    Thickness Ruby to make shell?
    17 Posts 6 Posters 2.2k Views 6 Watching
    • marvins_dadM Offline
      marvins_dad
      I've been doing a lot of 3d printing lately. Mostly the volumes have been a modification of something or simple volume.
      I understand that in order to get the object to print properly it needs to have a completely closed volume.
      The question I have for you guys after searching and not finding a solution...
      Is there a ruby out there that will create an offset or "shell". I have a car shell that I am working on that I want to print as a 1/6" thick lightweight shell to attach to something else...similar to an RC car shell. The problem is that I have created the shape of the shell I want, but the programs won't simply print along a plane with zero thickness.
      Any ideas?
      antoine
      My Gallery
        Fredo's Joint Push Pull?
          marvins_dad
          I have that installed...will try it at lunch...initial attempt crashed the program, but maybe if I am more selective it might work.
          Thanks Rich
          My Gallery
          • dukejazzD Offline
            dukejazz
            My plugin will make a shell
            [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013 by dukejazz » May 11th, 2012, 3:36 pm
            Copyright Feb 15, 2013
            DukeJazz: by James Cochran
            has a tool call
            cumulativeScaler_dj (now dose xyz x y z scale,step and rotation)
            http://sketchucation.com/forums/viewtopic.php?f=323&t=45254&start=15
            • cottyC Offline
              cotty
              And there is Thomthoms shell plugin.
              my SketchUp gallery
                marvins_dad
                has a tool call
                [attachment=0:24ybdmor]<!-- ia0 -->pic_0127.jpg<!-- ia0 -->[/attachment:24ybdmor]
                I can't figure it out...all I have been able to do is an offset.
                Looking to basically create a 1/16" shell.
                My Gallery
                  marvins_dad
                  Looks perfect...but can't get it to do anything. 😞
                  My Gallery
                  • jeff hammondJ Offline
                    jeff hammond
                    Thanks Rich
                    did it crash or appear to hang?
                    if you're doing a processor intensive operation in sketchup, it may appear as if its not working.. but it is.
                    (for reference, I once did a jpp operation that took 4 hrs to calculate)
                    dotdotdot
                    • gillesG Offline
                      gilles
                      works with groups or components, did you try on raw geometries?
                        marvins_dad
                        Thanks Rich
                        I get a "SketchUp Application has stopped working" dialog box...only options are check online and close or close program. Problem signature:...APPCRASH
                        My Gallery
                          marvins_dad
                          I was trying with raw geometries...I'll try with a group...are you talking about "Shell"?
                          My Gallery
                            marvins_dad
                            Shell seems to preview when I select a group and I can see the offset and adjust it. When I double click it doesn't stay...when I hit enter nothing happens. When I double click then click outside the group the offset disappears.
                            What am I doing wrong?
                            My Gallery
                            • gillesG Offline
                              gilles
                              I do.
                              • gillesG Offline
                                gilles
                                Adjust the fitness, then Enter, then double click.
                                  marvins_dad
                                  Okay - I tried on a portion that wasn't as complex and it worked.
                                  Looks like I need to simplify my model a bit (clean it up) and try again.
                                  Thanks!
                                  My Gallery
                                  • dukejazzD Offline
                                    dukejazz
                                    I have a tool call cumulativeScaler_dj
                                    it's part of scaleGroupFloat_dj package (doses cumulative xyz, x, y, z, scale,step,move and rotation)
                                    by marvins_dad » Yesterday, 12:08 pm
                                    I figure it for you.
                                    I found a car body on 3d warehouse
                                    and I work it 1/16 but it's not close yet for a volume
                                    car+body16_dj.skp
                                    • dukejazzD Offline
                                      dukejazz
                                      I rework it and now it's a closed shell volume:
                                      by these steps
                                      1. I started wuth the car body
                                      2. draw with line tool and close the volume
                                      3. I copy and offset scaled by 1/16 inch as before with scaleGroupFloat_dj
                                        scaleGroupFloat_dj will create an offset call "shell". the settings shown ealier above
                                      4 ) I then vector push-pull the wheels acoss
                                      5) right click and used context intersect face to model
                                      1. cut away
                                        and then cut the bottom interial face of the car
                                      by marvins_dad » February 27th, 2013, 9:36 am
                                      Is there a ruby out there that will create an offset or "shell". I have a car shell... 1/6" thick lightweight ... The problem is ... the programs won't simply print along a plane with zero thickness.
                                      and now marvins
                                      The Answer:
                                      yes- Use scaleGroupFloat_dj.rb
                                      and a vector push-pull tool
                                      (=to SU push-pull then one end exploded face move by the move tool)
                                      by the process above you get this
                                      car+body16_dj.skp
