    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 5.5k Views 10 Watching
    • renderizaR Offline
      renderiza
      What you suggested can be done no problem but having the ability to place a marker will provide visual reference which is good. Maybe you can click where you want to position camera and also place markers at the same time.
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • OxerO Offline
        Oxer
        Are you probe CubicPanoOut? You can free downloading it here CubicPanoOut.rb
        The plugin create six Views/Scenes-->Front, Right, Left, Back, Up and Down and you have the possibility to save the six images with size option.
        With the Place Camera SU Tool, put the camera for example in the center of a room and automatically the CubicPanoOut generate the six Views/Scenes.
        The problem is that the images generates are square, same width & height but you can go to File/Export/2D Graphic and save the image in the size that you want.
        • KrisidiousK Offline
          Krisidious
          I'll have a look at it.
          By: Kristoff Rand
            sepo
            We are talking about sections here rather than elevations, right? Elevations would just show internal orthogonal views and sections would cut through the walls.
            Surely that would be awesome tool to have.
              Krisidious
              In drafting we just call them elevations, but yes it is a section and in SU a section would be used to accomplish it. having the walls on either side cut out would be good. However, I have seen architects and designers show varying methods of showing them. some don't show any walls past the interior surface, some show the section of the wall, floor and roof/ceiling...
              By: Kristoff Rand
                sepo
                If you are showing design only than cut walls could be omitted, but if you are preparing working drawings than one would show cut walls. In any case I always show cut walls as they convey idea of proximity of windows /doors to the floor/ceiling.
                So idea of this plugin is really advanced section tool. That would save a lot of time if possible to implement, so +1 from me.
                  renderiza
                  Here is an update of what I have done so far;
                  #########Guide
                  # camdist = 80*12
                  # Elavation A (Front) = x , y+camdist
                  # Elavation B (Right) = x+camdist , y
                  # Elavation D (Left)  = x-camdist , y
                  # Elavation C (Back)  = x , y-camdist
                  model = Sketchup.active_model ;
                  view = model.active_view ;
                  camera = view.camera ;
                  pages = model.pages ;
                  page = pages.selected_page
                  sel = model.selection ;
                  ents = model.active_entities ;
                  groups = ents.grep(Sketchup;;Group)
                  groups.each do |e|
                    if e.name == "Camera"
                      boundbox = e.bounds ;
                      @center = boundbox.center ;
                    end ;
                  end ;
                  x = @center.x.to_f ;
                  y = @center.y.to_f ;
                  z = 6*12 ;
                  newEye = Geom;;Point3d.new(x,y,z) ;
                  newUp = Geom;;Vector3d.new(0,0,1)
                  camdist = 80*12
                  if page == nil
                  pages.add "Elevation A"
                  pages.add "Elevation B"
                  pages.add "Elevation C"
                  pages.add "Elevation D"
                  elev1 = "Elevation A" ;
                  elev2 = "Elevation B" ;
                  elev3 = "Elevation D" ;
                  elev4 = "Elevation C" ;
                  page_num = 0 ;
                  pages.each {|page|
                  	if page.name == elev1
                  		pages.selected_page = model.pages[page_num] ;
                  		break
                  	end ;
                  	page_num+=1 ;
                  } #Pages.each
                  if page.name != "Elevation A"
                  targetX = x ;
                  targetY = y+camdist ;
                  targetZ = z ;
                  newTarget = Geom;;Point3d.new(targetX,targetY,targetZ)
                  elevACam = view.camera
                  elevACam.set(newEye,newTarget,newUp)
                  view.camera = elevACam
                  view.invalidate()
                  camera.perspective = true ;
                  camera.perspective = false ;
                  page = pages.selected_page.update(1) ;
                  page_num = 0 ;
                  pages.each {|page|
                  	if page.name == elev2
                  		break
                  	end ;
                  	page_num+=1 ;
                  } #Pages.each
                  if page.name != "Elevation B"
                  targetX = x+camdist ;
                  targetY = y ;
                  targetZ = z ;
                  elevBCam = view.camera
                  elevBCam.set(newEye,newTarget,newUp)
                  view.camera = elevBCam
                  view.invalidate()
                  page_num = 0 ;
                  pages.each {|page|
                  	if page.name == elev3
                  		break
                  	end ;
                  	page_num+=1 ;
                  } #Pages.each
                  if page.name != "Elevation D"
                  targetX = x-camdist ;
                  targetY = y ;
                  targetZ = z ;
                  view.invalidate()
                  page_num = 0 ;
                  pages.each {|page|
                  	if page.name == elev4
                  		break
                  	end ;
                  	page_num+=1 ;
                  } #Pages.each
                  if page.name != "Elevation C"
                  targetX = x ;
                  targetY = y-camdist ;
                  targetZ = z ;
                  view.invalidate()
                  page_num = 0 ;
                  pages.each {|page|
                  		break
                  	end ;
                  	page_num+=1 ;
                  } #Pages.each
                  Important to realize that the above code is just a sketch which still needs to be polish but it offers an idea of the progress. Also I post it so that if anyone spots something that I can improve then please by all means let me know.
                  If you want to test this its important to do the following;
                  1. Crete group to serve as a marker
                  2. Right click that group and pick "Entity info"
                  3. Under Name enter "Camera"
                  4. Open "Ruby Code Editor" plugin
                  5. Copy & Paste the above code I provided to "Ruby Code Editor"
                  6. Execute Code
                  7. Done!
                  Anyways hope to keep working on this so I can finish and make Beta rb file...Cheers!
                    I have PM'd a 2013 compliant version of my tool 'TIG-ElevTag' to some of you for beta-testing...
                    All comments welcome [by PM] before it gets published...
                      Are you gonna publish it how i think you're gonna publish it?
                        NO.
                        I await beta-test results...
                        I'll send you a copy - to test πŸ˜•
                          renderiza
                          TIG is upcoming plugin looks very good! I might still finish my attempt to make plugin but only for learning purpose. (Hope to be as good as TIG one day) πŸ’š
                          Cheers!
                            Krisidious
                            @renderiza said:
                            Cheers!
                            He's a talented guy no doubt. I still want to see what you came up with too Renderiza.
                            By: Kristoff Rand
                              sepo
                              Hi Tig
                              Any chance for me to test it?
                              Best
                              Sepo
                                KrisM
                                TIG or Rendriza,
                                Have you done anything further on your plugin? The need is certainly still out there.
                                KrisM
                                  Krisidious
                                  Here it is KrisM...
                                  SketchUp Plugins | PluginStore | SketchUcation
                                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                  (sketchucation.com)
                                  By: Kristoff Rand
                                    It's been in the PluginStore for ~16 months !
                                    πŸ˜’
                                      KrisM
                                      Krisidious,
                                      Thanks for the link.
                                      Tig,
                                      I am rather embarrassed here. I did do a search for your plugins but didn't go past the first page. Didn't realize your list is composed of four pages. Your output is prodigious and well appreciated.
                                      KrisM
                                        Krisidious
                                        He's pretty awesome... And sarcastic.
                                        By: Kristoff Rand
                                          I prefer to think of it as my 'dry wit' πŸ˜‰
                                            Krisidious
                                            Then it shall be known as such... In all my kingdoms... as far as the eye can see...
                                            By: Kristoff Rand
                                            • 2 / 3
