    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.6k Views 144 Watching
    • W
      walesle
      Hi I just purchased this extension today and am trying to use it but for some reason it is inserting random outliers into my point cloud. I am viewing hidden geometry and have no clue why it is inserting random peaks and dips into my fairly level terrain. I attached the SketchUp file.
      23.10.02_Gragg.skp
        What roundness and smoothness values are you using?`
        https://i.imgur.com/bcmJFQl.png
        It can affect the final output so its best to experiment. Especially points clouds that have uneven didtribution.
        • fredo6F
          NEW RELEASE: TopoShaper v2.7a - 01 Apr 24
          Requirements:
          • LibFredo6 v14.3b
          • Sketchucation Plugintore v4.4.0
          TopoShaper 2.6a is a maintenance release for
          • Future compatibility
          Home Page of TopoShaper for information and Download.
          Main post of this TopoShaper thread.
          • O
            orhanskr
            How i can purchase this plugin ?
              SketchUcation | List of Plugin Licences
              (sketchucation.com)
              If you are purchasing from Turkey you will need to use Stripe as PayPal is not accepted in Turkey
              • E
                Einstein
                Hey, Fredo, a little theoretical question about terrain generation from point cloud:
                What was the mathematical foundation for the terrain mesh upsampling / interpolation algorithm? I mean the tool which increases the mesh density and smooths it, preserving the exact positions of input vertices, as we add iterations. Was it the butterfly subdivision algorithm? Have you used any specific paper to create this tool, or did you come up with the meshing algorithm yourself? I'm asking because I'm looking for something similar for Blender. I know, however, that butterfly subdivision is available in MeshLab, and it does more-less what Topo Shaper does. Besides that, I'm really just curious.
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @Einstein
                  @Einstein
                  It's home made. I wrote it long time ago, but I remember that for the interpolation, I did not find anything suitable and usable for my level of math in the literature.
                  For the upsampling of the triangulation, I remember that I tried the Steiner refinement approach, but it did not work well for what I wanted to do. So, I built my own method.
                  I was not familiar with the butterfly subdivision algorithm and still am not. Maybe it is a more conventional approach.
                  E 1 Reply Last reply
                  • B
                    BeyondSpace Newcomers
                    Hi, can you tell me whether we can use toposhaper for a terrain that uses both contours and cloud points (spot levels) together?
                    • fredo6F
                      No. At the moment, it is isocontours OR cloud points. You can simulate a few cloud points by small circular contours.
                      • B
                        Thanks Fredo6
                        • E
                          Einstein @fredo6
                          @fredo6 It's a late reply from me, but thanks for the explanation. I'm honestly impressed you built the algorithm from scratch!
                          • fredo6F
                            NEW RELEASE: TopoShaper v2.7b - 30 Jan 26
                            Requirements:
                            • LibFredo6 v14.3b
                            • Sketchucation Plugintore v5.0.5
                            TopoShaper 2.7b is a maintenance release for
                            • Repackaging of rbz
                              johnmcgahey
                              I update Toposhaper and now it doesn't work..... what happened?
                                Rich O Brien Moderator @johnmcgahey
                                Is your libfredo up todate too?
                                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                  johnmcgahey
                                  I wanted you to know that the latest Toposhaper version does not work on the new Mac OS version of Sketchup 26.2.242. I upgraded my sketchup and now Toposhaper does not work. I have another workstation with Sketchup version 26.1.257 and your version of Toposhaper still works.
                                  John McGahey, AIA
                                  • fredo6F
                                    Can you indicate which Mac you have (Intel or ARM) and run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp, as well as describe what does not work. Do you see the menu and toolbar, do you get error messages.
                                    I would also suggest that you open the Ruby console and leave it open when you close Sketchup. When you restart Sketchup, the console will open and show possible error messages.
                                    • 19
                                    • 20
                                    • 21
                                    • 22
                                    • 23
                                    • 23 / 23
