    Thickness Ruby to make shell?
    17 Posts 6 Posters 2.3k Views 6 Watching
      Fredo's Joint Push Pull?
      • marvins_dadM
        marvins_dad
        I have that installed...will try it at lunch...initial attempt crashed the program, but maybe if I am more selective it might work.
        Thanks Rich
        My Gallery
        • dukejazzD
          dukejazz
          My plugin will make a shell
          [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013 by dukejazz » May 11th, 2012, 3:36 pm
          Copyright Feb 15, 2013
          DukeJazz: by James Cochran
          has a tool call
          cumulativeScaler_dj (now dose xyz x y z scale,step and rotation)
          http://sketchucation.com/forums/viewtopic.php?f=323&t=45254&start=15
          • cottyC
            cotty
            And there is Thomthoms shell plugin.
            my SketchUp gallery
            • marvins_dadM
              marvins_dad
              has a tool call
              [attachment=0:24ybdmor]<!-- ia0 -->pic_0127.jpg<!-- ia0 -->[/attachment:24ybdmor]
              I can't figure it out...all I have been able to do is an offset.
              Looking to basically create a 1/16" shell.
              My Gallery
              • marvins_dadM
                marvins_dad
                Looks perfect...but can't get it to do anything. 😞
                My Gallery
                • jeff hammondJ
                  Thanks Rich
                  did it crash or appear to hang?
                  if you're doing a processor intensive operation in sketchup, it may appear as if its not working.. but it is.
                  (for reference, I once did a jpp operation that took 4 hrs to calculate)
                  • gillesG
                    gilles
                    works with groups or components, did you try on raw geometries?
                    • marvins_dadM
                      marvins_dad
                      Thanks Rich
                      I get a "SketchUp Application has stopped working" dialog box...only options are check online and close or close program. Problem signature:...APPCRASH
                      My Gallery
                      • marvins_dadM
                        marvins_dad
                        I was trying with raw geometries...I'll try with a group...are you talking about "Shell"?
                        My Gallery
                        • marvins_dadM
                          marvins_dad
                          Shell seems to preview when I select a group and I can see the offset and adjust it. When I double click it doesn't stay...when I hit enter nothing happens. When I double click then click outside the group the offset disappears.
                          What am I doing wrong?
                          My Gallery
                          • gillesG
                            gilles
                            I do.
                            • gillesG
                              gilles
                              Adjust the fitness, then Enter, then double click.
                              • marvins_dadM
                                marvins_dad
                                Okay - I tried on a portion that wasn't as complex and it worked.
                                Looks like I need to simplify my model a bit (clean it up) and try again.
                                My Gallery
                                • dukejazzD
                                  dukejazz
                                  I have a tool call cumulativeScaler_dj
                                  it's part of scaleGroupFloat_dj package (doses cumulative xyz, x, y, z, scale,step,move and rotation)
                                  by marvins_dad » Yesterday, 12:08 pm
                                  I figure it for you.
                                  I found a car body on 3d warehouse
                                  and I work it 1/16 but it's not close yet for a volume
                                  car+body16_dj.skp
                                  • dukejazzD
                                    dukejazz
                                    I rework it and now it's a closed shell volume:
                                    by these steps
                                    1. I started wuth the car body
                                    2. draw with line tool and close the volume
                                    3. I copy and offset scaled by 1/16 inch as before with scaleGroupFloat_dj
                                      scaleGroupFloat_dj will create an offset call "shell". the settings shown ealier above
                                    4 ) I then vector push-pull the wheels acoss
                                    5) right click and used context intersect face to model
                                    1. cut away
                                      and then cut the bottom interial face of the car
                                    by marvins_dad » February 27th, 2013, 9:36 am
                                    Is there a ruby out there that will create an offset or "shell". I have a car shell... 1/6" thick lightweight ... The problem is ... the programs won't simply print along a plane with zero thickness.
                                    and now marvins
                                    The Answer:
                                    yes- Use scaleGroupFloat_dj.rb
                                    and a vector push-pull tool
                                    (=to SU push-pull then one end exploded face move by the move tool)
                                    by the process above you get this
                                    car+body16_dj.skp
