    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
    • G
      glro
      @tt_su said:
      @glro said:
      i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
      but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
      so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
      Whaaat? 😕
      You shouldn't need to downgrade. Are you on Windows by any chance?
      Maybe you ended up with some files in VirtualStore...
      How did you install it?
      windows 7 64 bits
      installed using preferences > extensions
      downloaded vers 2.8.3 here
      http://sketchucation.com/resources/pluginstore?pln=TT_Lib
      but it didn't work so i downloaded the previous version using the link that appeared on my screen
      but it's OK now;works great
      • tt_suT
        tt_su
        That is strange. I need to look into that.
          matt.gordon320
          @dave r said:
          [attachment=0:38jz7em6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:38jz7em6]
          FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
          http://s23.postimg.org/pu5me6ejb/3d_text_editor.jpg
          Dave/TT - I'm glad to hear it's already capable, but here's the embarrassing part:I can't figure out how to do it 😳 . I've updated to the most recent version, but maybe I have an older version floating around in Virtual Store or something?
          EDIT - Ok I'm stupid. I just realized what you meant @Dave.
          http://s24.postimg.org/x152egbj9/I_m_Stupid.jpg
          download screenshot
            Matt, I hope this doesn't embarrass you further. Try using Enter between typing the letters. 😉 I setting Align to Center. You may need to play with the leading (spacing) between the letters after you've created the text but that will depend upon the font you choose.
            Edit: You edited your post while I was typing. 😄 Now you've got it and if anyone asked, it was a great day because you learned something. 👍
              matt.gordon320
              Haha no worries Dave. I've frequently found that publicly making a fool of myself is the best way to learn, and I'm ok with that 😄 I'm sure you experienced programmers will have a good laugh when I finally get around to releasing an actual plugin.
              • tt_suT
                tt_su
                Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
                • ntxdaveN
                  ntxdave
                  I really like the plugin but have a couple of things I would like for it to do (if possible):
                  1. I would like for it to remember my selections (font, size, alignment, etc.) so that I do not have to go through the selections everytime.
                  2. I would like to be able to specify the color (both face and outline if possible). In fact, it would be great if there was a way to eliminate the outline. I have a lot of text to enter in my model and it is a pain to go eliminate the outline all of the time.
                  Press F1...thank me later
                  • tt_suT
                    tt_su
                    "Outline"?
                      I suppose he means he's hiding the edges.
                      @ntxdave, how is it that you current "eliminate the outline" on 3D text?
                      • ntxdaveN
                        ntxdave
                        Switch to wireframe style, Edit Component (the 3d text), select of the text, hide the text, then switch the style back to shaded with textures. This results with only the "face" of the text (if you colored it - which I do with the pain bucket tool).
                        While this works, it is a pain when you have a lot of text components in the model (which I do). Thus the desire to have the ability to do these additional things.
                        • halroachH
                          halroach
                          1. This plugin's download needs updating on the first post. On the plugins store it's 1.1.3
                          FlexTools - Super Quick Windows, Doors, Slats...
                            Sorted.
                            • Bob JamesB
                              Bob James
                              1. It already does (at least for me)
                              2. +1
                              • ntxdaveN
                                ntxdave
                                2. +1
                                I just tried again on 2 different machines and #1 does not work for me. I really wish it did. I have also emailed these items to TT.
                                • halroachH
                                  halroach
                                  Hi Thom,
                                  When I edit a rotated 3D text object, it bounces to a new position and resets it's rotation...
                                  On the other hand if I have multiple instances, only the one I select to edit bounces and changes rotation, while the others maintain their position...
                                  • dkdickialD
                                    dkdickial
                                    First good job thomthom.
                                    But I got two problem while using it.
                                    When start the plugin, this popup come up.
                                    And when click the font, there is none fonts for chose.
                                    BTW, my computer system is windows 7 and IE is 11.
                                    Hope you can help me fix it, thanks.
                                    • tt_suT
                                      tt_su
                                      What version of TT_Lib2 do you have installed?
                                      • dkdickialD
                                        dkdickial
                                        TT Library v2.8.3
                                          Should the file path be .../SketchUp**%20**2013/...? Could that be a problem?
                                            It is... but the string breaks at the % because it can't fit in the dialog.
                                            The error is that the font-list is empty so the js can't work with it...
                                            So something is stopping the font-list getting made... or at least 'displayed' in the dropdown...
                                            Perhaps the dropdown making code is at fault - that's why the newest Lib is required as that has reused methods for that kind of thing...
                                            Assuming it is...
                                            In tt's code if the fonts-list that the code tries to make is 'empty' it then uses a default fonts-list anyway... So there should be fonts listed ??
                                            It does seem to be making some 3d text using Arial [?]...
                                            So it suggests that you have somehow mis-installed the toolset's files ?
                                            Is there any Windows Explorer > Compatibility Files / VirtualStore issues ?
                                            Do you have FULL Security permissions to read/write files to the Plugins folder ?
                                            • 11
                                            • 6 / 11
