    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 257.9k Views 54 Watching
    • C
      ccs1987
      Does this work on SU 2014?
      Sketchup 8 pro
      Vray
      Intel Xeon W3520 2.67Ghz
      12Gb Ram
      Nvdia Quadro FX 1800
      • OxerO
        Oxer
        Interesting plugin but the icons don't show on Mac (see the image below), but they work fine.
        When I push Tab key on Mac the Options window doesn't apper.
        OSX 10.9.3 & SU2014
        • CTXC
          CTX
          any news on SU2014?
          thanks in advance!!
            It works in v2014 on PC for me. πŸ˜„
            You do need delauney3.rb loading to get the 'Voroni' part to load and work.
            The zip on this thread's second page includes that. http://sketchucation.com/forums/viewtopic.php?p=417942#p417942
            It also makes the toolbar.
            The issue with MAC and toolbar's missing icons is most usually to do with the PNG files' format.
            Some PC-made PNG images are not suitable for the MAC.
            Try editing the PNGs shipped within the ZIP's subfolder on the MAC and saving them, they might then become MAC-friendly.
            The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
            def onKeyDown(...
            at line #10.
            For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
            It's easily fixed by changing the code to read:
            def onKey**Up**(...
            So then when you release the TAB-key the dialog appears - works on MAC AND PC.
            Also change the next line from:
            if key==9 or key==15 or key==48...
            to read:
            if key==9 or key==15 ###or key==48...
            As key#48 is NOT a TAB newer MACs - it's #15, and #9 on PCs.
            You might find odd things happening otherwise.
            This old toolset is a bit creaky BUT it works, and can be fixed up easily too...
            • OxerO
              Oxer
              Thanks TIG for the info, the dialog appears now on MAC. The icons don't show, I changed them to png mac format and resize their resolution of 96 to 72 but without result. It's a mystery!! ❓
                If you make brand new PNG files does that help ?
                The attached ZIP contains just the PNG files at 72 dpi and with the Color Profile 'generalized' [i.e. NOT IExxx] - put them into the subfolder...
                Do they help on your MAC ?
                voronoi_conic.zip
                • OxerO
                  Oxer
                  Thanks TIG for the effort but your icons don't show on Mac. 😒 ❓
                  I don't know if the problem is in the ConicCurveInFace.rb file, if there is a missing code to load the icons. The mouse icon shows correctly.
                    I don't expect this to fix it... but you never know 😲
                    Look in subfolder's .rb files for these lines...
                    cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
                    Change it to read thus:
                    cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
                    AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
                    Save & restart SketchUp........
                    • OxerO
                      Oxer
                      Thanks you very much TIG!! πŸ‘
                      Problem fixed, I changed the lines and the icons show now.
                      • CTXC
                        CTX
                        for TIG:
                        Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
                        Error message
                        • O
                          Oxygen220
                          anyone know what to do when this happens?
                          Error Loading File VoronoiXY.rb
                          Error: #<LoadError: cannot load such file -- delauney3.rb>
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
                            Yes.
                            It's an incompatibility with SketchUp v2014 Ruby2...
                            I'm working on a fix...
                            • O
                              Oxygen220
                              ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                                Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                                It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                                It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                                • OxerO
                                  Oxer
                                  Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                                  def onKeyDown(...
                                  at line #10.
                                  def onKeyUp(...
                                  to read:
                                    Doh ! πŸ˜’
                                    So many bug-fixes... v2.3 in progress...
                                      Here's v2.3 which fixes the TAB bug on MACs...
                                      • O
                                        Oxygen220
                                        god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                                        • CTXC
                                          CTX
                                          For Tig:
                                          Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                                          MattC: VoronoiXY v2.3) now everything works great.
                                          Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                                          • CTXC
                                            CTX
                                            I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                                            Many thanks
                                            • 5 / 7
