    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 7.0k Views 10 Watching
    • renderizaR
      renderiza
      The name is important since it will give a hint as to what the plugin do.
      "Marker Maker" - Is good
      "Elevation Maker" - Maybe good as well?
      Anyways no hurry for this but its nice to start exploring ideas. πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • KrisidiousK
        Krisidious
        Elevation Maker would be good if you can also make the exterior elevations... which would be an inversion of directions. The same marker is used for exterior parallel elevations.
        Easy Elevations?
        Interioriza?
        Elevation Tools?
        By: Kristoff Rand
        • CadFatherC
          CadFather
          sectionist πŸ˜†
          • BoxB
            Multi Elevation Set Point
              Late to the party...
              ElevTag - 1 direction == outside elev marker...
              ElevTag4 - 4 direction == room elev marker...
              That's what mine is called...
              Unpublished for personal use...
              • CadFatherC
                CadFather
                camera samurai
                • KrisidiousK
                  Krisidious
                  You already have something that does this Tig?
                  By: Kristoff Rand
                  • renderizaR
                    renderiza
                    Maybe TIG already have this but just in case here is some initial progress into making this plugin happen.
                    The following code is only purpose is to position camera to the center of a group (in this case the marker with arrows). The way the code filters other groups is by name so in this case I am naming the group "Camera".
                    model = Sketchup.active_model ;
                    sel = model.selection ;
                    ents = model.active_entities ;
                    groups = ents.grep(Sketchup;;Group)
                    groups.each do |e|
                      if e.name == "Camera"
                        boundbox = e.bounds ;
                        @center = boundbox.center ;
                      end ;
                    end ;
                    view = Sketchup.active_model.active_view ;
                    x = @center.x.to_f ;
                    y = @center.y.to_f ;
                    z = 50 ;
                    newEye = Geom;;Point3d.new(x,y,z) ;
                    targetX = 0.0 if !targetX ;
                    targetY = 0.0 if !targetY ;
                    targetZ = 50.0 if !targetZ ;
                    newTarget = Geom;;Point3d.new(targetX,targetY,targetZ)
                    newUp = Geom;;Vector3d.new(0,0,1)
                    newCamera = view.camera
                    newCamera.set(newEye,newTarget,newUp)
                    view.camera = newCamera
                    view.invalidate()
                    There is still a lot of things to but just want to post some progress code. This is just testing code that you may use with "Ruby Code Editor" to see results.
                    Cheers!
                    • CadFatherC
                      CadFather
                      woudn't it be more useful to actually click on the position required? (cheddar walls)
                      • KrisidiousK
                        Krisidious
                        yes that will be necessary. like 5 or more of these will be needed per plan... and rooms will never be in the same location.
                        By: Kristoff Rand
                        • renderizaR
                          renderiza
                          What you suggested can be done no problem but having the ability to place a marker will provide visual reference which is good. Maybe you can click where you want to position camera and also place markers at the same time.
                          Cheers!
                          • OxerO
                            Oxer
                            Are you probe CubicPanoOut? You can free downloading it here CubicPanoOut.rb
                            The plugin create six Views/Scenes-->Front, Right, Left, Back, Up and Down and you have the possibility to save the six images with size option.
                            With the Place Camera SU Tool, put the camera for example in the center of a room and automatically the CubicPanoOut generate the six Views/Scenes.
                            The problem is that the images generates are square, same width & height but you can go to File/Export/2D Graphic and save the image in the size that you want.
                            • KrisidiousK
                              Krisidious
                              I'll have a look at it.
                              By: Kristoff Rand
                                sepo
                                We are talking about sections here rather than elevations, right? Elevations would just show internal orthogonal views and sections would cut through the walls.
                                Surely that would be awesome tool to have.
                                • KrisidiousK
                                  Krisidious
                                  In drafting we just call them elevations, but yes it is a section and in SU a section would be used to accomplish it. having the walls on either side cut out would be good. However, I have seen architects and designers show varying methods of showing them. some don't show any walls past the interior surface, some show the section of the wall, floor and roof/ceiling...
                                  By: Kristoff Rand
                                    sepo
                                    If you are showing design only than cut walls could be omitted, but if you are preparing working drawings than one would show cut walls. In any case I always show cut walls as they convey idea of proximity of windows /doors to the floor/ceiling.
