    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 779.7k Views 143 Watching
      carlosmgilp
      Hi, thanks for your response.
      Here I attach the file.
      It's part of a building outline, so it won't have curves, but it's a green area.
      Prueba toposharpe.skp
        Roesmana Newcomers
        @menes said:
        Hello,
        I need help!
        I'm puzzled and I can't get on top of this issue
        this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
        I attach some files maybe someone understands what's going on
        thanks, everybody will be going to help
        Alberto
        • V Offline
          vexxejr Newcomers
          I am looking at generating complex surfaces from 3d contours, which have a height difference of 0.3m. I notice on videos that the grid size seems to have a max, what is the max for the grid size to be? and will it give me the granularity to show contours 0.3m apart, across a model which could be 1km wide.
            @vexxejr said:
            ... will it give me the granularity to show contours 0.3m apart, across a model which could be 1km wide.
            Your profile says you are using SketchUp 2023 Free/Make which indicates you are using the free web-based version. That version of SketchUp doesn't have any options for running extensions. You'll need SketchUp Pro.
            • W Offline
              walesle
              Hi I just purchased this extension today and am trying to use it but for some reason it is inserting random outliers into my point cloud. I am viewing hidden geometry and have no clue why it is inserting random peaks and dips into my fairly level terrain. I attached the SketchUp file.
              23.10.02_Gragg.skp
                What roundness and smoothness values are you using?`
                https://i.imgur.com/bcmJFQl.png
                It can affect the final output so its best to experiment. Especially points clouds that have uneven didtribution.
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: TopoShaper v2.7a - 01 Apr 24
                  Requirements:
                  • LibFredo6 v14.3b
                  • Sketchucation Plugintore v4.4.0
                  TopoShaper 2.6a is a maintenance release for
                  • Future compatibility
                  Home Page of TopoShaper for information and Download.
                  Main post of this TopoShaper thread.
                  • O Offline
                    orhanskr
                    How i can purchase this plugin ?
                      SketchUcation | List of Plugin Licences
                      (sketchucation.com)
                      If you are purchasing from Turkey you will need to use Stripe as PayPal is not accepted in Turkey
                      • E Offline
                        Einstein
                        Hey, Fredo, a little theoretical question about terrain generation from point cloud:
                        What was the mathematical foundation for the terrain mesh upsampling / interpolation algorithm? I mean the tool which increases the mesh density and smooths it, preserving the exact positions of input vertices, as we add iterations. Was it the butterfly subdivision algorithm? Have you used any specific paper to create this tool, or did you come up with the meshing algorithm yourself? I'm asking because I'm looking for something similar for Blender. I know, however, that butterfly subdivision is available in MeshLab, and it does more-less what Topo Shaper does. Besides that, I'm really just curious.
                        fredo6F 1 Reply Last reply Reply Quote 0
                        • fredo6F Offline
                          fredo6 @Einstein
                          @Einstein
                          It's home made. I wrote it long time ago, but I remember that for the interpolation, I did not find anything suitable and usable for my level of math in the literature.
                          For the upsampling of the triangulation, I remember that I tried the Steiner refinement approach, but it did not work well for what I wanted to do. So, I built my own method.
                          I was not familiar with the butterfly subdivision algorithm and still am not. Maybe it is a more conventional approach.
                          E 1 Reply Last reply Reply Quote 1
                            BeyondSpace Newcomers
                            Hi, can you tell me whether we can use toposhaper for a terrain that uses both contours and cloud points (spot levels) together?
                            • fredo6F Offline
                              fredo6
                              No. At the moment, it is isocontours OR cloud points. You can simulate a few cloud points by small circular contours.
                                Thanks Fredo6
                                • E Offline
                                  Einstein @fredo6
                                  @fredo6 It's a late reply from me, but thanks for the explanation. I'm honestly impressed you built the algorithm from scratch!
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE: TopoShaper v2.7b - 30 Jan 26
                                    Requirements:
                                    • LibFredo6 v14.3b
                                    • Sketchucation Plugintore v5.0.5
                                    TopoShaper 2.7b is a maintenance release for
                                    • Repackaging of rbz
                                    • 19
                                    • 20
                                    • 21
                                    • 22
                                    • 23
                                    • 23 / 23
