    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 262.7k Views 54 Watching
    • OxerO
      Oxer
      Thanks TIG for the effort but your icons don't show on Mac. 😒 ❓
      I don't know if the problem is in the ConicCurveInFace.rb file, if there is a missing code to load the icons. The mouse icon shows correctly.
      http://www.oxervision.blogspot.com/
      • TIGT
        I don't expect this to fix it... but you never know 😲
        Look in subfolder's .rb files for these lines...
        cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
        Change it to read thus:
        cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
        AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
        Save & restart SketchUp........
        • OxerO
          Oxer
          Thanks you very much TIG!! πŸ‘
          Problem fixed, I changed the lines and the icons show now.
          • CTXC
            CTX
            for TIG:
            Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
            Error message
            • O
              Oxygen220
              anyone know what to do when this happens?
              Error Loading File VoronoiXY.rb
              Error: #<LoadError: cannot load such file -- delauney3.rb>
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
              C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
              • TIGT
                Yes.
                It's an incompatibility with SketchUp v2014 Ruby2...
                I'm working on a fix...
                • O
                  Oxygen220
                  ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                  • TIGT
                    Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                    It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                    It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                    • OxerO
                      Oxer
                      Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                      @tig said:
                      The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
                      def onKeyDown(...
                      at line #10.
                      For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
                      It's easily fixed by changing the code to read:
                      def onKeyUp(...
                      So then when you release the TAB-key the dialog appears - works on MAC AND PC.
                      Also change the next line from:
                      if key==9 or key==15 or key==48...
                      to read:
                      if key==9 or key==15 ###or key==48...
                      • TIGT
                        Doh ! πŸ˜’
                        So many bug-fixes... v2.3 in progress...
                        • TIGT
                          Here's v2.3 which fixes the TAB bug on MACs...
                          • O
                            Oxygen220
                            god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                            • CTXC
                              CTX
                              For Tig:
                              Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                              MattC: VoronoiXY v2.3) now everything works great.
                              Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                              • CTXC
                                CTX
                                I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                                Many thanks
                                • TIGT
                                  This is the staple 'PointTool'...
                                  http://sketchucation.com/pluginstore?pln=PointTool
                                  Toolbar or menu item...
                                  It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
                                    You have Raytracer by Thomthom who dropts Cpoints on Surfaces! πŸ˜‰
                                    http://sketchucation.com/forums/download/file.php?id=53901&t=1
                                    • D
                                      darkshadow47
                                      OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
                                      The Conic curve in a face works fine...
                                      • R
                                        ronel_12
                                        No Existe para Pc ? saludos y bendiciones
                                        • TIGT
                                          No entiendo lo que quieres decir.
                                          Esto funciona en la PC.
                                          ΒΏPor quΓ© crees que no lo hace?
                                          I don't understand what you mean.
                                          This works on PC.
                                          Why do you think it does not?
                                          • A
                                            AUTER
                                            i tried to install in my SketchUp but didnt work... anyone could help me with this?
                                            • 6
                                            • 7
                                            • 5 / 7
