    What is this?
    5 Posts 5 Posters 363 Views 5 Watching
      bailey1
      What are these gray borders? They appear when I set up a scene. However when I want to continue working on the model they stay there. Can't figure out hoe to disable it and and am having to restart to remove them.
      please, someone must know 😄
      • yorik1984Y Offline
        yorik1984
        change camera setting
          Looks like masking from the Advanced Camera Tools plugin but that only works in Pro. Is it possible the style you are using contains a watermark mask?
          Go to Window>Styles and choose a style from the default Styles library. Does it go away?
          By the way, you could move some of your toolbars up and give yourself some additional drawing window space.
          • jeff hammondJ Offline
            jeff hammond
            probably from your renderer.. looks like you exported a square view.
            see if your render plugin has a reset camera option
            dotdotdot
            • massimoM Offline
              massimo Moderator
              Yes, as far as I know, often that coming from some render camera settings. There is also a plugin to remove that if you can't get rid of it in other ways.
              http://www.smustard.com/script/FixAspectRatio
