    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • volpino170790V
      volpino170790
      Hi !
      Here a link for a video
      https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
      Error in console
      https://i.goopics.net/800/pj3gjq.jpg
      • volpino170790V
        volpino170790
        Hi!
        I all uninstall my extensions (just not uninstall 3dxSketchUp and the Sketchup extensions from sketchup) and reinstall this:
        • LibFredo6, then close and reopen the file
        • Toposhaper, then close and reopen the file
        • Scf licence manager, then close and reopen the file
        https://i.goopics.net/800/uhkap9.jpg
        It is solved, but no idea why πŸ˜•
        I think there is a conflict between Fredo 6 and an other extension but which one... THAT the question πŸ˜†
        A video belove:
        Share Anything with pCloud
        With pCloud's unique Download Link feature you can share files with everyone. Click to download. Join pCloud.com and get up to 20GB FREE cloud storage.
        pCloud (e1.pcloud.link)
        • volpino170790V
          volpino170790
          Hi!
          I think I've find the extension it cause a Bug
          CleanUp3 3.4.3
          I install juste TT lib, I test to make a terrain, no problem
          I installCleanUp3 3.4.3, I test to make a terrain, problem with toposhaper
          I uninstallCleanUp 3 3.4.3, I test to make a terrain, problem with toposhaper
          I uninstallTT lib, I test to make a terrain, problem with toposhaper
          I uninstallToposhaper and reinstall it, I test to make a terrain and it work great.
          --> TT lib and CleanUp3 can cause issues
          Before install TTLib and Cleanup3
          https://i.goopics.net/800/ia4rm8.jpg
          After install, but before close and reload the file
          https://i.goopics.net/800/zv75yd.jpg
          After reopen the file and test a terrain
          https://i.goopics.net/800/vdylah.jpg
          This time it's ok, but 5 minutes ago it didn't work... No idea
          And I've make the same install 😲
          I install Fredo6 Push Pull:
          https://i.goopics.net/800/ucpyqz.jpg
          and I close the file and reopen it:
          https://i.goopics.net/800/vovqfk.jpg
          and I test terrain Toposhaper:
          https://i.goopics.net/800/4arqc1.jpg
          • fredo6F
            @volpino170790
            Could you install LibFredo6 v13.5a to see if this improves the situation.
            • volpino170790V
              volpino170790
              Hi!
              It seems to be the LibFredo6 because (apart from basic SketchUp extensions) I only installed Fredo6 extensions and the bug occurs.
              However, sometimes it resolves itself and the Toposhaper toolbar appears.
              I haven't been able to find a routine that produces the bug for sure.
              After installing Curviloft (same message as after installing FredoTools)
              https://i.goopics.net/800/u2cqe8.jpg
              https://i.goopics.net/800/sfevdc.jpg
              Since installing version 13.5a, the bug no longer seems to occur but
              there are always error messages for installations of extensions requiring a Fredo6 license.
              After install of FredoSpline:
              https://i.goopics.net/800/uyhh8m.jpg
              Thanks a lot for your speed react πŸ˜„ πŸ˜„ πŸ˜„
                shirokostup
                hi. I'm in Russia now, PayPal is blocked here. I need a TopoShaper. How can I pay?
                  atoney
                  6132023.JPGHi..I purchased the toposhaper plugin. Installed and works..but I dont see the tool bar for it. I have to access it via the Menu bar? Can u suggest a solution?
                  Atoney
                    Did you restart SketchUp after installation?
                    Fredo's tools are comprehensive and some need a restart.
                    If you right click your toolbar zone is Topshaper checked?
                      Make sure you have the current version of LibFredo6 and the Sketchucation ExtensionStore tool installed. Then quit and restart SketchUp.
                      • C
                        carlosmgilp
                        Hello how are you.
                        Is there a way to complete the mesh?
                        It is that sometimes it has happened to me that it does not fully reach the edges.
                        In this example, the top corner doesn't quite reach the edge.
                        • C
                          carlosmgilp
                          Hello how are you.
                          Any help, I would appreciate it.
                          Selected contour
                          Plan view
                          • fredo6F
                            @carlosmgilp said:
                            Hello how are you.
                            Would you have the model so that I can have a look.
                            • C
                              carlosmgilp
                              Hi, thanks for your response.
                              Here I attach the file.
                              It's part of a building outline, so it won't have curves, but it's a green area.
                              Prueba toposharpe.skp
                                Roesmana Newcomers
                                @menes said:
                                Hello,
                                I need help!
                                I'm puzzled and I can't get on top of this issue
                                this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
                                I attach some files maybe someone understands what's going on
                                thanks, everybody will be going to help
                                Alberto
                                • V
                                  vexxejr Newcomers
                                  I am looking at generating complex surfaces from 3d contours, which have a height difference of 0.3m. I notice on videos that the grid size seems to have a max, what is the max for the grid size to be? and will it give me the granularity to show contours 0.3m apart, across a model which could be 1km wide.
                                    @vexxejr said:
                                    ... will it give me the granularity to show contours 0.3m apart, across a model which could be 1km wide.
                                    Your profile says you are using SketchUp 2023 Free/Make which indicates you are using the free web-based version. That version of SketchUp doesn't have any options for running extensions. You'll need SketchUp Pro.
                                    • W
                                      walesle
                                      Hi I just purchased this extension today and am trying to use it but for some reason it is inserting random outliers into my point cloud. I am viewing hidden geometry and have no clue why it is inserting random peaks and dips into my fairly level terrain. I attached the SketchUp file.
                                      23.10.02_Gragg.skp
                                        What roundness and smoothness values are you using?`
                                        https://i.imgur.com/bcmJFQl.png
                                        It can affect the final output so its best to experiment. Especially points clouds that have uneven didtribution.
                                        • fredo6F
                                          NEW RELEASE: TopoShaper v2.7a - 01 Apr 24
                                          Requirements:
                                          • LibFredo6 v14.3b
                                          • Sketchucation Plugintore v4.4.0
                                          TopoShaper 2.6a is a maintenance release for
                                          • Future compatibility
                                          Home Page of TopoShaper for information and Download.
                                          Main post of this TopoShaper thread.
                                          • O
                                            orhanskr
                                            How i can purchase this plugin ?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
