    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 764.0k Views 143 Watching
      You've got several groups nested with the loose geometry of the countours in the model. Explode the group representing the perimeter of the contours and cut the other stuff down at the bottom of the group out so the group only contains the geometry for your terrain. There's a lot of edges to deal with in the contours so be patient when you run TopoShaper. Might not hurt to simplify the contours first.
        titusbiao Newcomers
        Hello,
        I am now using Sketchup Pro 2021, with TopoShaper v2.6a. Following the instructions to TopoShaper::IsoContours, when I try to generate terrain as Step 4, SketchUp crashed! No matter the grid set as default 50x48, or 200x198, crashed all the same!
        I don't know why, and could anyone tell me if there is anything wrong?
        My file Topo.skp is here (uploaded to Microsoft OneDrive for download):
        https://1drv.ms/u/s!AvaTfkcj2ZSTijSdm9cz1fsnQNFr?e=gUdSXs
        Please help and many thanks!
          Try tidying up the border to help Toposhaper create a mesh...
          https://i.imgur.com/8s0IPHU.png
          Topo-sk8.skp
          I removed your outline and some pointless small edges and the BugSplat stops.
          I also moved your raw geometry onto the default layer rather than your major/minor layers
            titusbiao Newcomers
            Hello Rich O Brien,
            Many thanks for your help.
            The Topo-sk8.skp works well with toposhaper v2.6a in SketchUp 2021 (Win10).
            I have tried some other skp files and find that if the geometry is rectangle, no errors will occur.
            So I guess that there might be 2 situations for toposhaper smoothly running without errors:
            1. the geometry is better in rectangle --- at least not too much acute or obtuse angles;
            2. Not too much tiny contour lines near the edge of the geometry.
              Is that true?
            Many thanks again!
            [attachment=0:3akutcq8]<!-- ia0 -->Topo-sk8.skp<!-- ia0 -->[/attachment:3akutcq8]
            • fredo6F Offline
              fredo6
                Is that true?
              Correct. You do not need too many contours, or too detailed contours, because TopoShaper is interpolating.
              When the terrain has an irregular contour, you may also get artefacts, because TopoShaper is based on quads.
              • volpino170790V Offline
                volpino170790
                Hi !
                I have a problem with TopoShaper
                Buttons don't appear and if the terrain geometry is not at the top level, it crashes.
                I've had this problem before with other files.
                Lib Fredo6 13.4a
                Toposhaper 2.6a
                I send a picture and a file
                https://i.goopics.net/800/ck230g.jpg
                Thank's !
                2.1878.skp
                  Works fine for me...
                  https://i.imgur.com/iw9dhgV.png
                  • fredo6F Offline
                    fredo6
                    It works for me too.
                    Could you open the Ruby Console before launching TopoShaper to see if there are error messages displayed.
                      volpino170790
                      Hi !
                      Here a link for a video
                      https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
                      Error in console
                      https://i.goopics.net/800/pj3gjq.jpg
                        volpino170790
                        Hi!
                        I all uninstall my extensions (just not uninstall 3dxSketchUp and the Sketchup extensions from sketchup) and reinstall this:
                        • LibFredo6, then close and reopen the file
                        • Toposhaper, then close and reopen the file
                        • Scf licence manager, then close and reopen the file
                        https://i.goopics.net/800/uhkap9.jpg
                        It is solved, but no idea why πŸ˜•
                        I think there is a conflict between Fredo 6 and an other extension but which one... THAT the question πŸ˜†
                        A video belove:
                        Share Anything with pCloud
                        With pCloud's unique Download Link feature you can share files with everyone. Click to download. Join pCloud.com and get up to 20GB FREE cloud storage.
                        pCloud (e1.pcloud.link)
                          volpino170790
                          Hi!
                          I think I've find the extension it cause a Bug
                          CleanUp3 3.4.3
                          I install juste TT lib, I test to make a terrain, no problem
                          I installCleanUp3 3.4.3, I test to make a terrain, problem with toposhaper
                          I uninstallCleanUp 3 3.4.3, I test to make a terrain, problem with toposhaper
                          I uninstallTT lib, I test to make a terrain, problem with toposhaper
                          I uninstallToposhaper and reinstall it, I test to make a terrain and it work great.
                          --> TT lib and CleanUp3 can cause issues
                          Before install TTLib and Cleanup3
                          https://i.goopics.net/800/ia4rm8.jpg
                          After install, but before close and reload the file
                          https://i.goopics.net/800/zv75yd.jpg
                          After reopen the file and test a terrain
                          https://i.goopics.net/800/vdylah.jpg
                          This time it's ok, but 5 minutes ago it didn't work... No idea
                          And I've make the same install 😲
                          I install Fredo6 Push Pull:
                          https://i.goopics.net/800/ucpyqz.jpg
                          and I close the file and reopen it:
                          https://i.goopics.net/800/vovqfk.jpg
                          and I test terrain Toposhaper:
                          https://i.goopics.net/800/4arqc1.jpg
                          • fredo6F Offline
                            fredo6
                            @volpino170790
                            Could you install LibFredo6 v13.5a to see if this improves the situation.
                              volpino170790
                              Hi!
                              It seems to be the LibFredo6 because (apart from basic SketchUp extensions) I only installed Fredo6 extensions and the bug occurs.
                              However, sometimes it resolves itself and the Toposhaper toolbar appears.
                              I haven't been able to find a routine that produces the bug for sure.
                              After installing Curviloft (same message as after installing FredoTools)
                              https://i.goopics.net/800/u2cqe8.jpg
                              https://i.goopics.net/800/sfevdc.jpg
                              Since installing version 13.5a, the bug no longer seems to occur but
                              there are always error messages for installations of extensions requiring a Fredo6 license.
                              After install of FredoSpline:
                              https://i.goopics.net/800/uyhh8m.jpg
                              Thanks a lot for your speed react πŸ˜„ πŸ˜„ πŸ˜„
                                shirokostup
                                hi. I'm in Russia now, PayPal is blocked here. I need a TopoShaper. How can I pay?
                                  atoney
                                  6132023.JPGHi..I purchased the toposhaper plugin. Installed and works..but I dont see the tool bar for it. I have to access it via the Menu bar? Can u suggest a solution?
                                  Atoney
                                    Did you restart SketchUp after installation?
                                    Fredo's tools are comprehensive and some need a restart.
                                    If you right click your toolbar zone is Topshaper checked?
                                      Make sure you have the current version of LibFredo6 and the Sketchucation ExtensionStore tool installed. Then quit and restart SketchUp.
                                        carlosmgilp
                                        Hello how are you.
                                        Is there a way to complete the mesh?
                                        It is that sometimes it has happened to me that it does not fully reach the edges.
                                        In this example, the top corner doesn't quite reach the edge.
                                          carlosmgilp
                                          Hello how are you.
                                          Any help, I would appreciate it.
                                          Selected contour
                                          Plan view
                                          • fredo6F Offline
                                            fredo6
                                            @carlosmgilp said:
                                            Hello how are you.
                                            Would you have the model so that I can have a look.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
