    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 4.8k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      Elevation Maker would be good if you can also make the exterior elevations... which would be an inversion of directions. The same marker is used for exterior parallel elevations.
      Easy Elevations?
      Interioriza?
      Elevation Tools?
      By: Kristoff Rand
      • CadFatherC Offline
        CadFather
        sectionist πŸ˜†
        • BoxB Offline
          Multi Elevation Set Point
            Late to the party...
            ElevTag - 1 direction == outside elev marker...
            ElevTag4 - 4 direction == room elev marker...
            That's what mine is called...
            Unpublished for personal use...
              CadFather
              camera samurai
                Krisidious
                You already have something that does this Tig?
                By: Kristoff Rand
                • renderizaR Offline
                  renderiza
                  Maybe TIG already have this but just in case here is some initial progress into making this plugin happen.
                  The following code is only purpose is to position camera to the center of a group (in this case the marker with arrows). The way the code filters other groups is by name so in this case I am naming the group "Camera".
                  model = Sketchup.active_model ;
                  sel = model.selection ;
                  ents = model.active_entities ;
                  groups = ents.grep(Sketchup;;Group)
                  groups.each do |e|
                    if e.name == "Camera"
                      boundbox = e.bounds ;
                      @center = boundbox.center ;
                    end ;
                  end ;
                  view = Sketchup.active_model.active_view ;
                  x = @center.x.to_f ;
                  y = @center.y.to_f ;
                  z = 50 ;
                  newEye = Geom;;Point3d.new(x,y,z) ;
                  targetX = 0.0 if !targetX ;
                  targetY = 0.0 if !targetY ;
                  targetZ = 50.0 if !targetZ ;
                  newTarget = Geom;;Point3d.new(targetX,targetY,targetZ)
                  newUp = Geom;;Vector3d.new(0,0,1)
                  newCamera = view.camera
                  newCamera.set(newEye,newTarget,newUp)
                  view.camera = newCamera
                  view.invalidate()
                  There is still a lot of things to but just want to post some progress code. This is just testing code that you may use with "Ruby Code Editor" to see results.
                  Cheers!
                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    CadFather
                    woudn't it be more useful to actually click on the position required? (cheddar walls)
                      Krisidious
                      yes that will be necessary. like 5 or more of these will be needed per plan... and rooms will never be in the same location.
                      By: Kristoff Rand
                        renderiza
                        What you suggested can be done no problem but having the ability to place a marker will provide visual reference which is good. Maybe you can click where you want to position camera and also place markers at the same time.
                        Cheers!
                        • OxerO Offline
                          Oxer
                          Are you probe CubicPanoOut? You can free downloading it here CubicPanoOut.rb
                          The plugin create six Views/Scenes-->Front, Right, Left, Back, Up and Down and you have the possibility to save the six images with size option.
                          With the Place Camera SU Tool, put the camera for example in the center of a room and automatically the CubicPanoOut generate the six Views/Scenes.
                          The problem is that the images generates are square, same width & height but you can go to File/Export/2D Graphic and save the image in the size that you want.
                          [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                            Krisidious
                            I'll have a look at it.
                            By: Kristoff Rand
                              sepo
                              We are talking about sections here rather than elevations, right? Elevations would just show internal orthogonal views and sections would cut through the walls.
                              Surely that would be awesome tool to have.
                                Krisidious
                                In drafting we just call them elevations, but yes it is a section and in SU a section would be used to accomplish it. having the walls on either side cut out would be good. However, I have seen architects and designers show varying methods of showing them. some don't show any walls past the interior surface, some show the section of the wall, floor and roof/ceiling...
                                By: Kristoff Rand
                                  sepo
                                  If you are showing design only than cut walls could be omitted, but if you are preparing working drawings than one would show cut walls. In any case I always show cut walls as they convey idea of proximity of windows /doors to the floor/ceiling.
                                  So idea of this plugin is really advanced section tool. That would save a lot of time if possible to implement, so +1 from me.
