    Grasshopper lamp
    18 Posts 11 Posters 1.7k Views 11 Watching
    • StinkieS
      Stinkie
      Agreed! Care to let us have a look at the wall material?
      • FrederikF
        Frederik
        You're a master in making fairly simple scenes look stunning...! πŸ‘ πŸ‘ πŸ‘
        Cheers
        Kim Frederik
        • StinkieS
          Stinkie
          Thanks, Massimo. πŸ˜„
          • massimoM
            massimo Moderator
            Thank you very much for the kind words guys. πŸ˜„
            Tom it's a pretty simple mat. The diffuse map is a painted wood texture I made by mixing some photos. Also was a bit desaturated in Thea. In the roughness slot I inverted the specular map.
            • olisheaO
              olishea
              so white = rough, black = smooth? For roughness slot?
              Lovely work. Liking the wood block!
              oli
              • unrealVizU
                unrealViz
                Beautiful scene. And I love this lamp.
                Agree. The mastery in materials is responsible for this. Probably. Partly at least. πŸ˜„
                http://www.unrealviz.blogspot.com
                • N
                  notareal
                  yes.
                  • massimoM
                    massimo Moderator
                    Thanks guys. πŸ˜„
                    Oli it's a free sample by Bertrand Benoit. A bit low res though. πŸ˜„
                    • allanxA
                      allanx
                      Wow! love the render...
                      allanx
                      Portfolio
                      • massimoM
                        massimo Moderator
                        Glad you like it Allan. πŸ˜„
                          In the More Settings I see saturation -50 but no inversion?
                          Really nice btw. Such a gifted talent for material setup.
                          • massimoM
                            massimo Moderator
                            That -50 in saturation is for the diffuse map and that "more settings" panel shows the settings of the tone mapping for the diffuse map. In the screenshot you can see to which map is related the "more settings" panel by checking the coloured "texture" button near to the texture in the main mat panel. The inverted spec map is in the roughness slot.
                            If you do left click on the "texture" button in solid mode view you can see how that texture is applied on the model. If you do right click then the "more settings" panel will appear.
                            Anyway here you have the ss for the spec & rough maps.
                            Hope I understood your question. πŸ˜„
                            • hellnbakH
                              hellnbak
                              Very nice render, very realistic (although all this render-jargon stuff goes right over my head)
                              Curious tho - why is it called a Grasshopper lamp? Did Caine have one when he was training on "Kung Foo"?
                              • massimoM
                                massimo Moderator
                                Thanks Steve. πŸ˜„
                                Perhaps because it reminds a grasshopper? πŸ˜›
                                • hellnbakH
                                  hellnbak
                                  @massimo said:
                                  Thanks Steve. πŸ˜„
                                  Well, that was my first thought. But I looked and looked at it and I just don't see a grasshopper there. Maybe a praying mantis?
                                  Well, anyhow, really nice work.
