    For the love of GOD.....!!!!!!
    20 Posts 11 Posters 1.7k Views 11 Watching
    • frascatiF
      frascati
      .....when you link to or announce a plugin, why is it so damn difficult just to give a heads-up as to where it is accessed after installation.
      This is so go@@amn frustrating that I want to pull hair.
      • jeff hammondJ
        jeff hammond
        lol
        (in the meantime.. any specific plugin you need help with locating?)
        dotdotdot
        • frascatiF
          frascati
          No I'm ok. But thanks. Just had to let off a bit-o-steam.
          • jeff hammondJ
            jeff hammond
            ha.. i hear you.. it's cool..
            fyi, if you're on mac by any chance, you can always use the help menu to find stuff.. just start typing in the plugin name and you'll be shown it's location in the menus..
            [example- can't locate Advanced Camera Tools... help menu then start typing 'camera'.. choose item when filtered down enough...(in this case, after the c&a were typed)
            and there it is.. under the tools menu.. not the camera menu.. duh πŸ˜‰
            dotdotdot
            • KrisidiousK
              Krisidious
              And if you're on a PC Jeff just rubbed it in really good...
              By: Kristoff Rand
              • thomthomT
                You can always use the Shortcut list, regardless of OS.
                • jeff hammondJ
                  jeff hammond
                  ha.. i mean, it's ok and i'll use it occasionally (especially handy when learning a new app).. it works like a command line too in that you can launch tools from it using the keyboard.. i wouldn't call it a mindblowing feature though πŸ˜‰
                  maybe a little utility that does the same thing on windows? or maybe someone could do something with win32 & ruby which searches the sketchup menus like that?
                  [EDIT]
                  or maybe a ruby which ties in to the shortcuts info as shown by thomthom above.. but displays the info in a different way.. and let's you launch the tool?
                  i don't know.. (as in, i really don't know)
                  dotdotdot
                  • thomthomT
                    Problem is, you cannot get all this info easily with the Ruby API. You need to do some very dirty hacks in order to map the commands. I've done an experimental version a couple of years back, but never completed it because I'm afraid it'd cause too many issues.
                    • jeff hammondJ
                      jeff hammond
                      yeah.. doesn't seem worth it..
                      dotdotdot
                      • thomthomT
                        One "god" thing will be also
                        an image before / after ! β˜€
                        Numerous plugins have only texts some obscure, impenetrable, unintelligible, arcane for no native English speaker! πŸ˜’
                        +1
                        (I know, I need to be better at this.)
                          And thanks Jeff for the Duhduh of the day! 😎
                          I was too speed to read the Jeff's text! It's only for Mac πŸ’š
                          • A
                            Aerilius
                            I wonder why Google missed the chance of adding a searchable UI (that would have been the least they could have advanced SketchUp).
                            Imagine that means we could have an infinite amount of features accessible in a simple/limited UI (even on phone UIs etc.).
                            • soloS
                              solo
                              Ugh!! I was hoping this thread was a religious debate πŸ‘Ώ
                              http://www.solos-art.com
                                It is. It's about plugins and you are a disciple.
                                • thomthomT
                                  I doubt that...
                                  • gullfoG
                                    gullfo
                                    for windows - enable search index with the SU extensions on the sketchup folders and you can find components, material, plugins etc off the start menu.
                                    • make sure the SU directory has indexing enabled (properties->advanced)
                                    • in the index options control panel, advanced - add the rbz, skp, skm, etc extensions (rb if its not there), there is an option for content as well as file name, you choose...
                                    • in the index options control panel add the top level folder (or each one) and let it index...
                                    Glenn
                                    http://www.runnel.com
                                    • Wo3DanW
                                      Wo3Dan
                                      @thomthom said:
                                      I doubt that...
                                      Héhé..... Solo IS the Creator of ............ "the new Beast"..... 😲
                                      Ooops, new PC that is. 😳
                                      • A
                                        Aerilius
                                        I'm not exactly god (at least I'm not aware of),
                                        or maybe a ruby which […] let's you launch the tool?
                                        but someone must have animated me to make such a Ruby plugin (in January, even before this topic was started).
                                        See if the "LaunchUp" plugin search is helpful.
                                        • thomthomT
                                          Have you tried walking on water..?
                                          • PixeroP
                                            Pixero
                                            Anyone can walk on water...it just have to be below 0 degrees Celsius. πŸ˜’
