    [Plugin] 3D Text Editor
    202 Posts 50 Posters 199.6k Views 49 Watching
      Matt, I hope this doesn't embarrass you further. Try using Enter between typing the letters. 😉 I setting Align to Center. You may need to play with the leading (spacing) between the letters after you've created the text but that will depend upon the font you choose.
      Edit: You edited your post while I was typing. 😄 Now you've got it and if anyone asked, it was a great day because you learned something. 👍
        matt.gordon320
        Haha no worries Dave. I've frequently found that publicly making a fool of myself is the best way to learn, and I'm ok with that 😄 I'm sure you experienced programmers will have a good laugh when I finally get around to releasing an actual plugin.
        • tt_suT Offline
          tt_su
          Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
          • ntxdaveN Offline
            ntxdave
            I really like the plugin but have a couple of things I would like for it to do (if possible):
            1. I would like for it to remember my selections (font, size, alignment, etc.) so that I do not have to go through the selections everytime.
            2. I would like to be able to specify the color (both face and outline if possible). In fact, it would be great if there was a way to eliminate the outline. I have a lot of text to enter in my model and it is a pain to go eliminate the outline all of the time.
            Press F1...thank me later
            • tt_suT Offline
              tt_su
              "Outline"?
                I suppose he means he's hiding the edges.
                @ntxdave, how is it that you current "eliminate the outline" on 3D text?
                • ntxdaveN Offline
                  ntxdave
                  Switch to wireframe style, Edit Component (the 3d text), select of the text, hide the text, then switch the style back to shaded with textures. This results with only the "face" of the text (if you colored it - which I do with the pain bucket tool).
                  While this works, it is a pain when you have a lot of text components in the model (which I do). Thus the desire to have the ability to do these additional things.
                  • halroachH Offline
                    halroach
                    1. This plugin's download needs updating on the first post. On the plugins store it's 1.1.3
                    FlexTools - Super Quick Windows, Doors, Slats...
                      Sorted.
                      • Bob JamesB Offline
                        Bob James
                        1. It already does (at least for me)
                        2. +1
                        • ntxdaveN Offline
                          ntxdave
                          2. +1
                          I just tried again on 2 different machines and #1 does not work for me. I really wish it did. I have also emailed these items to TT.
                          • halroachH Offline
                            halroach
                            Hi Thom,
                            When I edit a rotated 3D text object, it bounces to a new position and resets it's rotation...
                            On the other hand if I have multiple instances, only the one I select to edit bounces and changes rotation, while the others maintain their position...
                            • dkdickialD Offline
                              dkdickial
                              First good job thomthom.
                              But I got two problem while using it.
                              When start the plugin, this popup come up.
                              And when click the font, there is none fonts for chose.
                              BTW, my computer system is windows 7 and IE is 11.
                              Hope you can help me fix it, thanks.
                              • tt_suT Offline
                                tt_su
                                What version of TT_Lib2 do you have installed?
                                  dkdickial
                                  TT Library v2.8.3
                                    Should the file path be .../SketchUp**%20**2013/...? Could that be a problem?
                                      It is... but the string breaks at the % because it can't fit in the dialog.
                                      The error is that the font-list is empty so the js can't work with it...
                                      So something is stopping the font-list getting made... or at least 'displayed' in the dropdown...
                                      Perhaps the dropdown making code is at fault - that's why the newest Lib is required as that has reused methods for that kind of thing...
                                      Assuming it is...
                                      In tt's code if the fonts-list that the code tries to make is 'empty' it then uses a default fonts-list anyway... So there should be fonts listed ??
                                      It does seem to be making some 3d text using Arial [?]...
                                      So it suggests that you have somehow mis-installed the toolset's files ?
                                      Is there any Windows Explorer > Compatibility Files / VirtualStore issues ?
                                      Do you have FULL Security permissions to read/write files to the Plugins folder ?
                                        I wasn't thinking of the line break in the dialog box but rather the %20 instead of a space. Maybe it doesn't matter in this case.
                                          dkdickial
                                          Uh, seems a little complex...
                                          1. I'm login as administrator, so I think I have full security permissions to read/write files to the Plugins folder.
                                          2. All plugins are auto-installed in the sketchUcation store, so I think the "mis-installed" question doesn't exist.
                                          3. As for the "Windows Explorer > Compatibility Files / VirtualStore issue", I have no idea 😞
                                            Being logged in as administrator does not assure full permissions to the Plugins folder are granted. You need to check that and change it if permissions are not granted. Not that complex.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
