    No way, is it ?
    21 Posts 6 Posters 1.5k Views 6 Watching
      JuanV.Soler
      There is no way to dock the windows (layer, components,styles, etc...) in SketchUp like in Layout, no ?
      just in case i missed it.
      Thank_you
        no unfortunately
          JuanV.Soler
          that was quick ¡
            You can actually do it but they won't be attached at the side as in LayOut. I have all of my SketchUp windows (layers, components, materials, etc. placed on the right side of my screen and the main window to the left. My screen is a 25" monitor and I have the main SketchUp window set to cover about 4/5 of the width of the entire screen. This gives room for the small windows on the right. Somewhere there is a thread where various people showed their screens and I have a screen shot of this.
              JuanV.Soler
              I understand, that´s a good workaround. Still...Layout`s way is better.
                I found the screen shot.
                • gullfoG Offline
                  gullfo
                  Dave - you definitely need some more tool bars 😄
                  Glenn
                  http://www.runnel.com
                    Actually, since that screen shot was made I think I have a few less.
                      This belongs to the general SketchUp section, right? I don't see anything related to plugins here.
                        Moved.
                          JuanV.Soler
                          My fault ¡
                          I thought it could be done with ruby.
                          By the way thomthom
                          was it of any use to you my post in http://sketchucation.com/forums/viewtopic.php?f=180&t=48090
                          just curious and a bit annoyed by your silence there .
                          thanks
                          • hellnbakH Offline
                            hellnbak
                            If you would include a more accurate description of your problem or question in the subject of your post, it will be easier for others to find in the future should they have a similar situation. Plus, it will increase your chances that someone with expertise in the area you are having a problem with will notice the post and maybe provide the help you need.
                              JuanV.Soler
                              sorry hellnbakI don´t get you.
                              I think my question was clear enough to get an answer as I fortunately did
                                @juanv.soler said:
                                By the way thomthom
                                thanks
                                I've not had time to investigate that issue - I've been working overtime this week - and I'm about to head into the office today as well.
                                  He was talking about the topic title - it's preferred that it is descriptive of the topic, not just something generic. Makes it easier when you search or browse for a given topic.
                                  In this case, a title of "Can you dock tool-windows in SketchUp like in Layout?" would be a better title instead of "No way, is it?"
                                  You see?
                                  • hellnbakH Offline
                                    hellnbak
                                    Yes, your question was clear enough. I was referring to the subject, "No way, is it?". What I was saying is that if you describe your question/problem in the subject of your post, somebody else who may have a similar question somewhere down the road can do a search and find this thread and maybe the information he needs. And as I mentioned, it also increases the chances of somebody noticing your post who has some expertise in the area in question.
                                    Not a huge thing, just a suggestion that makes these forums a bit more useful for everyone
                                    • hellnbakH Offline
                                      hellnbak
                                      ThomThom commented on this while I was making the last post, sorry for the redundancy 😉
                                        JuanV.Soler
                                        Ah ¡
                                        Ok
                                        I will be more accurate in the name of the topic next time .
                                        Thanks both .
                                            JuanV.Soler
                                            Ok, I can wait , but would like to know what happened when you get into it.
                                            • 1 / 2
