    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 257.9k Views 54 Watching
    • OxerO
      Oxer
      Thanks TIG for the info, the dialog appears now on MAC. The icons don't show, I changed them to png mac format and resize their resolution of 96 to 72 but without result. It's a mystery!! ❓
        If you make brand new PNG files does that help ?
        The attached ZIP contains just the PNG files at 72 dpi and with the Color Profile 'generalized' [i.e. NOT IExxx] - put them into the subfolder...
        Do they help on your MAC ?
        voronoi_conic.zip
        • OxerO
          Oxer
          Thanks TIG for the effort but your icons don't show on Mac. 😒 ❓
          I don't know if the problem is in the ConicCurveInFace.rb file, if there is a missing code to load the icons. The mouse icon shows correctly.
            I don't expect this to fix it... but you never know 😲
            Look in subfolder's .rb files for these lines...
            cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
            Change it to read thus:
            cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
            AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
            Save & restart SketchUp........
            • OxerO
              Oxer
              Thanks you very much TIG!! πŸ‘
              Problem fixed, I changed the lines and the icons show now.
              • CTXC
                CTX
                for TIG:
                Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
                Error message
                • O
                  Oxygen220
                  anyone know what to do when this happens?
                  Error Loading File VoronoiXY.rb
                  Error: #<LoadError: cannot load such file -- delauney3.rb>
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                  C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
                    Yes.
                    It's an incompatibility with SketchUp v2014 Ruby2...
                    I'm working on a fix...
                    • O
                      Oxygen220
                      ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                        Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                        It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                        It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                        • OxerO
                          Oxer
                          Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                          @tig said:
                          The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
                          def onKeyDown(...
                          at line #10.
                          For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
                          It's easily fixed by changing the code to read:
                          def onKeyUp(...
                          So then when you release the TAB-key the dialog appears - works on MAC AND PC.
                          Also change the next line from:
                          if key==9 or key==15 or key==48...
                          to read:
                          if key==9 or key==15 ###or key==48...
                            Doh ! πŸ˜’
                            So many bug-fixes... v2.3 in progress...
                              Here's v2.3 which fixes the TAB bug on MACs...
                              • O
                                Oxygen220
                                god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                                • CTXC
                                  CTX
                                  For Tig:
                                  Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                                  MattC: VoronoiXY v2.3) now everything works great.
                                  Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                                  • CTXC
                                    CTX
                                    I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                                    Many thanks
                                      This is the staple 'PointTool'...
                                      http://sketchucation.com/pluginstore?pln=PointTool
                                      Toolbar or menu item...
                                      It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
                                        You have Raytracer by Thomthom who dropts Cpoints on Surfaces! πŸ˜‰
                                        http://sketchucation.com/forums/download/file.php?id=53901&t=1
                                          darkshadow47
                                          OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
                                          The Conic curve in a face works fine...
                                            ronel_12
                                            No Existe para Pc ? saludos y bendiciones
                                            • 5 / 7
