    CatchUp Edition 14 - SketchUcation 2.0
    12 Posts 10 Posters 3.8k Views 10 Watching
      You make such things with in a very speedy little time! 😲
      N° 13 was yesterday! ☀
      • olisheaO Offline
        olishea
        Great work! Fantastic read. 👍
        oli
        • massimoM Offline
          massimo Moderator
          👍 As usual.
          • cottyC Offline
            cotty
            great collection (as always)!
            One question (see picture): is it really possible to change the position of the arrow after the text was created? I'm not able to dofollow the hint...
            my SketchUp gallery
            • Dan RathbunD Offline
              Dan Rathbun
              Yes I can, but sometimes it's tricky, it selects move leader instead. Often takes a few trys, or zooming in a bit.
              Didn't know the TextTool had editing features for existing objects. (Learn something new everyday.)
              I'm not here much anymore.
              • boofredlayB Offline
                boofredlay
                Beautifully done as usual Rich.
                • cottyC Offline
                  cotty
                  I'm not able to change the target of the arrow, can you explain the conductive steps to me, please?
                  my SketchUp gallery
                    Bertier
                    great job !
                      If you want to edit some preexisting Text... activate the 'Text' tool, instead of placing the arrowhead, then the text-block, and then typing in the desired text-string for a new piece of Text, you can use it to 'edit' any existing Text in three ways.
                      • Double-click on the text-block's string itself and it will open to be edited - change the string as desired.
                      • Click+drag on the text-block - i.e. hold the left-mouse-button down and drag the cursor [now with the text-block attached to it] to any new position - similar to using the 'Move' tool on selected Text objects...
                      • Click+drag on the text-leader's arrowhead - i.e. hold the left-mouse-button down and drag the cursor [now attached onto the arrowhead] to a new position for the arrow, snapping the arrowhead onto any new object - resulting in a modified piece of Text that you would have otherwise needed to recreate from scratch...
                        Once done you can continue with the Text tool to edit other Text objects in these ways, or make new Text objects...
                      • cottyC Offline
                        cotty
                        8 attempts didn't work, the ninth was successful. Thank you!
                        my SketchUp gallery
