    SketchUp 2013 Pro and Make FAQs
    57 Posts 23 Posters 13.6k Views 23 Watching
    • TIGT Online
      @jorge
      You only get to see the preview if you have FULL seucurity permissions to your Plugins folder.
      Otherwise the thumbnail image can't be written...
      This is a know/reported issue... Trimble have been asked to fix it - it is a relatively straightforward fix.
      It is always best if you have FULL permissions to your Plugins folder - it makes installing plugins etc MUCH easier...
      To do this, first find you Plugins folder's icon in Windows Explorer.
      then with Admin rights...
      Select it
      Right-click
      Context-menu
      Properties
      Security
      Edit...
      ...make sure everyone listed has FULL permissions...
      Apply/OK
      That should now allow the creation of the thumbnail file that is written to the Plugins folder...
      It's also a good idea to set the permissions to other Plugins folders that you might want to write to - like Components, Materials and Styles...
        jorge2011
        Thank you very much. now works perfect.
        And on thumbnails of the *. Skp? I can not see thumbnails of the *. skp in windows 64bit
        is possible to solve this error?
        • TIGT Online
          This is not an error.
          It is something built in to Windows 64bit.
          Icons with images from 32bit applications, like SketchUp, do not display on 64bit PCs. 😞
          There is fix - an inexpensive app called MysticThumbs will allow you to see previews of SKP files, and SKMs and much more... β˜€
          http://mysticcoder.net/mysticthumbs.html
          There are several threads on SCF discussing it...
          Do a search...
          • Dan RathbunD Offline
            Dan Rathbun
            Missing from the What's New page or Change Log is the new right-click configurable Statusbar menu (on Windows at least.)
            I'm not here much anymore.
              jorge2011
              thank you very much.
              Another query. Is possible to customize the toolbars which Plugins are downloaded from http://extensions.sketchup.com/?
                Dan Rathbun
                @jorge2011 said:
                Is it possible to customize the Ruby toolbars of Plugins, which are downloaded from http://extensions.sketchup.com/ ?
                NO, not in this first release of SketchUp 2013.
                ADD: There is a plugin that can do this: [url=http://sketchucation.com/forums/viewtopic.php?p=470810#p470810:1ankxah2]Toolbar Editor (by Aerilius)[/url:1ankxah2]
                  jorge2011
                  Another query. There are some open post sobe to review this new version of sketchup 2013?
                  • jgbJ Offline
                    jgb
                    So far as I have read in this and other posts, as well as Trimbles blogs and info,
                    there seems to be NO (I repeat} NO real benefit to 2013 Make (Free Equivalent??) versus SU V8 Free.
                    All the talk is about Pro and Layout. πŸ˜’
                    In Trimbles' own description of the Make version, it very soon turns to Pro and Layout features. The only clear differentiation between Make and Free from Trimble is the Commercial Use restrictions, and this was obviously written by a lawyer, not an SU user/developer.
                    So can anyone please list the improvements that 2013 has over V8, and NOT ONCE mention Pro or Layout?
                    jgb
                      new icons, toolbar chaos fixed, better exporters/importers
                      • jgbJ Offline
                        jgb
                        If that's it, then Big Whop
                        But what do you want for free, eh? 🀣
                        jgb
                        • KrisidiousK Offline
                          Krisidious
                          free has been restricted more in 13...
                          By: Kristoff Rand
                            Does the 2013 version PRO / MAKE has an option "save as" V6, v7, v8... ?
                            • BoxB Offline
                              Yep
                                Thx! Cool ! πŸ˜„
                                a list of them for MAKE?
                                Seems STL Import export is integrated ?
                                  Create Dynamic Components are not yet allowed in SU MAKE?
                                    Dan Rathbun
                                    This has always been a Pro only feature.
                                      Thx for the info, but it's a pity, if yes that will boost the DC who have not the succes that they merit! πŸ˜„
                                        Dan Rathbun
                                        New for SU 2013... the SelectionTool is now the default tool, by popular demand.
                                        (In previous versions the default tool was the LineTool.)
                                        • Wo3DanW Offline
                                          Wo3Dan
                                          Let's hope this is a final decision.
                                          You preferably enter a room (workspace) with a toolbox full of tools, to see what needs to be done, not with some tool in your hands.
                                          • jgbJ Offline
                                            jgb
                                            WOW, that means I can finally eliminate Startup.rb. A God-Send from the Sketchup folks. β˜€
                                            I only asked for this when I first started using SU, back in 2005. Others before me, hence Startup.rb was there when I first posted.
                                            8 years........ musta used a whole development team with prototyping s/w to fix that.
                                            OR, maybe someone at Trimble actually uses SU and stuck a needle up someones butt to fix that.
                                            I'm staying 8. πŸ˜’
                                            jgb
                                            • 1 / 3
