyC Offline
                        cotty
                        πŸ˜†
                        my SketchUp gallery
                        • hellnbakH Offline
                          hellnbak
                          Yeah, I suppose. Plodding gets real tiresome after a while, though.
                            mrossk
                            Isn't this where Pilou would mention the "Quick lathe" plugin? πŸ˜„
                            https://www.mkaplanfinefurniture.com/
                              ...and for the shared file to be in v6
                                πŸ˜†
                                I was expecting that, too.
                                • Wo3DanW Offline
                                  Wo3Dan
                                  Don't know,..... but keep distance from any 'Explode' tool!