                                    So idea of this plugin is really advanced section tool. That would save a lot of time if possible to implement, so +1 from me.
                                    • renderizaR
                                      renderiza
                                      Here is an update of what I have done so far;
                                      #########Guide
                                      # camdist = 80*12
                                      # Elavation A (Front) = x , y+camdist
                                      # Elavation B (Right) = x+camdist , y
                                      # Elavation D (Left)  = x-camdist , y
                                      # Elavation C (Back)  = x , y-camdist
                                      view = model.active_view ;
                                      camera = view.camera ;
                                      pages = model.pages ;
                                      page = pages.selected_page
                                      groups.each do |e|
                                        end ;
                                      end ;
                                      z = 6*12 ;
                                      camdist = 80*12
                                      if page == nil
                                      pages.add "Elevation A"
                                      pages.add "Elevation B"
                                      pages.add "Elevation C"
                                      pages.add "Elevation D"
                                      elev1 = "Elevation A" ;
                                      elev2 = "Elevation B" ;
                                      elev3 = "Elevation D" ;
                                      elev4 = "Elevation C" ;
                                      page_num = 0 ;
                                      pages.each {|page|
                                      	if page.name == elev1
                                      		pages.selected_page = model.pages[page_num] ;
                                      		break
                                      	end ;
                                      	page_num+=1 ;
                                      } #Pages.each
                                      if page.name != "Elevation A"
                                      targetX = x ;
                                      targetY = y+camdist ;
                                      targetZ = z ;
                                      elevACam = view.camera
                                      elevACam.set(newEye,newTarget,newUp)
                                      view.camera = elevACam
                                      view.invalidate()
                                      camera.perspective = true ;
                                      camera.perspective = false ;
                                      page = pages.selected_page.update(1) ;
                                      page_num = 0 ;
                                      pages.each {|page|
                                      	if page.name == elev2
                                      		break
                                      	end ;
                                      	page_num+=1 ;
                                      } #Pages.each
                                      if page.name != "Elevation B"
                                      targetX = x+camdist ;
                                      targetY = y ;
                                      targetZ = z ;
                                      elevBCam = view.camera
                                      elevBCam.set(newEye,newTarget,newUp)
                                      view.camera = elevBCam
                                      view.invalidate()
                                      page_num = 0 ;
                                      pages.each {|page|
                                      	if page.name == elev3
                                      		break
                                      	end ;
                                      	page_num+=1 ;
                                      } #Pages.each
                                      if page.name != "Elevation D"
                                      targetX = x-camdist ;
                                      targetY = y ;
                                      targetZ = z ;
                                      view.invalidate()
                                      page_num = 0 ;
                                      pages.each {|page|
                                      	if page.name == elev4
                                      		break
                                      	end ;
                                      	page_num+=1 ;
                                      } #Pages.each
                                      if page.name != "Elevation C"
                                      targetX = x ;
                                      targetY = y-camdist ;
                                      targetZ = z ;
                                      view.invalidate()
                                      page_num = 0 ;
                                      pages.each {|page|
                                      		break
                                      	end ;
                                      	page_num+=1 ;
                                      } #Pages.each
                                      Important to realize that the above code is just a sketch which still needs to be polish but it offers an idea of the progress. Also I post it so that if anyone spots something that I can improve then please by all means let me know.
                                      If you want to test this its important to do the following;
                                      1. Crete group to serve as a marker
                                      2. Right click that group and pick "Entity info"
                                      3. Under Name enter "Camera"
                                      4. Open "Ruby Code Editor" plugin
                                      5. Copy & Paste the above code I provided to "Ruby Code Editor"
                                      6. Execute Code
                                      7. Done!
                                      Anyways hope to keep working on this so I can finish and make Beta rb file...Cheers!
                                        I have PM'd a 2013 compliant version of my tool 'TIG-ElevTag' to some of you for beta-testing...
                                        All comments welcome [by PM] before it gets published...
                                          Are you gonna publish it how i think you're gonna publish it?
                                            NO.
                                            I await beta-test results...
                                            I'll send you a copy - to test πŸ˜•
                                            • 2 / 3
