    Grasshopper lamp
    18 Posts 11 Posters 1.7k Views 11 Watching
    • massimoM
      massimo Moderator
      Designed in 1947 by Greta Magnusson. Powder-coated metallic tripod stand and elongated conical shade. Solid brass hardware. Rendered with Thea. πŸ˜„
      • boofredlayB
        boofredlay
        Perfect!
        • soloS
          solo
          As always...brilliant!
          http://www.solos-art.com
          • StinkieS
            Stinkie
            Agreed! Care to let us have a look at the wall material?
            • FrederikF
              Frederik
              You're a master in making fairly simple scenes look stunning...! πŸ‘ πŸ‘ πŸ‘
              Cheers
              Kim Frederik
              • StinkieS
                Stinkie
                Thanks, Massimo. πŸ˜„
                • massimoM
                  massimo Moderator
                  Thank you very much for the kind words guys. πŸ˜„
                  Tom it's a pretty simple mat. The diffuse map is a painted wood texture I made by mixing some photos. Also was a bit desaturated in Thea. In the roughness slot I inverted the specular map.
                  • olisheaO
                    olishea
                    so white = rough, black = smooth? For roughness slot?
                    Lovely work. Liking the wood block!
                    oli
                    • unrealVizU
                      unrealViz
                      Beautiful scene. And I love this lamp.
                      Agree. The mastery in materials is responsible for this. Probably. Partly at least. πŸ˜„
                      http://www.unrealviz.blogspot.com
                      • N
                        notareal
                        yes.
                        • massimoM
                          massimo Moderator
                          Thanks guys. πŸ˜„
                          Oli it's a free sample by Bertrand Benoit. A bit low res though. πŸ˜„
                          • allanxA
                            allanx
                            Wow! love the render...
                            allanx
                            Portfolio
                            • massimoM
                              massimo Moderator
                              Glad you like it Allan. πŸ˜„
                                In the More Settings I see saturation -50 but no inversion?
                                Really nice btw. Such a gifted talent for material setup.
                                • massimoM
                                  massimo Moderator
                                  That -50 in saturation is for the diffuse map and that "more settings" panel shows the settings of the tone mapping for the diffuse map. In the screenshot you can see to which map is related the "more settings" panel by checking the coloured "texture" button near to the texture in the main mat panel. The inverted spec map is in the roughness slot.
                                  If you do left click on the "texture" button in solid mode view you can see how that texture is applied on the model. If you do right click then the "more settings" panel will appear.
                                  Anyway here you have the ss for the spec & rough maps.
                                  Hope I understood your question. πŸ˜„
                                  • hellnbakH
                                    hellnbak
                                    Very nice render, very realistic (although all this render-jargon stuff goes right over my head)
                                    Curious tho - why is it called a Grasshopper lamp? Did Caine have one when he was training on "Kung Foo"?
                                    • massimoM
                                      massimo Moderator
                                      Thanks Steve. πŸ˜„
                                      Perhaps because it reminds a grasshopper? πŸ˜›
                                      • hellnbakH
                                        hellnbak
                                        @massimo said:
                                        Thanks Steve. πŸ˜„
                                        Well, that was my first thought. But I looked and looked at it and I just don't see a grasshopper there. Maybe a praying mantis?
                                        Well, anyhow, really nice work.
