    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 6.4k Views 10 Watching
    • OxerO Offline
      Oxer
      Are you probe CubicPanoOut? You can free downloading it here CubicPanoOut.rb
      The plugin create six Views/Scenes-->Front, Right, Left, Back, Up and Down and you have the possibility to save the six images with size option.
      With the Place Camera SU Tool, put the camera for example in the center of a room and automatically the CubicPanoOut generate the six Views/Scenes.
      The problem is that the images generates are square, same width & height but you can go to File/Export/2D Graphic and save the image in the size that you want.
      • KrisidiousK Offline
        Krisidious
        I'll have a look at it.
        By: Kristoff Rand
          sepo
          We are talking about sections here rather than elevations, right? Elevations would just show internal orthogonal views and sections would cut through the walls.
          Surely that would be awesome tool to have.
            Krisidious
            In drafting we just call them elevations, but yes it is a section and in SU a section would be used to accomplish it. having the walls on either side cut out would be good. However, I have seen architects and designers show varying methods of showing them. some don't show any walls past the interior surface, some show the section of the wall, floor and roof/ceiling...
            By: Kristoff Rand
              sepo
              If you are showing design only than cut walls could be omitted, but if you are preparing working drawings than one would show cut walls. In any case I always show cut walls as they convey idea of proximity of windows /doors to the floor/ceiling.
              So idea of this plugin is really advanced section tool. That would save a lot of time if possible to implement, so +1 from me.
              • renderizaR Offline
                renderiza
                Here is an update of what I have done so far;
                #########Guide
                # camdist = 80*12
                # Elavation A (Front) = x , y+camdist
                # Elavation B (Right) = x+camdist , y
                # Elavation D (Left)  = x-camdist , y
                # Elavation C (Back)  = x , y-camdist
                model = Sketchup.active_model ;
                view = model.active_view ;
                camera = view.camera ;
                pages = model.pages ;
                page = pages.selected_page
                sel = model.selection ;
                ents = model.active_entities ;
                groups = ents.grep(Sketchup;;Group)
                groups.each do |e|
                  if e.name == "Camera"
                    boundbox = e.bounds ;
                    @center = boundbox.center ;
                  end ;
                end ;
                x = @center.x.to_f ;
                y = @center.y.to_f ;
                z = 6*12 ;
                newEye = Geom;;Point3d.new(x,y,z) ;
                newUp = Geom;;Vector3d.new(0,0,1)
                camdist = 80*12
                if page == nil
                pages.add "Elevation A"
                pages.add "Elevation B"
                pages.add "Elevation C"
                pages.add "Elevation D"
                elev1 = "Elevation A" ;
                elev2 = "Elevation B" ;
                elev3 = "Elevation D" ;
                elev4 = "Elevation C" ;
                page_num = 0 ;
                pages.each {|page|
                	if page.name == elev1
                		pages.selected_page = model.pages[page_num] ;
                		break
                	end ;
                	page_num+=1 ;
                } #Pages.each
                if page.name != "Elevation A"
                targetX = x ;
                targetY = y+camdist ;
                targetZ = z ;
                newTarget = Geom;;Point3d.new(targetX,targetY,targetZ)
                elevACam = view.camera
                elevACam.set(newEye,newTarget,newUp)
                view.camera = elevACam
                view.invalidate()
                camera.perspective = true ;
                camera.perspective = false ;
                page = pages.selected_page.update(1) ;
                page_num = 0 ;
                pages.each {|page|
                	if page.name == elev2
                		break
                	end ;
                	page_num+=1 ;
                } #Pages.each
                if page.name != "Elevation B"
                targetX = x+camdist ;
                targetY = y ;
                targetZ = z ;
                elevBCam = view.camera
                elevBCam.set(newEye,newTarget,newUp)
                view.camera = elevBCam
                view.invalidate()
                page_num = 0 ;
                pages.each {|page|
                	if page.name == elev3
                		break
                	end ;
                	page_num+=1 ;
                } #Pages.each
                if page.name != "Elevation D"
                targetX = x-camdist ;
                targetY = y ;
                targetZ = z ;
                view.invalidate()
                page_num = 0 ;
                pages.each {|page|
                	if page.name == elev4
                		break
                	end ;
                	page_num+=1 ;
                } #Pages.each
                if page.name != "Elevation C"
                targetX = x ;
                targetY = y-camdist ;
                targetZ = z ;
                view.invalidate()
                page_num = 0 ;
                pages.each {|page|
                		break
                	end ;
                	page_num+=1 ;
                } #Pages.each
                Important to realize that the above code is just a sketch which still needs to be polish but it offers an idea of the progress. Also I post it so that if anyone spots something that I can improve then please by all means let me know.
                If you want to test this its important to do the following;
                1. Crete group to serve as a marker
                2. Right click that group and pick "Entity info"
                3. Under Name enter "Camera"
                4. Open "Ruby Code Editor" plugin
                5. Copy & Paste the above code I provided to "Ruby Code Editor"
                6. Execute Code
                7. Done!
                Anyways hope to keep working on this so I can finish and make Beta rb file...Cheers!
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                  I have PM'd a 2013 compliant version of my tool 'TIG-ElevTag' to some of you for beta-testing...
                  All comments welcome [by PM] before it gets published...
                    Are you gonna publish it how i think you're gonna publish it?
                      NO.
                      I await beta-test results...
                      I'll send you a copy - to test πŸ˜•
                        renderiza
                        TIG is upcoming plugin looks very good! I might still finish my attempt to make plugin but only for learning purpose. (Hope to be as good as TIG one day) πŸ’š
                        Cheers!
                          Krisidious
                          @renderiza said:
                          Cheers!
                          He's a talented guy no doubt. I still want to see what you came up with too Renderiza.
                          By: Kristoff Rand
                            sepo
                            Hi Tig
                            Any chance for me to test it?
                            Best
                            Sepo
                              KrisM
                              TIG or Rendriza,
                              Have you done anything further on your plugin? The need is certainly still out there.
                              KrisM
                                Krisidious
                                Here it is KrisM...
                                404 Not Found
                                (sketchucation.com)
                                By: Kristoff Rand
                                  It's been in the PluginStore for ~16 months !
                                  πŸ˜’
                                    KrisM
                                    Krisidious,
                                    Thanks for the link.
                                    Tig,
                                    I am rather embarrassed here. I did do a search for your plugins but didn't go past the first page. Didn't realize your list is composed of four pages. Your output is prodigious and well appreciated.
                                    KrisM
                                      Krisidious
                                      He's pretty awesome... And sarcastic.
                                      By: Kristoff Rand
                                        I prefer to think of it as my 'dry wit' πŸ˜‰
                                          Krisidious
                                          Then it shall be known as such... In all my kingdoms... as far as the eye can see...
                                          By: Kristoff Rand
                                          • O Offline
                                            otb designworks
                                            Not sure how I missed this the other year, but thanks TIG! Totally awesome!
                                            Cheers, Chuck
                                            OTB Designworks is on Youtube
                                            • 2 / 3
