    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
    • tt_suT
      tt_su
      Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
      • ntxdaveN
        ntxdave
        I really like the plugin but have a couple of things I would like for it to do (if possible):
        1. I would like for it to remember my selections (font, size, alignment, etc.) so that I do not have to go through the selections everytime.
        2. I would like to be able to specify the color (both face and outline if possible). In fact, it would be great if there was a way to eliminate the outline. I have a lot of text to enter in my model and it is a pain to go eliminate the outline all of the time.
        Press F1...thank me later
        • tt_suT
          tt_su
          "Outline"?
            I suppose he means he's hiding the edges.
            @ntxdave, how is it that you current "eliminate the outline" on 3D text?
            • ntxdaveN
              ntxdave
              Switch to wireframe style, Edit Component (the 3d text), select of the text, hide the text, then switch the style back to shaded with textures. This results with only the "face" of the text (if you colored it - which I do with the pain bucket tool).
              While this works, it is a pain when you have a lot of text components in the model (which I do). Thus the desire to have the ability to do these additional things.
              • halroachH
                halroach
                1. This plugin's download needs updating on the first post. On the plugins store it's 1.1.3
                FlexTools - Super Quick Windows, Doors, Slats...
                  Sorted.
                  • Bob JamesB
                    Bob James
                    1. It already does (at least for me)
                    2. +1
                    • ntxdaveN
                      ntxdave
                      2. +1
                      I just tried again on 2 different machines and #1 does not work for me. I really wish it did. I have also emailed these items to TT.
                      • halroachH
                        halroach
                        Hi Thom,
                        When I edit a rotated 3D text object, it bounces to a new position and resets it's rotation...
                        On the other hand if I have multiple instances, only the one I select to edit bounces and changes rotation, while the others maintain their position...
                        • dkdickialD
                          dkdickial
                          First good job thomthom.
                          But I got two problem while using it.
                          When start the plugin, this popup come up.
                          And when click the font, there is none fonts for chose.
                          BTW, my computer system is windows 7 and IE is 11.
                          Hope you can help me fix it, thanks.
                          • tt_suT
                            tt_su
                            What version of TT_Lib2 do you have installed?
                            • dkdickialD
                              dkdickial
                              TT Library v2.8.3
                                Should the file path be .../SketchUp**%20**2013/...? Could that be a problem?
                                  It is... but the string breaks at the % because it can't fit in the dialog.
                                  The error is that the font-list is empty so the js can't work with it...
                                  So something is stopping the font-list getting made... or at least 'displayed' in the dropdown...
                                  Perhaps the dropdown making code is at fault - that's why the newest Lib is required as that has reused methods for that kind of thing...
                                  Assuming it is...
                                  In tt's code if the fonts-list that the code tries to make is 'empty' it then uses a default fonts-list anyway... So there should be fonts listed ??
                                  It does seem to be making some 3d text using Arial [?]...
                                  So it suggests that you have somehow mis-installed the toolset's files ?
                                  Is there any Windows Explorer > Compatibility Files / VirtualStore issues ?
                                  Do you have FULL Security permissions to read/write files to the Plugins folder ?
                                    I wasn't thinking of the line break in the dialog box but rather the %20 instead of a space. Maybe it doesn't matter in this case.
                                    • dkdickialD
                                      dkdickial
                                      Uh, seems a little complex...
                                      1. I'm login as administrator, so I think I have full security permissions to read/write files to the Plugins folder.
                                      2. All plugins are auto-installed in the sketchUcation store, so I think the "mis-installed" question doesn't exist.
                                      3. As for the "Windows Explorer > Compatibility Files / VirtualStore issue", I have no idea 😞
                                        Being logged in as administrator does not assure full permissions to the Plugins folder are granted. You need to check that and change it if permissions are not granted. Not that complex.
                                          With admin powers...
                                          Select the Plugins folder icon.
                                          Right-click
                                          Context-menu
                                          Properties
                                          Security
                                          Edit...
                                          Ensure everyone in the list has FULL permissions ticked.
                                          Apply/OK
                                          The permissions to subfolders within the 'Program Files' tree, of everyone - including admins - are limited by Windows by default. You simply need to reset them to FULL, otherwise you will not be able to add/change files into that folder - although you think you have !
                                          Also while you are at it...
                                          Select the SketchUp.exe file icon [in the same folder as the Plugins folder].
                                          Right-click
                                          Context-menu
                                          Properties
                                          Compatibility
                                          Always run as administrator... should be ticked
                                          Apply/OK
                                          The 'Compatibility Files' issue arises if you have limited security permissions to a folder - like Plugins - and Windows [weirdly] lets you think you have installed actually the file[s] and subfolders etc, but in fact it has put them into a VirtualStore - so if you have a 'Compatibility Files...' link/button in the top bars of your Windows Explorer window for a folder like Plugins then that's a sign of you having insufficient permissions to add/change files; click on the link to see what you think was installed but is squirreled away by the OS 😒
                                          • tt_suT
                                            tt_su
                                            Hm... I've not had time to look at this yet, but TIG's comment about the font list not being populated could be a clue. Maybe IE11 had removed the MS hack I used to get the font list...
                                            The %20 instead of a space is just IE transforming the path string into a URL string. Nothing wrong there.
                                            • 11
                                            • 6 / 11
