    CatchUp Edition 14 - SketchUcation 2.0
    12 Posts 10 Posters 3.9k Views 10 Watching
    • Rich O BrienR Online
      http://i.minus.com/iAaPKSVFkcnlo.png
      Download Interactive PDF
      View Online
      In this edition....
      Curves to Flats
      http://i.minus.com/i0wn24nSyiPKm.png
      Massimo Siracusa's elegant lofting technique using CurviLoft
      Artisan v1.2 Update
      http://i.minus.com/iba3lV1qfuaNhr.png
      What's new in Dale Martens sculpting plugin for SketchUp.
      Slingshot
      http://i.minus.com/i9l6DSn9rwdGZ.jpg
      Mike Lucey takes the Slingshot smartphone accessory for a test drive.
      SketchUcation 2.0
      http://i.minus.com/iFjquDkgtDTDp.png
      The ins and outs of the brand new site by Csaba Pozsarko.
      Cut & Split to Plane
      http://i.minus.com/iSNOyF5wKAjj9.png
      TIG's latest plugins explained.
      Freebies
      http://i.minus.com/iwsqJo5WVTlSi.jpg
      What members have shared over the last few weeks.
      Keyframe Animation
      A look at Regular Polygon's animation toolset for SketchUp.
      ArchiDraw
      http://i.minus.com/ibwUwn88w1Lgow.gif
      The new iPad 2D drafting app.
      To download the Interactive PDF you can go here
      or to view in Flipping Page Format online you can go here
      As always feel free to comment here as we love feedback.
      • iichiversiiI Offline
        iichiversii
        Hell yeah, something to read ๐Ÿ‘
        Bring on the Rain...
          You make such things with in a very speedy little time! ๐Ÿ˜ฒ
          Nยฐ 13 was yesterday! โ˜€
          • olisheaO Offline
            olishea
            Great work! Fantastic read. ๐Ÿ‘
            oli
            • massimoM Offline
              massimo Moderator
              ๐Ÿ‘ As usual.
              • cottyC Offline
                cotty
                great collection (as always)!
                One question (see picture): is it really possible to change the position of the arrow after the text was created? I'm not able to dofollow the hint...
                my SketchUp gallery
                • Dan RathbunD Offline
                  Dan Rathbun
                  Yes I can, but sometimes it's tricky, it selects move leader instead. Often takes a few trys, or zooming in a bit.
                  Didn't know the TextTool had editing features for existing objects. (Learn something new everyday.)
                  I'm not here much anymore.
                  • boofredlayB Offline
                    boofredlay
                    Beautifully done as usual Rich.
                    • cottyC Offline
                      cotty
                      I'm not able to change the target of the arrow, can you explain the conductive steps to me, please?
                      my SketchUp gallery
                        Bertier
                        great job !
                        ๐Ÿ˜Ž
                          If you want to edit some preexisting Text... activate the 'Text' tool, instead of placing the arrowhead, then the text-block, and then typing in the desired text-string for a new piece of Text, you can use it to 'edit' any existing Text in three ways.
                          • Double-click on the text-block's string itself and it will open to be edited - change the string as desired.
                          • Click+drag on the text-block - i.e. hold the left-mouse-button down and drag the cursor [now with the text-block attached to it] to any new position - similar to using the 'Move' tool on selected Text objects...
                          • Click+drag on the text-leader's arrowhead - i.e. hold the left-mouse-button down and drag the cursor [now attached onto the arrowhead] to a new position for the arrow, snapping the arrowhead onto any new object - resulting in a modified piece of Text that you would have otherwise needed to recreate from scratch...
                            Once done you can continue with the Text tool to edit other Text objects in these ways, or make new Text objects...
                          • cottyC Offline
                            cotty
                            8 attempts didn't work, the ninth was successful. Thank you!
                            my SketchUp gallery
