    Questions about realization of tools
    20 Posts 4 Posters 797 Views 4 Watching
      dacastror
      Hi, I'm trying to create a tool and I have arisen various questions in the process.
      One question is how orienting a tool as shown in the image? since there are no faces on which to place the tool and degrees_of_freedom is in this case = 3
      rotate tool
      Another question I have is, How to detect the position of the tool outside the edit window?, (as happens with the orbit tool).
      Orbit tool
      and the other question is, what command I can use for prevent my tool this cropped and disappears only when I leave the drawing window?
      sorry for these "gif" can be a bit annoying but needed to illustrate my questions 😄
      (google translator)
        #1. You make special cases for that. When you don´t hit any geometry, Make a pickray and see if it intersects any of the XY, XZ, YZ planes.
        #2. Don´t think you can with just pure Ruby. The native tools do that because they are done in C++ and capture the mouse. Unfortunatly there is no way to capture the mouse from the Ruby API.
          dacastror
          Thomthom thank you very much!, That's what I'll do 😄
          It is a pity. I thought this might serve me
          require 'Win32API'
          getCursorPos = Win32API.new("user32", "GetCursorPos", ['P'], 'V')
          lpPoint = " " * 8 # store two LONGs
          getCursorPos.Call(lpPoint)
          x, y = lpPoint.unpack("LL") # get the actual values
          coor_mouse = " y = #{x},  x = #{y}"
          but at the end I think can not because onMouseMove only respond within the drawing window.
          any suggestions to prevent my tool display incomplete?
            What if you also hook into the event callback of when the cursor moves? Ignoring the Tool class' events?
                Jim
                @thomthom said:
                getExtents, maybe.
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool#getExtents
                  dacastror
                  @jim said:
                  getExtents, maybe.
                  thank you very much Jim!, this solved the problem, cost me a bit to understand how to implement it, but it goes
                  I tried but it works very slow when the cursor is outside the window of Sketchup, 😞
                    Got a bare bone example that shows this slowness?
                      dacastror
                      Yes,
                      require 'Win32API'
                      Thread.new {
                         x=1
                         while (x<1000) do
                           coor_mouse = "  #{x},  #{y}"
                           Sketchup;;set_status_text coor_mouse, SB_VCB_VALUE
                      Note : to see how slow returns coordinates, should be small the Sketchup window and put the cursor outside it, to stop the program move the cursor to the right until x >1000
                      (Google Translator)
                        Threads doesn't work well in SketchUp Ruby. It's Ruby 1.8 and they are not true threads.
                        And I see you are polling GetCursorPos. I was thinking if there might be a callback function you could register instead.
                          dacastror
                          I did not know this 😲, thanks
                            dacastror
                            I give up, I can not understand how to use view.pickray x, y for the intersection with the XY, XZ and YZ, and thereby be able to guide a tool, really I can not see how this is done 😞
                            I could only understand that returns two points, one coincides with the point of view and the other (I think) is a vector pointing toward the cursor, but do not understand how to use this to get the intersection with the respective flat front or behind me
                            • Dan RathbunD Offline
                              Dan Rathbun
                              View.pickray() can take ANY screen co-ordinate (it can be, or may not be the mouse position.)
                              It returns a ray
                              A ray is a two element array containing a point and a vector [ Geom::Point3d, Geom::Vector3d ]. The point defines the start point of the ray and the vector defines the direction.
                              I'm not here much anymore.
                                Dan Rathbun
                                Perhaps you wish to use model#raytest ?
                                It can return objects it hits.
                                View#pickray() does not, by itself, "hit" anything, but could be used for the 1st argument to Model#raytest().
                                  dacastror
                                  Guys, how to remove an observer of tools? I created an observer slightly modifying the example shown in the API
                                  class MyToolsObserver < Sketchup;;ToolsObserver
                                     def onActiveToolChanged(tools, tool_name, tool_id)
                                        if tool_id == 21100
                                           puts "tool x"
                                  Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                                  I thought you could with something like this:
                                  Sketchup.active_model.tools.remove_observer(MyToolsObserver)
                                  What is the correct way to remove this observer?
                                    Keep a reference to the observer instance.
                                    <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool_observer&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">MyToolsObserver</span><span class="syntaxkeyword">.new<br /><br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tools</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">tool_observer</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tools</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">remove_observer</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">tool_observer</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                      dacastror
                                      Thanks Dan, I now understand better 😄
                                      I've never used it, looks interesting I'll give a look.
                                      For now solve the problem using the parametric form of the line;
                                      x = x0 + ta
                                      y = y0 + t
                                      b
                                      z = z0 + t*c
                                      in my case a, b, c is associated with Geom :: Vector3D (parallel to the line)
                                      and x0, y0, z0 is associated with Geom :: Point3D (content in the line)
                                      the intersection with plane z=0 (XY plane), for example would be
                                      ray = view.pickray x, y  #ray[0] -> Point3D, ray[1] -> Vector3d
                                      if ray[1].z.abs>0
                                         z1 = 0 #Interesting plane
                                         t1 = (z1-ray[0].z)/ray[1].z
                                         x1 = ray[0].x + t1*ray[1].x
                                         y1 = ray[0].y + t1*ray[1].y
                                      #x1,y1,z1 are coordinates of the point of intersection with the plane
                                      For the other two planes is very similar, although in my case I want to compare the different distances of the planes to the point of "eye" for this I did the following
                                      if ray[1].z.abs>0
                                         d1 = (t1*ray[1].x)**2 + (t1*ray[1].y)**2 + (z1-ray[0].z)**2
                                      #d1 is the square of the distance from the eye to the plane
                                        dacastror
                                        Thom thank you very much, really I could not understand how to do this 👍 😄
                                          The API doc examples are confusing. One learn the hard way.
                                            dacastror
                                            is true, on several occasions have been very frustrating these examples
                                            error
