    SketchUp 2013 Pro and Make FAQs
    57 Posts 23 Posters 15.0k Views 23 Watching
      Just spotted this on the new SketchUp site which pretty much spells it out for those wondering and pondering about all the new 'things' in SU2013....
      http://help.sketchup.com/en/article/3000023
      From the new licensing system to the what is commercial work etc....
      I'll make this a global for a few days while members are transitioning to the new version.
      It's a long read but covers just about everything.
      • M
        Macker
        So they have an extension warehouse. .. but nothing much else?
        Check out my blog @ http://macviz.blogspot.co.uk
          There's a bit more here and there. Try the SketchUp 2013 thread Thomthom started. All the heavyweights are in there trading blows.
          Sent from my iPad
          • GarethG
            Gareth
            In that case, I'll be a lightweight, avoid injury, and stay in here until the dust settles..! πŸ˜†
            • thomthomT
              Wise move. I got too close to the action... πŸ‘Š
              • J
                jpalm32
                If you don't use Layout, not much there.
                • KrisidiousK
                  Krisidious
                  SketchUp
                  Extension Warehouse for Pro users.
                  Reworked toolbars menu and use with native custom toolbars.
                  Reworked UI
                  Show hidden lines for backside geometry.
                  here is a blog post about the upgrades to layout.
                  Error 404 (Not Found)!!1
                  (sketchupdate.blogspot.com)
                  By: Kristoff Rand
                  • J
                    jorge2011
                    en windows 7 64 bit , no veo las miniaturas de los archivos, y no veo ls miniaturas de las opciones de los componentes.
                    alguna ayuda?
                    windows 7 64 bit, I see the thumbnails of the files, and I see the thumbnails of the options of the components.
                    any help?
                    • TIGT
                      @jorge
                      You only get to see the preview if you have FULL seucurity permissions to your Plugins folder.
                      Otherwise the thumbnail image can't be written...
                      This is a know/reported issue... Trimble have been asked to fix it - it is a relatively straightforward fix.
                      It is always best if you have FULL permissions to your Plugins folder - it makes installing plugins etc MUCH easier...
                      To do this, first find you Plugins folder's icon in Windows Explorer.
                      then with Admin rights...
                      Select it
                      Right-click
                      Context-menu
                      Properties
                      Security
                      Edit...
                      ...make sure everyone listed has FULL permissions...
                      Apply/OK
                      That should now allow the creation of the thumbnail file that is written to the Plugins folder...
                      It's also a good idea to set the permissions to other Plugins folders that you might want to write to - like Components, Materials and Styles...
                      • J
                        jorge2011
                        Thank you very much. now works perfect.
                        And on thumbnails of the *. Skp? I can not see thumbnails of the *. skp in windows 64bit
                        is possible to solve this error?
                        • TIGT
                          This is not an error.
                          It is something built in to Windows 64bit.
                          Icons with images from 32bit applications, like SketchUp, do not display on 64bit PCs. 😞
                          There is fix - an inexpensive app called MysticThumbs will allow you to see previews of SKP files, and SKMs and much more... β˜€
                          http://mysticcoder.net/mysticthumbs.html
                          There are several threads on SCF discussing it...
                          Do a search...
                          • Dan RathbunD
                            Dan Rathbun
                            Missing from the What's New page or Change Log is the new right-click configurable Statusbar menu (on Windows at least.)
                            I'm not here much anymore.
                            • J
                              jorge2011
                              thank you very much.
                              Another query. Is possible to customize the toolbars which Plugins are downloaded from http://extensions.sketchup.com/?
                              • Dan RathbunD
                                Dan Rathbun
                                @jorge2011 said:
                                Is it possible to customize the Ruby toolbars of Plugins, which are downloaded from http://extensions.sketchup.com/ ?
                                NO, not in this first release of SketchUp 2013.
                                ADD: There is a plugin that can do this: [url=http://sketchucation.com/forums/viewtopic.php?p=470810#p470810:1ankxah2]Toolbar Editor (by Aerilius)[/url:1ankxah2]
                                • J
                                  jorge2011
                                  Another query. There are some open post sobe to review this new version of sketchup 2013?
                                  • jgbJ
                                    jgb
                                    So far as I have read in this and other posts, as well as Trimbles blogs and info,
                                    there seems to be NO (I repeat} NO real benefit to 2013 Make (Free Equivalent??) versus SU V8 Free.
                                    All the talk is about Pro and Layout. πŸ˜’
                                    In Trimbles' own description of the Make version, it very soon turns to Pro and Layout features. The only clear differentiation between Make and Free from Trimble is the Commercial Use restrictions, and this was obviously written by a lawyer, not an SU user/developer.
                                    So can anyone please list the improvements that 2013 has over V8, and NOT ONCE mention Pro or Layout?
                                    jgb
                                      new icons, toolbar chaos fixed, better exporters/importers
                                      • jgbJ
                                        jgb
                                        If that's it, then Big Whop
                                        But what do you want for free, eh? 🀣
                                        jgb
                                        • KrisidiousK
                                          Krisidious
                                          free has been restricted more in 13...
                                          By: Kristoff Rand
                                            Does the 2013 version PRO / MAKE has an option "save as" V6, v7, v8... ?
                                            • 1 / 3
