    Thickness Ruby to make shell?
    17 Posts 6 Posters 2.1k Views 6 Watching
    • cottyC Offline
      cotty
      And there is Thomthoms shell plugin.
      my SketchUp gallery
      • marvins_dadM Offline
        marvins_dad
        @dukejazz said:
        My plugin will make a shell
        [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013 by dukejazz » May 11th, 2012, 3:36 pm
        Copyright Feb 15, 2013
        DukeJazz: by James Cochran
        has a tool call
        cumulativeScaler_dj (now dose xyz x y z scale,step and rotation)
        [attachment=0:24ybdmor]<!-- ia0 -->pic_0127.jpg<!-- ia0 -->[/attachment:24ybdmor]
        http://sketchucation.com/forums/viewtopic.php?f=323&t=45254&start=15
        I can't figure it out...all I have been able to do is an offset.
        Looking to basically create a 1/16" shell.
        My Gallery
          marvins_dad
          Looks perfect...but can't get it to do anything. 😞
          My Gallery
          • jeff hammondJ Offline
            @marvins_dad said:
            @rich o brien said:
            Fredo's Joint Push Pull?
            I have that installed...will try it at lunch...initial attempt crashed the program, but maybe if I am more selective it might work.
            Thanks Rich
            did it crash or appear to hang?
            if you're doing a processor intensive operation in sketchup, it may appear as if its not working.. but it is.
            (for reference, I once did a jpp operation that took 4 hrs to calculate)
            • gillesG Offline
              gilles
              works with groups or components, did you try on raw geometries?
                marvins_dad
                Thanks Rich
                I get a "SketchUp Application has stopped working" dialog box...only options are check online and close or close program. Problem signature:...APPCRASH
                My Gallery
                  marvins_dad
                  I was trying with raw geometries...I'll try with a group...are you talking about "Shell"?
                  My Gallery
                    marvins_dad
                    Shell seems to preview when I select a group and I can see the offset and adjust it. When I double click it doesn't stay...when I hit enter nothing happens. When I double click then click outside the group the offset disappears.
                    What am I doing wrong?
                    My Gallery
                    • gillesG Offline
                      gilles
                      I do.
                      • gillesG Offline
                        gilles
                        Adjust the fitness, then Enter, then double click.
                          marvins_dad
                          Okay - I tried on a portion that wasn't as complex and it worked.
                          Looks like I need to simplify my model a bit (clean it up) and try again.
                          My Gallery
                          • dukejazzD Offline
                            dukejazz
                            I have a tool call cumulativeScaler_dj
                            it's part of scaleGroupFloat_dj package (doses cumulative xyz, x, y, z, scale,step,move and rotation)
                            by marvins_dad » Yesterday, 12:08 pm
                            I figure it for you.
                            I found a car body on 3d warehouse
                            and I work it 1/16 but it's not close yet for a volume
                            car+body16_dj.skp
                            • dukejazzD Offline
                              dukejazz
                              I rework it and now it's a closed shell volume:
                              by these steps
                              1. I started wuth the car body
                              2. draw with line tool and close the volume
                              3. I copy and offset scaled by 1/16 inch as before with scaleGroupFloat_dj
                                scaleGroupFloat_dj will create an offset call "shell". the settings shown ealier above
                              4 ) I then vector push-pull the wheels acoss
                              5) right click and used context intersect face to model
                              1. cut away
                                and then cut the bottom interial face of the car
                              by marvins_dad » February 27th, 2013, 9:36 am
                              Is there a ruby out there that will create an offset or "shell". I have a car shell... 1/6" thick lightweight ... The problem is ... the programs won't simply print along a plane with zero thickness.
                              and now marvins
                              The Answer:
                              yes- Use scaleGroupFloat_dj.rb
                              and a vector push-pull tool
                              (=to SU push-pull then one end exploded face move by the move tool)
                              by the process above you get this
                              car+body16_dj.skp
