    [Plugin] 3D Text Editor
    202 Posts 50 Posters 202.0k Views 49 Watching
        matt.gordon320
        Hi Thomthom, thanks again for an awesome plugin. I have an idea for a feature that some might find useful if they're doing visualization work - vertically stacked text (like the following, perhaps).
        http://2.bp.blogspot.com/_nswHPYi_dEw/SoWP9m4sr6I/AAAAAAAAH_4/BUtChw6LSK8/s400/P1000262.JPG
        Any way, just a thought! Thanks for creating so many awesome tools, it's inspiring. I'm slowly learning code, and it's great to see what you've written.
        Matt
          FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
            glro
            i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
            but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
            so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
            and then it worked
            you did a great job
            you managed to make a multilines editor...
            would it be possible to ...? 😛
            have the 3d text in a red/blue plan, instead of red/green?
            i would like to use your plugin to add comments to a scene, one comment per scene; usually, the camera is oriented so that vertical objects appear vertical
            So, it would be easier to read if the text was in the red/blue plan.
              glro
              and then it worked
              you did a great job
              no, i just realised that you can change the plan by writing on a face of the model; so to write vertically, you just have to find a vertical face in the model
              • tt_suT Offline
                tt_su
                Whaaat? 😕
                You shouldn't need to downgrade. Are you on Windows by any chance?
                Maybe you ended up with some files in VirtualStore...
                How did you install it?
                  glro
                  Whaaat? 😕
                  windows 7 64 bits
                  installed using preferences > extensions
                  downloaded vers 2.8.3 here
                  http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                  but it didn't work so i downloaded the previous version using the link that appeared on my screen
                  but it's OK now;works great
                  • tt_suT Offline
                    tt_su
                    That is strange. I need to look into that.
                      matt.gordon320
                      @dave r said:
                      [attachment=0:38jz7em6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:38jz7em6]
                      http://s23.postimg.org/pu5me6ejb/3d_text_editor.jpg
                      Dave/TT - I'm glad to hear it's already capable, but here's the embarrassing part:I can't figure out how to do it 😳 . I've updated to the most recent version, but maybe I have an older version floating around in Virtual Store or something?
                      EDIT - Ok I'm stupid. I just realized what you meant @Dave.
                      http://s24.postimg.org/x152egbj9/I_m_Stupid.jpg
                      download screenshot
                        Matt, I hope this doesn't embarrass you further. Try using Enter between typing the letters. 😉 I setting Align to Center. You may need to play with the leading (spacing) between the letters after you've created the text but that will depend upon the font you choose.
                        Edit: You edited your post while I was typing. 😄 Now you've got it and if anyone asked, it was a great day because you learned something. 👍
                          matt.gordon320
                          Haha no worries Dave. I've frequently found that publicly making a fool of myself is the best way to learn, and I'm ok with that 😄 I'm sure you experienced programmers will have a good laugh when I finally get around to releasing an actual plugin.
                          • tt_suT Offline
                            tt_su
                            Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
                            • ntxdaveN Offline
                              ntxdave
                              I really like the plugin but have a couple of things I would like for it to do (if possible):
                              1. I would like for it to remember my selections (font, size, alignment, etc.) so that I do not have to go through the selections everytime.
                              2. I would like to be able to specify the color (both face and outline if possible). In fact, it would be great if there was a way to eliminate the outline. I have a lot of text to enter in my model and it is a pain to go eliminate the outline all of the time.
                              Press F1...thank me later
                              • tt_suT Offline
                                tt_su
                                "Outline"?
                                  I suppose he means he's hiding the edges.
                                  @ntxdave, how is it that you current "eliminate the outline" on 3D text?
                                  • ntxdaveN Offline
                                    ntxdave
                                    Switch to wireframe style, Edit Component (the 3d text), select of the text, hide the text, then switch the style back to shaded with textures. This results with only the "face" of the text (if you colored it - which I do with the pain bucket tool).
                                    While this works, it is a pain when you have a lot of text components in the model (which I do). Thus the desire to have the ability to do these additional things.
                                    • halroachH Offline
                                      halroach
                                      1. This plugin's download needs updating on the first post. On the plugins store it's 1.1.3
                                      FlexTools - Super Quick Windows, Doors, Slats...
                                        Sorted.
                                        • Bob JamesB Offline
                                          Bob James
                                          1. It already does (at least for me)
                                          2. +1
                                          • ntxdaveN Offline
                                            ntxdave
                                            2. +1
                                            I just tried again on 2 different machines and #1 does not work for me. I really wish it did. I have also emailed these items to TT.
                                            • 11
                                            • 6 / 11
