    Questions about realization of tools
    20 Posts 4 Posters 1.1k Views 4 Watching
      Threads doesn't work well in SketchUp Ruby. It's Ruby 1.8 and they are not true threads.
      And I see you are polling GetCursorPos. I was thinking if there might be a callback function you could register instead.
        dacastror
        I did not know this 😲, thanks
          dacastror
          I give up, I can not understand how to use view.pickray x, y for the intersection with the XY, XZ and YZ, and thereby be able to guide a tool, really I can not see how this is done 😞
          I could only understand that returns two points, one coincides with the point of view and the other (I think) is a vector pointing toward the cursor, but do not understand how to use this to get the intersection with the respective flat front or behind me
          • Dan RathbunD Offline
            Dan Rathbun
            View.pickray() can take ANY screen co-ordinate (it can be, or may not be the mouse position.)
            It returns a ray
            A ray is a two element array containing a point and a vector [ Geom::Point3d, Geom::Vector3d ]. The point defines the start point of the ray and the vector defines the direction.
            I'm not here much anymore.
              Dan Rathbun
              Perhaps you wish to use model#raytest ?
              It can return objects it hits.
              View#pickray() does not, by itself, "hit" anything, but could be used for the 1st argument to Model#raytest().
                dacastror
                Guys, how to remove an observer of tools? I created an observer slightly modifying the example shown in the API
                class MyToolsObserver < Sketchup;;ToolsObserver
                   def onActiveToolChanged(tools, tool_name, tool_id)
                      if tool_id == 21100
                         puts "tool x"
                Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                I thought you could with something like this:
                Sketchup.active_model.tools.remove_observer(MyToolsObserver)
                What is the correct way to remove this observer?
                  Keep a reference to the observer instance.
                  <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool_observer&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">MyToolsObserver</span><span class="syntaxkeyword">.new<br /><br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tools</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">tool_observer</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tools</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">remove_observer</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">tool_observer</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                    dacastror
                    Thanks Dan, I now understand better 😄
                    I've never used it, looks interesting I'll give a look.
                    For now solve the problem using the parametric form of the line;
                    x = x0 + ta
                    y = y0 + t
                    b
                    z = z0 + t*c
                    in my case a, b, c is associated with Geom :: Vector3D (parallel to the line)
                    and x0, y0, z0 is associated with Geom :: Point3D (content in the line)
                    the intersection with plane z=0 (XY plane), for example would be
                    ray = view.pickray x, y  #ray[0] -> Point3D, ray[1] -> Vector3d
                    if ray[1].z.abs>0
                       z1 = 0 #Interesting plane
                       t1 = (z1-ray[0].z)/ray[1].z
                       x1 = ray[0].x + t1*ray[1].x
                       y1 = ray[0].y + t1*ray[1].y
                    #x1,y1,z1 are coordinates of the point of intersection with the plane
                    For the other two planes is very similar, although in my case I want to compare the different distances of the planes to the point of "eye" for this I did the following
                    if ray[1].z.abs>0
                       d1 = (t1*ray[1].x)**2 + (t1*ray[1].y)**2 + (z1-ray[0].z)**2
                    #d1 is the square of the distance from the eye to the plane
                      dacastror
                      Thom thank you very much, really I could not understand how to do this 👍 😄
                        The API doc examples are confusing. One learn the hard way.
                          dacastror
                          is true, on several occasions have been very frustrating these examples
                          error