                                    renderiza
                                    Here is an update of what I have done so far;
                                    #########Guide
                                    # camdist = 80*12
                                    # Elavation A (Front) = x , y+camdist
                                    # Elavation B (Right) = x+camdist , y
                                    # Elavation D (Left)  = x-camdist , y
                                    # Elavation C (Back)  = x , y-camdist
                                    view = model.active_view ;
                                    camera = view.camera ;
                                    pages = model.pages ;
                                    page = pages.selected_page
                                    groups.each do |e|
                                      end ;
                                    end ;
                                    z = 6*12 ;
                                    camdist = 80*12
                                    if page == nil
                                    pages.add "Elevation A"
                                    pages.add "Elevation B"
                                    pages.add "Elevation C"
                                    pages.add "Elevation D"
                                    elev1 = "Elevation A" ;
                                    elev2 = "Elevation B" ;
                                    elev3 = "Elevation D" ;
                                    elev4 = "Elevation C" ;
                                    page_num = 0 ;
                                    pages.each {|page|
                                    	if page.name == elev1
                                    		pages.selected_page = model.pages[page_num] ;
                                    		break
                                    	end ;
                                    	page_num+=1 ;
                                    } #Pages.each
                                    if page.name != "Elevation A"
                                    targetX = x ;
                                    targetY = y+camdist ;
                                    targetZ = z ;
                                    elevACam = view.camera
                                    elevACam.set(newEye,newTarget,newUp)
                                    view.camera = elevACam
                                    view.invalidate()
                                    camera.perspective = true ;
                                    camera.perspective = false ;
                                    page = pages.selected_page.update(1) ;
                                    page_num = 0 ;
                                    pages.each {|page|
                                    	if page.name == elev2
                                    		break
                                    	end ;
                                    	page_num+=1 ;
                                    } #Pages.each
                                    if page.name != "Elevation B"
                                    targetX = x+camdist ;
                                    targetY = y ;
                                    targetZ = z ;
                                    elevBCam = view.camera
                                    elevBCam.set(newEye,newTarget,newUp)
                                    view.camera = elevBCam
                                    view.invalidate()
                                    page_num = 0 ;
                                    pages.each {|page|
                                    	if page.name == elev3
                                    		break
                                    	end ;
                                    	page_num+=1 ;
                                    } #Pages.each
                                    if page.name != "Elevation D"
                                    targetX = x-camdist ;
                                    targetY = y ;
                                    targetZ = z ;
                                    view.invalidate()
                                    page_num = 0 ;
                                    pages.each {|page|
                                    	if page.name == elev4
                                    		break
                                    	end ;
                                    	page_num+=1 ;
                                    } #Pages.each
                                    if page.name != "Elevation C"
                                    targetX = x ;
                                    targetY = y-camdist ;
                                    targetZ = z ;
                                    view.invalidate()
                                    page_num = 0 ;
                                    pages.each {|page|
                                    		break
                                    	end ;
                                    	page_num+=1 ;
                                    } #Pages.each
                                    Important to realize that the above code is just a sketch which still needs to be polish but it offers an idea of the progress. Also I post it so that if anyone spots something that I can improve then please by all means let me know.
                                    If you want to test this its important to do the following;
                                    1. Crete group to serve as a marker
                                    2. Right click that group and pick "Entity info"
                                    3. Under Name enter "Camera"
                                    4. Open "Ruby Code Editor" plugin
                                    5. Copy & Paste the above code I provided to "Ruby Code Editor"
                                    6. Execute Code
                                    7. Done!
                                    Anyways hope to keep working on this so I can finish and make Beta rb file...Cheers!
                                      I have PM'd a 2013 compliant version of my tool 'TIG-ElevTag' to some of you for beta-testing...
                                      All comments welcome [by PM] before it gets published...
                                        Are you gonna publish it how i think you're gonna publish it?
                                          NO.
                                          I await beta-test results...
                                          I'll send you a copy - to test πŸ˜•
                                            renderiza
                                            TIG is upcoming plugin looks very good! I might still finish my attempt to make plugin but only for learning purpose. (Hope to be as good as TIG one day) πŸ’š
                                            Cheers!
                                            • 2 / 3
