    Vray sketchup: editor light
    renderpluginsextensions
    12 Posts 8 Posters 2.8k Views 8 Watching
      alefabio
      Hello everyone
      I just installed vray for sketchup 8 demo version, I nell'intefaccia window appears and vray plugin can also be seen in the "plugins" at the top then it means that the installation is successful.
      I can not, however, to change the values ​​of the intensity of light (any type of light) in the 'light editor, I can only enter 0 or -1 as you can?
      I tried to uninstall and rinstallare several times is that vray sketchup pro 8, but to no avail, the problem persists.
      I ask you to help!
      thank you very much
      • ToboboT Offline
        Tobobo
        @alefabio said:
        Hello everyone
        I ask you to help!
        thank you very much
        I would contact the customer support on the Chaos Website.
        Toby
        Philippians 4:13
        • broomstickB Offline
          broomstick
          Hi Alefabio, the problem is not very clear to me. You can contact me in private, and in italian, so I can help you better!
          trad: se hai bisogno di aiuto in italiano, contattami con un messaggio privato πŸ˜‰
            alefabio
            BROOMSTICK GRAZIE DELLA RISPOSTA..SCUSA MA NN RIESCO A TROVARE IL MODO DI CONTATTARTI PRIVATAMENTE..TI LASCIO LA MIA MAIL ...alessandratex@alice.it..graziee
            • massimoM Offline
              massimo Moderator
              Hi ale, if you want you can use the PM feature or post the question in the Italian section of the forum.
                broomstick
                I am responding here just for the sake of publishing a solution. Maybe it will be useful to others.
                The problem Ale had, was that she could not change intensity values in the vray light editor.
                This happens when you try to insert the value using a period like so: 4.00
                What you want to do is, instead, insert the value with a comma: 4,00
                Remember to click OK on the editor, and this value will be stored for the light you are modifying!
                Happy rendering πŸ˜„
                • V Offline
                  valerostudio
                  Not sure of his units settings but I use decimals (.) in all of my parameters with no problems. I have never seen anyone use commas (,)
                    broomstick
                    We do, here in Italy.
                    Periods are used for thousands: 1.000.000
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      Actually, most countries use commas as decimal marks.
                      Green : Comma
                      Blue : Full stop
                      http://i.imgur.com/6IcRRCG.png
                        rspierenburg
                        And the red just don't believe in punctuation? lol.
                          jiminy-billy-bob
                          They use something called "Momayyez".
                          • andybotA Offline
                            andybot
                            'murican...
                            (with a George W. inflection.) πŸ˜†
