    For the love of GOD.....!!!!!!
    20 Posts 11 Posters 1.6k Views 11 Watching
    • jeff hammondJ Offline
      @thomthom said:
      Problem is, you cannot get all this info easily with the Ruby API. You need to do some very dirty hacks in order to map the commands. I've done an experimental version a couple of years back, but never completed it because I'm afraid it'd cause too many issues.
      yeah.. doesn't seem worth it..
        One "god" thing will be also
        an image before / after ! β˜€
        Numerous plugins have only texts some obscure, impenetrable, unintelligible, arcane for no native English speaker! πŸ˜’
        +1
        (I know, I need to be better at this.)
          And thanks Jeff for the Duhduh of the day! 😎
          I was too speed to read the Jeff's text! It's only for Mac πŸ’š
            Aerilius
            I wonder why Google missed the chance of adding a searchable UI (that would have been the least they could have advanced SketchUp).
            Imagine that means we could have an infinite amount of features accessible in a simple/limited UI (even on phone UIs etc.).
            • soloS Offline
              Ugh!! I was hoping this thread was a religious debate πŸ‘Ώ
                It is. It's about plugins and you are a disciple.
                  I doubt that...
                  • gullfoG Offline
                    gullfo
                    for windows - enable search index with the SU extensions on the sketchup folders and you can find components, material, plugins etc off the start menu.
                    • make sure the SU directory has indexing enabled (properties->advanced)
                    • in the index options control panel, advanced - add the rbz, skp, skm, etc extensions (rb if its not there), there is an option for content as well as file name, you choose...
                    • in the index options control panel add the top level folder (or each one) and let it index...
                    Glenn
                    http://www.runnel.com
                    • Wo3DanW Offline
                      Wo3Dan
                      @thomthom said:
                      I doubt that...
                      Héhé..... Solo IS the Creator of ............ "the new Beast"..... 😲
                      Ooops, new PC that is. 😳
                        Aerilius
                        I'm not exactly god (at least I'm not aware of),
                        or maybe a ruby which […] let's you launch the tool?
                        but someone must have animated me to make such a Ruby plugin (in January, even before this topic was started).
                        See if the "LaunchUp" plugin search is helpful.
                          Have you tried walking on water..?
                          • PixeroP Offline
                            Pixero
                            Anyone can walk on water...it just have to be below 0 degrees Celsius. πŸ˜’
